Roper #ras8245eq1 leaks during spin cycles
Leaks during spin cycles
  • Washing Mach... Master
  • 17,129 Answers
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and removal:
Posted on Dec 31, 2012
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
vest6
  • 196 Answers
SOURCE: Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Posted on Jan 12, 2008
Lumpy816
  • 246 Answers
SOURCE: Roper Washing machine model #
Great question, here is your answer. You have to open the console (usually 2 screws in the front or back where the console meets the top of the washer) Pull the bottom of the console towards you and swing it up. Remove the 2 brass colored clips underneath by pushing down with a large screwdriver at the point where it goes into the top of the machine and press down while simultaniously pushing towards the rear. Now there will be a connector with a white, green and gray wires in it. Unplug this connector. Now tilt the top of the washer towards you (the top, front and sides all come off as one assembly) The washer will fill with water, but you will not be able to drain it unless you install a wire between the white and gray wires on the machine side. ( I would do this with the unit un-plugged and make sure you have a good connection by spinning it before you add any water. Likely the leak will be coming from the pump (white peice of plastic in the lower front with 2 black hoses going to it). If so, pry the two clips off the pump with a screw driver. Put the pump over a bowl to catch any remaining water. Squeeze the clamps on the hoses with a pair of pliers to remove them. A replacement part is availible at a local appliance part store or on line from the manufacture's web site.
Posted on Jul 11, 2008
SOURCE: Roper washer leaves clothes wet after spin cycle.
Thanks, Master Tech; I was having the same problem as Jason. When I put the pen in place, I realized that the motor was running, but the tub wasn't spinning (which I thought it was because of the sound of the motor). So, I put my hand in and gave it a push/spin and it started turning on its own after I did that.. So, I'm going to let it run and see what happens when the cycle is done. At least its a start in the right direction!
Posted on Aug 04, 2008
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
Roper washer model RAS8245EQ1 not working, buzzing noise
Her you'll find your answer..
http://www.appliancerepair.net/washing-machines-forward.html
Mar 08, 2013 | Roper Washing Machines
Washer leaks during rinse and spin cycle
What is the
model number of your unit?
May 23, 2012 | Roper Washing Machines
Model RAS8245EQ1 The washer is not spinning on the rinse cycle. I need to check to see if it is agitating during the wash. When pressing the lid switch it sounds like something is coming on but no spin.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
NOTE: Your washer is manufactured by Whirpool and has Whirlpool parts. So, these instructions will apply.
Aug 10, 2009 | Roper RAS8445KQ Top Load Washer
Only spin cycle
Check the lid switch, it only locks out the spin cycle.
eric
Jun 30, 2009 | Roper RAS8445KQ Top Load Washer
Washer stops after wash cycle. Won't empty water, won't spin.
the lid switch is defective or the lid or door screws on left & right side are loose tighten and or replace. nbcrca:)
Apr 11, 2009 | Roper RAS8244KQ Top Load Washer
I have a top load Roper washer that won't spin.Any ideas?
That sounds like a bad drum bearing, check and eventually replace the drum bearing.
Dec 28, 2008 | Roper RAS8445KQ Top Load Washer
Washer will not spin, during rinse & I'm assuming spin cycle
throw pin in trash..shipping pin..spin problem..if motr runs and unit agitates suspect transmission or clutch on top of transmission
Nov 27, 2008 | Roper RAX4233PQ Top Load Washer
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
