Question about Whirlpool Dishwashers
Whirlpool dishwasher du84ocwdb5
Im replacing my kenmoor dishwasher to the whirlpool, how do I match the wiring. The kenmoor has white, black and green and the whirlpool doesn't have the green.
  • 34 Answers
SOURCE: I am installing a dishwasher.
If you have a volt/ohm meter you can check for Power on the Blue wire. Or you can open the face of your fuse box and look to make sure the Blue wire is connected to the fuse. If it is, just hook up your Black from dishwasher to the blue from house. White to White ( Neutral). There is no real way to ground the dishwasher if your house wiring is a 2 wire (old) system. You shouldn't have a shock hazard if the wires are in the junction box for the dishwasher.
Bill
Posted on Jun 22, 2008
  • 140 Answers
SOURCE: new install; where to hook up old wiring/plug to ASKO
There should be an installers/repair guide folded up behind the front panel. Check for that as it will show a wireing diagram. I won't be able to get any info until Jan 2. Let me know what you find.
Posted on Jan 01, 2009
  • 188 Answers
SOURCE: Kenmore dishwasher power cord.
The green is the ground wire. Attach it to the screw inside the junction box.
Posted on Feb 20, 2009
Krazytech
  • 725 Answers
SOURCE: I am installing a Kenmore
next step to check the door switch...the door must close and the switches on the door must close to send power to the control...let me know
Posted on Sep 19, 2009
jsrock516
  • 5911 Answers
SOURCE: We purchased a white Whirlpool Gold Quiet Partner need it black
You can purchase door panels to replace the existing one to match your other appliances. The part number for a BLACK panel is W10073200. The cheapest I found the panel listed was appliancepartspros.com for about $96. Only you can decide whether or not the cost is too much. I hope this helps you.
Posted on Jan 06, 2010
Testimonial: "Not only did I get the answer I was hoping for, I got a part number, a supplier and what I think is a reasonable cost. Thank you very much!!"
Both the motors for my Defy Twinmaid 920 is not working,the replacement motors has black,green and red wires while the original motor has black,blue and white wires,how do I match the wires?
Black is universal. I would substitute the green and red wires for blue and white. Also notice the location that the original wires are coming from and then match the location up with that on the new motor wires.
Mar 20, 2016 | Heating & Cooling
LG Dishwasher Wiring issue
Yes the green goes to your bare copper wire, it is the ground. Black to black and white to white.
Jul 17, 2012 | LG LDF6920ST Stainless Steel 24 in....
How can I change the electrical connection? It has four wires. One white, one black, one green and one red. Where do I connect them?
On the back of the dryer where the plug wires in you'll see 3 screws. The white and green wires go together in the middle. look at the left and right screws and you'll see wires connecting to them from inside the dryer. just match the wires, put the black on the black and the red on the red.
Oct 31, 2010 | Whirlpool LER4634J Electric Dryer
My dishwasher did not come with power cord. what kind of cord do it need and how do i connect the cord? On the new cord how will i know which one to connect to the white and black wire? The dishwasher is...
120 Volt 16 gauge, 3 wire power cord.
Brass Screw is Black, White Screw is is Common, Green is Ground....Try Home Deport for a cord. If no screws are on the dishwasher, use wire nuts and elec. tape
Jun 13, 2010 | Whirlpool 24 in. DU930PWP Built-in...
There are cut wires and no cord for the second hand dishwasher i purchased and I need to find out what wires I am connecting and where
There should be a small junction box under the dishwasher behind the front toe panel. There should be three wires:
BLACK - HOT (120VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - GROUND
You can purchase a three conductor power cord from any hardware store. A 3-prong power tool power cord works the best, as they have a durable outer sheathing and have good current handling properties.
Simply match the corresponding colors (black to black, white to white) and ground the green wire to the chassis. There should be a ground lug somewhere to connect it to.
Use wire lugs when splicing wires together and use the wire strain relief (if equipped) on the junction box. The strain relief is located at the point where the wire enters the junction box and keeps the wires from inadvertently being pulled.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 29, 2010 | Maytag 24 in. MDB5601AWS Stainless Steel...
The power cord on my Whirlpool washing machine is not connected. There are 4 cables (red, black, white, and green). I can see where the black, white, and red, but where does the green one go? There is...
The following link explains how to correctly install a power cord on your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
The main difference between the 3-wire and 4-wire configuration is how the Neutral (WHITE) wire and Ground (GREEN or BARE COPPER) wire are terminated on the terminal block in the back of the dryer:
- In a 4-wire configuration, these two wires are INDEPENDENT of each other and are terminated separately.
Terminate the wires at the terminal block by matching the corresponding colors:
RED to RED (HOT) 120VAC
BLACK to BLACK (HOT) 120VAC
WHITE to WHITE (Neutral) 0VAC
GREEN (Ground) - attached to a ground lug that grounds it to the equipment cabinet.
If you have any questions, please let me know. I hope this helps you
Dec 24, 2009 | Washing Machines
I have a whirlpool dryer ler5624bwo it is zaping us how is the plug wired to the back i think maybe some one switched the black or red power for the white neutral the plug is a 4 wire 2 rectangular on...
Black and red go to the outside terminals, white goes to the middle, and green goes to the frame of the machine.  You can look up at the wires coming down to the plug terminal and match up the colors.  Your ground is green and goes to the frame of the machine.  Green is the wire that is supposed to pop the breaker and prevent you from getting shocked so make sure you hook it up to the frame.
Oct 24, 2009 | Whirlpool LER5636P Electric Dryer
What wire colors match up for hooking up LG dishwasher?
white to white
green to green or bare
red or black to the red or black from the house wiring.
Oct 24, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
Dishwashers Logo
49 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
