Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool ultimate care 2 washer wont start unless reset by pulling power
Clothes also seem very wet when done
  • Whirlpool Master
  • 17,130 Answers
Possible error within the processor or memory and so it seems to hang at times.
remove the controller and check for loose joints, clean and reset before the controller can be suspected.
Posted on Dec 31, 2012
IFIXALL
  • 868 Answers
SOURCE: whirlpool ultimate care 2 washer wont spin
Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
Posted on May 21, 2008
reg501
  • 413 Answers
SOURCE: Whirlpool Ultimate Care II washer won't spin clothes more dry than soggy
Tip the washer backward, inspect the bottom of the gearcase for oil. If oil is present, the oil has migrated to the clutch causing it to slip during spin. The gearcase and clutch will have to be replaced if oil is present. Check the owners manual for limited warranty on the gearcase. If oil is not present, the clutch is just worn and should be replaced.
Posted on Oct 05, 2008
mumma_1
  • 903 Answers
SOURCE: excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Posted on Nov 05, 2008
  • 360 Answers
SOURCE: I need to find out how old is my Whirlpool Washer Ultimate Care 2
The copyright on the owners manual is 2003.
Here is a -->link<-- to download the manual if you would like.
Please take the time to give this solution a fix ya rating.
clarkco
Posted on Feb 10, 2009
  • 13 Answers
SOURCE: washer will not high spin
It sounds like a set of clutches would fix it. If not clutches...transmission. :(
Posted on Feb 27, 2009
Clothes still wet after spin
it is normal for clothes to be a bit wet after spin.approximately about 80 percent of your clothes will be dry after spin. you may hang your clothes to completely dry or place it inside a drier machine
Sep 03, 2015 | Maytag Bravos 3.8 Cu. Ft. Washer
Samsung WA422PRHDWR not filling with enough water
I find that some of my clothes don't seem to get wet enough to clean them properly. I like to use the pre-wash cycle to wet everything thoroughly then the machine goes through the normal wash cycle and it seems to do a better job. Just an idea.
Dec 08, 2012 | Samsung WA422PRHDWR
When the wash is done the clothes are sopping wet. I tried putting fewer clothes in and they are still very wet. Checked the drain hose for a kink and it seems to be fine.
motor coupler-to test restart the washer in it's spin cycle, let the washing machine run for one minute, then open the lid and check to see if the tub is spinning. if it's spinning the coupler is fine. if it is not then the coupler needs to be replaced, can be purchased at any appliance parts store. good luck!
Jan 04, 2011 | Kenmore Energy Star 44092 Front Load...
Its a halo reach game.. it will play all the introductions..but will not allow the game to appear to play..we have cleaned the game well and has no scratches on it..what can we do
If your disk is unreadable, skipping, or is slow in playback, it may just be be dirty. Even if your disk has a few scratches, a little bit of cleaning may be all it takes to make it good as new.
Required tools:
  • Microfiber Cloth
  • 85% Rubbing Alcohol
Process:
(1) Get a nice clean cloth, preferably a micro fiber cloth. Silk should also work fine. Avoid using a Kleenex, paper towel, or cotton cloth, as it may scratch your disk. Micro fiber clothes are available at most grocery stores, but if you can't find one, pick one up at any place that sells glasses.
Rubbing alcohol can be obtained at any pharmacy and 75% should still work fine. The higher concentration does work a little better, but the difference isn't substantial. Don't substitute rubbing alcohol with Windex or other solvents, as they may damage the reflective coating on the disk.
(2) Wet the cloth at one edge with rubbing alcohol. This is best achieved by plugging up one end of the alcohol bottle with a part of the cloth, flipping the bottle over, and letting the cloth soak for a bit before flipping it back over. If done properly there, shouldn't be much alcohol spilled.
(3) Hold the disk firmly in one hand in-between your thumb and middle finger. Use the thumb of your other hand to apply pressure though the wet area of the cloth to the disk and move the cloth in and out from the center of the disk to the edge and back again. Use the index finger of the hand you are holding the disc with to support the non data side so you can apply more pressure. It may take a few tries to find a comfortable position. Continue to work the wet cloth out from the center of the disk toward the edges until you're satisfied, or until you find a spot you can't seem to get.
If you find a particularly bad spot that has a lot of dirt or grime that you just can't seem get, try getting it wet by re-wetting the cloth and allowing the area to absorb the alcohol. If that still doesn't help, apply more pressure by using the tip of your thumb or your nail on the cloth when you're rubbing the area. Be careful when using your nail as, you may cut through the fibers of the cloth and end up scratching the disk. You should never touch the data side of the disk with anything except the micro fiber cloth.
(4) Once you've finished with the wet part of the cloth, use the dry part of it. Again, use your thumb to work the cloth in and out from the center to the disk to the edge. This is mostly cosmetic and you can skip this step.
(5) Allow the disk to dry for one to two minutes and you should be done.
Nov 21, 2010 | Microsoft Xbox 360 Console
Xbox360 not reading disc and continues to open
Disk cleaning
Required tools:
  • Microfiber Cloth
Process:
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Soaking wet clothes
Burly Bob,
Is this the same model as listed by the previous poster? If so, does the washer ATTEMPT to go into the spin cycle? That is, does the timer advance to spin cycle properly, and can you hear the transmission or drive motor engage?
May 31, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
119 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
