Question about Water Heaters
Site Gauge for 1927 American Radiator Co. Coal Furnace
I have a 1927 American Radiator Company Capitol Winchester Gravity Steam Coal furnace which has been converted to oil.
I am in search of a replacement glass site gauge. The gauge is 7.5 inches long.
I posted under plumbing / water heaters for lack of a better cat.
  • PaPa Dom
    PaPa Dom Jan 21, 2009
    Thank you all fixed!!!
    President:
  • 2,692 Answers
This is a common glass available at most boiler parts supply places.  You may also be able to find the glass at an exclusive  plumbing supply store.
Posted on Jan 19, 2009
What size fresh air vent do I need in a boiler room with a gas boiler and gas hot water heater with about 220,000 btu combined
I suggest that you run a duct that is 3 inches larger than the furnace duct . and you should run it down close to the floor and aim it in the direction of the furnace. this will trap warm air above the vent and supply an adequate supply of air for combustion. also make sure you have insulated any pipes in the furnace room that carry water or steam you want heat where you live, not going up the chimney.
Aug 02, 2014 | Water Heaters
How do i get even heat thru out the house with a daka wood stove
http://www.hearth.com/talk/categories/main-hearth-forums.4/
You burn wood, and smoke goes up flueway.
You're not running chimney smoke through ductwork so you have a heat exchanger.
What kind of heat exchanger?
probably air since you're running through ductwork?
How much hot air or hot water is coming off heat exchanger?
How big of a space can be heated with that amount of heat?
Is the exchanger located in optimal location?
Considerations.
One room log cabin with fireplace will not stay very warm.
One room house with big wood burning stove in center, with hot flue pipe running across the room and exiting on far wall, will get warm-hot, but will cool off fast.
Why?
Because the BTU output of firewood is much less than electric, coal, oil, or gas.
Otherwise they would have made wood-burning steam locomotives. But the locomotive boiler cannot get hot enough with wood ... the boiler needs coal to produce enough BTUs to boil water fast enough to rotate the turbine and turn the wheels.
Maybe your wood stove output should be measured.
Don't forget a huge percentage of fire heat goes straight up flueway.
Mar 16, 2013 | Lux Tx500 Series Smart Temp Electronic...
I need the diagram american heat adk-3 6.4
You want wiring diagram? With recommended wire size?
This particular water heater is direct-wired into a wall box, and appears to be 240Volt 6500 watts. Connect water heater to 40 amp breaker and 8 gauge wire.
Look at nameplate on device for amp and wattage rating to confirm exact power requirement.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Or a general part illustration?
http://waterheatertimer.org/images/American-ADK-3-parts.jpg
Contact American Heat. 888-818-4328
Their support button and link to product manuals and literature seems rather null date 10-14-12 which could indicate a company in transition.
There is email form
http://americanheatus.com/index.php/contacts/
American Heat is NOT same company as American water heater company.
Oct 14, 2012 | American Heat ADK-3 - Electric 6.4KW...
When the hot water heater is running water leaks from the chimney. the pipe from the heater to the chimney is dry upon removal. about 3 gals. of water leaks from the chimney with two showers.
If I understand correctly, your Bock gas water heater vent is causing water to leak down into chimney.
This is a very serious concern
Water leaking from water heater flue indicates improper venting.
The hot air gasses from water heater combustion contain water vapor, but the gas should vent out of house before condensate forms on pipes.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#flue
The problem might be caused by a power vented furnace that pushes vent air from furnace down into flue pipe for water heater. As a result, the water heater doesn't vent properly.
There could also be a clog.
Light a match under water heater draft hood and see if smoke from match travels instantly upward.
There are two major concerns.
1) If vent is not working, it means that odorless CO gas is entering home instead of venting outdoors.
CO carbon monoxide is deadly poison.
http://en.wikipedia.org/wiki/CO_poisoning
You can buy CO detector after vent is repaired.
2) Water condensate will eventually rust away vent pipes because of acidic content of the combustion vapor. It can be expensive to replace pipes, and pipes with holes pose risk of CO poisoning.
My suggestion is call a qualified plumber ASAP and explain what you observe.
Plumber will want to inspect the vent pipes, and may want to extend water heater vent pipe up further inside chimney so furnace is not pushing air back into water heater vent.
Plumber may also find blockage somewhere in the vent stack or chimney.
Also post on a professional water heater forum like the Tank to double check anything the plumber says to you. These are the pros.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Dec 25, 2010 | RTO Bock Water Heaters 32E 32 gal 104,000...
Furnace does not work
Is there a booster motor for the burner? I have seen these stick and make a furnace not turn on. The thermostat trips and you hear the furnace click on but nothing else happens. The booster is a small electric motor connected to a small duct. Take the booster motor loose and turn the fan by hand. Usually they will start working after you do this. Make sure furnace is shut off when you do this. Some booster motors have ports to oil them also.
Dec 09, 2009 | Calvin Klein The Field Controls Company...
Furnace locks out because of twinning polarity
Usually a polarity problem is fixed by reversing the wires that run to the power supply to the unit.First, shut off the breaker that feeds power to the furnace. Most of the time, there will be one black, and one white Unhook those, switch the wires around, use new wire nuts to wire them back together. Hope this helps.
Nov 08, 2009 | American Standard 40 G Natural Gas Water...
Amtrol water heater WH-7P gets barely warm water
From what you are saying it sounds like an issue with either a circulator pump or a zone valve. It depends on what type of system you have ... if you have a circulator pump that only runs the Amtrol then that is probably bad. If you have a zone valve system then it is probably the zone valve if you still have heat for the rest of the house. If you have no space heating then it is probably the circulator pump.
Nov 04, 2009 | Water Heaters
Water Heaters Logo
420 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
