Question about Novatel Label Factory Deluxe (2098686) for PC
My new label factory deluxe 4.0, won't open zdl files from previous version label factory deluxe 2.0
Label created with Zebra Bar One V5 read in Zebra Designer
Hi Jonathan. Did you ever reach a solution? We are in same baot with over 60 Barone v5 formats to convert to SAP. Thanks in advance. Mike
Jul 04, 2012 | Zebra DESIGNER FOR MySAP BUSINESS SUITE V2
I WANT TO REFORMAT MY SAMSUNG NP-R60Y TO FACTORY SETTINGS WITHOUT THE PREVIOUS OWNERS INFORMATION BEING THERE
If you perform a Full Installation (Destructive Installation), the computer will be back to day 1, when it came from the factory.
This means the previous owner hadn't been there yet, and all of the previous owner's files do NOT exist.
This is done with either;
1) Restoration Disk:
When you receive the laptop new, and run it for the first time, a pop-up comes up asking if you would like to make a Backup.
THIS,...is the Restoration Disk.
[ Or perhaps Samsung included the Restoration Disk (CD)
Laptop manufacturers are starting to include the disk again. The reason they stopped because owners were too afraid to use it, or just lost the disk. { "Don't need this! Look out cat!" ]
2) New genuine copy of Windows:
Purchase a new genuine copy of Windows, and install it.
ALL previous files (Info) will be gone.
[ Microsoft makes one Master disk. From it all GENUINE copies are made, and sold to the consumer.
IF, you are installing the SAME version of Windows that is on the laptop, you need to go into BIOS Setup, and in Boot Order, set the first boot device to CDROM ]
Regards,
joecoolvette
Apr 29, 2012 | Samsung Computers & Internet
I just got a new computer with Windows &, when I tried to install my Label Factory Deluxe it said it was not compatible with the software version. Can you help?
That version was not designed for Windows 7 or 64bit operating systems. As to what to do with the discs, that is up to you. The only thing I can suggest is that if you need to use that version of the program, you will need to install it on one of its supported operating systems.
In regards to an upgrade, there is no "upgrade" for that program. There is a newer version of the program. However, it is a full program and not an upgrade for any prior version. So, it does not require the prior version to be installed in order to install the new version.
I have not seen any problems opening the prior version's files in the newer version. The only thing that may need to be done is re-map fields if you created a database in the program.
You should be able to purchase the newest version of Label Factory from the Nova Development site or at various retailers.
Hope this answers all your questions Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya
Aug 16, 2011 | Computers & Internet
I am currently using both Print Shop 5.0 Premier and Print Shop 10. I am switching to a new computer with Windows 7 and will need to install Print Shop 23 Deluxe. Will I be able to retrieve all the files...
I will advice you to locate the print-shop folders that are on your computer. or simple open one of the files you created with this software and right click file location. it will open where all the other files are stored on your computer. backup everything stored on your computer to a flash drive.
Let me know if this solution helps.
May 14, 2011 | Encore The Print Shop 23 Deluxe Full...
I have bought Greeting Card factory deluxe version 8. i have deleted the version i had before but when i try to install it it says i cant as i have previous one. i do not and now find i am without any...
download the uninstaller program for the internet. it will clear out all the system files of the previous version then try installing the new version. next time uninstall the program don't delete it.
Apr 22, 2011 | Computers & Internet
I cannot download my version onwindows 7
here is the newest version.....the older version you are using is outdated or installed incorrectly. by download i am assuming you mean install. so here is the link to get the new version:
http://www.novadevelopment.com/software/label-factory-deluxe-129006?meta=software&cat=print-creativity-software&sub=desktop-publishing-software
If you have any problems let me know and please leave positive feedback for me. Jethro
Feb 03, 2011 | Nova Development Art Explosion Label...
I have used Quickverse VErsion 7 Deluxe for years on previous laptops using Windows 98 and Windows XP. However, I have installed it on my new laptop using Vista 32 bit and if I right click on the desk
From their website
Question 1:
Can QuickVerse 2007 run on Windows Vista?
Answer: Configure QuickVerse 2007 for Microsoft Vista Compatibility Mode
  1. Download and install the latest Maintenance Release
    Browse to the Program Files folder for QuickVerse 2007
  2. Configure Compatibility Mode for these 2 files:
    C:\Program Files\QuickVerse 2007\qv11.exe
    C:\Program Files\QuickVerse 2007\QVBookManager.exe
  3. Right-click each file listed above and select Properties on the Menu
  4. Click on the Compatibility tab and make the following selections for both files listed above:
http://www.quickverse.com/Shopfiles/Faq.asp?ID=QV2007WIN
Apr 23, 2009 | Computers & Internet
Problem installing,deluxe version 7,greeting card
insert disk
click on MYCOMPUTER and then RIGHT-CLICK on the drive and then click or EXPLORE
This should open a folder for the disk. somewhere in there should be an EXE file with SETUP in the title.
if the folder doesn't display the contents you may have a bad disk
if it does and you cant find a setup program let me know.
is this the only disk you have had trouble with lately?
Dec 26, 2008 | Nova Development Art Explosion Greeting...
Novatel Label Factory Deluxe (2098686) for PC Logo
219 people viewed this question
Top Novatel Computers & Internet Experts
ray gallant
Chris
Are you a Novatel Computer and Internet Expert? Answer questions, earn points and help others
