Question about Weiser Lock Powerbolt 1000 Lock
I have to wiggle the key on a wiser dead bolt in order for it to unlock
Have to wiggle the key in order to unlock the dead bolt
  • Raymong Dec 30, 2012
Locks don't unlock with fob or key
Check that license plate...
If it checks... think dead battery... and try CALMLY re-inserting your key... gently wiggling to see if you get some lateral motion.
It is not IMPOSSIBLE to have picked up the WRONG KEY... try getting that OTHER key and attempting entry again.
Then call out the AUTOCLUB... roadside assistance.
Jan 08, 2016 | 2010 Chevrolet HHR
Key won't turn past lock position. Tried wiggling it with the wheel, but the wheel was not locked until I jiggled it to hard. Now I can't unlock wheel because key won't even turn enough and key just won't...
Squirt WD40 into key hole and try again. Do not worry it wont affect wiring.
If still bad you have to drill out the bolts holding the keyswitch on, as soon as its off, its not locked. Bikers often have to do this and there are tools and tips you can use to do it with minimum fuss.
Dec 15, 2013 | Nissan Maxima Cars & Trucks
Key won't turn, won't shift from Park
My 2003 Saturn l200 2.2 ecotec did this when the battery was dead. Put some juice on the battery, then the car came out of park, and I was able to remove the key. To the car, there's a vast difference between a sluggish battery and a dead battery. It may have enough amps to crank it, but it wont start w/out full output from the battery.
Apr 12, 2013 | 2004 Chevrolet Cavalier
The key has to be wiggled before the dead bolt will work
Try a little WD 40 and spray it into the lock to lubricate it. and then try using your key to work the lock
Dec 30, 2012 | Locks & Locksmithing
1997 VW Jetta, battery went dead now I'm trying to charge it but the alarm doesn't want to stop... the catch is that both lock on the car are broken. I did take the drivers door panel apart and found the...
First, try to disable the alarm using the key in the truck lock. If that doesn't work....
You should be able to pull the lock cylinder out of the handle using the key. Insert the key, then gently twist and pull. Once the lock cyl is out, be careful when you remove the key in order to keep the keying blades in the right order. Once out, do whatever you can to knock the remainder of the lock cylinder mechanism loose, use a very narrow screwdriver or the like, and keep going until you can look through the hole with a flashlight and see a slot in a white plastic circular piece. Then use a flat head screwdriver to unlock the door, after the battery has been reconnected.
The parts to fix the lock cylinder are cheap, and well worth replacing. The door handle is held in place by a single bolt, should be a t30 torx. Remove the bolt then work the handle loose.
It will be difficult to reassemble corrrectly without having done it previously but you may be able to find images on the internet to help you.
Jan 09, 2011 | 1997 Volkswagen Jetta
Where do you hook cables to jump start
A lot of people will tell you to hook the good car with the negative on a bolt for ground, I have never had luck with that, never had luck with hooking either car to a bolt, always went right to the battery, hot to hot, neg to neg, If there is no connection, wiggle the cables while turning the key, It should catch. Make sure the donor car is running or you will have 2 dead batteries. Check the water in the dead battery, I have seen them come back to life with just water added. Hope this helps.
Dec 21, 2010 | Dodge Avenger Cars & Trucks
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
Troybilt riding lawnmower - won't start
i have a troy built riding mower, just replaced battery, when i turn key sounds like battery is dead. what could be the problem?
Aug 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Dead battery on bmw 740i how to unlock the doors
Cant tell you there is a premium if I share this info with you
Dec 26, 2008 | 2006 BMW 750Li
Weiser Lock Powerbolt 1000 Lock Logo
35 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
