Question about HP VP6310 Multimedia Projector
Projector I have a projector that makes a funny chirping sound after its been only a few minutes. at first it appears to be working fine then within 2 minutes the color changes, image flickers then the projector powers off. like its ran hog then the Lamp Led blinks. i read some forums that said it was the color wheel sensor. If so. where can i find one? i've searched the web and found nothing. not even a price.
  • ThunderSlap Jan 19, 2009
    This Projector is an HP VP6310.
  • Albert Vasquez
    Albert Vasquez May 11, 2010
    What is the brand and model number?With this info I can head you in thr right direction.
    Problem Solver:
  • 18 Answers
The sound came from the switching power supply and the lamp ballast circuitary. You need to replace the color wheel sensor, I can fix it.
Posted on Jun 06, 2009
Red lamp/ orange/lamp After a "break" of about
test this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 28, 2013 | BenQ PB6110 Multimedia Projector
I have sanyo projector model PDG-DSU20E. Few white spots appeared on the right side of the screen. Gradually the spots has filled the right side about 1 feet is width till bottom of the screen. Now few...
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
2,the projector running off after only a few minutes,means the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Sep 11, 2013 | Optoma PRO250X Projector
A vertical white strip appears after few minutes.
Hi fabiano did you ever find a solution the vertical line in your RD-JT91 Multimedia OH projector. I now have the same problem. Gary
Oct 02, 2009 | LG RD-JT91 Multimedia Projector
Projectors
The color wheel sensor is bad.
Jan 18, 2009 | HP VP6310 Multimedia Projector
Loss of picture
Yes, it is the projector.
Take the filter out and vaccum it, take the lamp out and use compressed air to clean the dust away.
Be carefull witt the air thoug! keep it a bit away from the projector when u cleand the dust away, to close and you can make big mamages inside it.
And, remeber to keep the filter as cleas as possible, i clean min every 2,5-3 monthes.
Good luck
Dec 06, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Flashing red light
sounds like a flaky power supply or lamp ballast
Jun 01, 2008 | Radio Shack Cinego D-1000 Multimedia...
Lamp off
Hi there
Your Projector is overheating , check if all the fans are running.
I can almost guarantee you that one of the fans is faulty !
Mar 23, 2008 | HP Digital Projector Vp6120 Multimedia...
InFocus LP280 problem
Hi there
I'm afraid this might be a faulty Mainboard.
Your lamp will never make the Projector show funny stuff on the image.
Must warn you that a new Mainbaord is quite expensive
Mar 11, 2008 | InFocus Lamp Projector Lamp for LP240 [...
Projector Colour Problem
Could be a few things....first you need to isolate a signal source issue or a faulty LED lamp. Simply unplug your signal source and run the menus on the projector. Purple Gone with source unplugged = faulty source our signal Purple still there = faulty device Sounds crazy but make sure you have no interference devices running real close within say 2 feet. cell phone, microwave, magnets, high voltage eletricity...etc
Jun 06, 2007 | Offspring Technologies C5YP-BIN-25 25...
HP VP6310 Multimedia Projector Logo
166 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
