Question about Kenwood KDC-319 CD Player
Need a wire harness plug for a kdc319
Plug is not with the receiver need to replace or wire diagram so I can hook up so I can use it
    President:
  • 720 Answers
Kenwood adapter looms are readily available from your local Auto Accessory store, of from Ebay.
These are a 'plug & play' solution (pre-wired), which eliminates the need to cut any of your existing vehicle's wiring.
Ideally, you want a single adapter loom with Kenwood plug on one end, with your vehicle's "factory" plug on the other (all common brands are available).
e.g. Kenwood ---> Ford; Kenwood ---> GM etc etc
Cheers,
Posted on Mar 14, 2013
Duncan
  • 218 Answers
SOURCE: wiring harness in back missing a couple of wires
If you could tell how many pins per row on the connector at back then I might be able to help you out.
Posted on Sep 17, 2007
mixmaster
  • 626 Answers
SOURCE: Need to know how to wire plug to speakers and power
Users manual is located here;
http://inform3.kenwoodusa.com/manuals%5Ckdc5005.pdf
Best of Luck.
Posted on Oct 27, 2007
ginko
  • 19396 Answers
SOURCE: no sound.
The first thing you need to do is doublechecking all the new wirings, it sounds like a contact.
Posted on Oct 24, 2008
pctech1
  • 1940 Answers
SOURCE: hooking up a kenwood mp235
Blue/White - Power Control/Motor Antenna Control Wire
Brown - TEL Mute Wire
Blue - ANT. Cont. (Not Used)
White/Black - Front Left Speaker -
White - Front Left Speaker +
Gray/Black - Front Right Speaker -
Gray - Front Right Speaker +
Green/Black - Rear Left Speaker -
Green - Rear Left Speaker +
Purple/Black - Rear Right Speaker -
Purple - Rear Right Speaker +
Red - Ignition Wire (Switched +)
Yellow - Battery Wire (Continuous +)
Black - Ground Wire -
Here is a copy of the User Manual:
http://www.masterspas.com/manuals_av/Kenwood_KDC-MP2035.pdf
Posted on Jul 23, 2010
Testimonial: "Thanks."
  • 12 Answers
SOURCE: i have a kenwood krc-12 cassette receiver to hook
it costs 12 bucks for the plug and wiring harness at wall mart for chryler/ jeep.with the wiring harness instructions are on or in the package.u will need the plug if you are useing the factory speakers and factory wiring in jeep for power.if not just copy the instructions off the package.it will give you all you need to know,just match them up.and you should be all set/MAKE SURE YOU RECHECK ALL WIRING 2 OR 3 TIMES BEFORE PLUGING IN.
Posted on Dec 22, 2010
I aquired Bose Acoustimass 15 surround sound through home purchase. Hooked wires up to reciever and hdmi to tv and i got nothing. my question is, how do you turn on the sub? just plug it in?
Hey Any chance you have the Acoustimass 15 II or III? The first Acoustimass 15 has a switch. The II and II models turn off and on when it receives a signal from the source you are using. Amplifier, ect. All you need to do is make sure everything hooked up correctly and plug it in.
Aug 02, 2014 | Bose Acoustimass 15 System
Need wiring diagram fo 1994 nissan quest gxe premium stereo
A picture requires an installation, which is what you are doing. You should invest in a vehicle specific wiring harness. The wiring colors match for the connection and said harness then plug into the factory harness. If the factory harness no longer exists then you need the wiring diagram for the vehicle. You mention the vehicle has a premium stereo, the Metra part number is 70-5510. It's for an amplified system.
Aug 11, 2012 | Nissan Vehicle Parts & Accessories
I need the wiring diagram for a dual stereo model xd1225 to hook it up to a 1986 ford f150
OK, for starters, get a wiring harness made for your vehicle. All aftermarket radios have standardized wiring colors. You wiring harness will have matching colors, so it will be easy to hook up. The harness will also have the diagram of colors on the package. However, you vehicle wire colors will not match this. That's why you have the harness. You will just plug into the stock vehcile harness. You will not have to match any wires because the harness is specifically made to match your vehicle. Trust me, it's easier this way. You can find them all over, try www.crutchfiedl.com to get one if you need. Hopd this helps.
Aug 23, 2011 | Car Audio & Video
I have a kenwood krc-12 cassette receiver to hook up in my cherokee but no wiring diagram,i want to hook it up rightneed a wiring diagram.
Dec 22, 2010 | Kenwood Car Audio & Video
Install new radio ,wiring diagram of car radio harness
Easier to just use this:
http://www.crutchfield.com/p_120701782/Receiver-Wire-Harness.html?tp=2977
And then use included plug wiring diagram and receiver's wiring diagram in manual to hook 'em up. (I used crimp connectors)
Jan 18, 2010 | 1995 Geo Prizm
Need wiring harness color coded diagram for pioneer dehp6800mp.
Hello randscates,
Here's a link to the manual. The wiring color code for the supplied harness is on page 78. The diagram is rotated 90 degrees clockwise. I recommend that you download the PDF and print out the page you need.
Hope this helps.
May 16, 2009 | Pioneer DEH-P6800MP CD Player
I HAVE A 1992 FORD F-150 AND I NEED A DIAGRAM TO WIRE IT?
Do you mean plug wires? there is a diagram on the front of your truck near the radiator that tells your fireing order you read it counter clock wise and your spark plug numbers is from front looking to the back left side #1 #2 #3and #4 right side is #5 #6 #7 And #8 is your motor a 5.0 v-8?
Mar 21, 2009 | 1989 Ford F 150
Wiring harness
you should never cut the wires on your factory harness... metra and other companys have harnesses that fit your car and would provide you with a correct wire color code you need to hook up a aftermarket stereo keep that in mind but i will post the wire diagram u are looking for
Aug 08, 2008 | 2002 Honda Civic
Wireing harness
you can buy the proper harness for any vehicle at most stereo shops or even some at WalMart, but you have to hook it to the one that plugs into the radio. The colors on each harness will be identical- just match them up.
Dec 06, 2007 | Xtreme Sound WMS303 CD Player
Wire harness diagram
www.scosche.com will give you the cars wires, u may want to just by a harness adapter, cutting wires=bad
Don
Nov 21, 2007 | JVC KD-S680 CD Player
Kenwood KDC-319 CD Player Logo
206 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
