Question about Samsung BD-E5900 Smart-3D Blu-ray Player
How unlock region codes on a U.S. model samsung bd-e5900
  • Lynn Miller Dec 30, 2012
    I have tried numerous searches on the web nothing is working as they all use the AK59-00148A remote with the repeat button. I have the AK59-00145A remote with no repeat button. Any suggestions?
  • kourouloutou
    kourouloutou Feb 27, 2013
    Hi Lynn, I have the same problem than you. Did you manage to do it?
If you have an Android phone (maybe it has to be Samsung, I'm not sure) download the Samsung remote App from the Play Store.
There you have the REPEAT button! I used the phone only to push the repeat button and the rest with the 'physical' remote, otherwise you have to slide the screen to get to the number button and may run out of time.
I worked!! Now I have a (DVD) region-free player!
Posted on Apr 19, 2013
  • Evonne Brooks
    Evonne Brooks Dec 30, 2013
    what app did you use as I have looked for one that has the repeat button for my blu-ray player and can't find 1
I have just checked the physical layout of the US remote compared to my Aus/NZ model. They look almost identical, except for the button on mine named REPEAT..and on yours named HUB. This is the button immediately below the PAUSE button. Why don't you try the following HACK (which definitely worked me)..but push your HUB button instead of the REPEAT.?. It may work...fingers x'ed. 1. Ensure that there is no disk in the tray. 2. Switch the player off and then back on. This is necessary to clean-boot the firmware. 3. Wait until the main menu page appears and the player stops doing anything. 4. Press the eject button to open the tray. (The button is between the "Power" and "TV Power" buttons at the top of the controller.) 5. Press the eject button to close the tray. 6. Wait while the player searches for a disk. 7. As soon as the "No Disk" message appears at the top right corner do the following. 8. Press the REPEAT button - just above the TV channel selector at the bottom right of the controller. 9. Enter 76884 on the number pad. This is The Code If You Have A Region 4 Player (Other Region Codes Given Below) 10. The region code "4" should appear at the top right corner of the screen.(this just flashed on then off, so keep an eye on the screen) 11. If you see "4" over the top right corner, quickly enter "9" to make the player region free. 12. Power down and power up again. 13. Play a foreign DVD to verify the change. Other Region Codes To Be Used In Step 9 If You Dont Have Region 2 Player Samsung Region Codes 1 - 2 9 3 3 4 2 - 5 7 5 3 8 3 - 5 6 7 3 2 4 - 7 6 8 8 4 5 - 5 3 8 1 4 6 - 2 4 4 6 2 YOu may have to try many times. YOu have limited time window to enter the numbers. As soon as you see "4" on the top right corner, quickly enter "9".
Posted on Feb 02, 2013
    Problem Solver:
Hola como hiciste a mi no me aparece nada cuando apret? bot?n stop porque no tengo repeat
Posted on Dec 08, 2014
    Problem Solver:
  • 7 Answers
THIS IS A REAL SOLUTION:
*Please translate*
Hola,soy de Mexico y yo tambien tengo un samsung bd E5900 y tengo un control que no tiene el boton 'repeat' pero lo intente con el boton stop y si funciona, es decir en lugar de usar el boton repeat usa el boton stop. :D :D
Posted on Jun 19, 2014
  • 1 more comment
  • dolores buschiazzo
    dolores buschiazzo Dec 08, 2014
    podes ayudarme gracias
  • Roberto CL
    Roberto CL Dec 15, 2014
    Mira paso a paso1. Aseg?rese de que no hay ning?n disco en la bandeja. 2. Apague el reproductor y vuelva a encenderla. Esto es necesario para limpiar-arrancar el firmware. 3. Espere hasta que la p?gina del men? principal aparece y el reproductor deja hacer nada. 4. Pulse el bot?n de expulsi?n para abrir la bandeja. (El bot?n est? entre el "Poder" y los botones "TV de alimentaci?n" en la parte superior del controlador.) 5. Pulse el bot?n de expulsi?n para cerrar la bandeja. 6. Espere a que el jugador busca un disco. 7. Tan pronto como aparezca el mensaje "No hay disco" en la esquina superior izquierda haga lo siguiente. 8. Pulse el bot?n REPEAT - justo por encima del selector de canales de televisi?n en la parte inferior derecho del controlador. 9. Introduzca 76884 en el teclado num?rico. 10. El c?digo de regi?n "4" deben aparecer en la esquina superior izquierda de la pantalla. (esto s?lo se encendi? entonces apagado, por lo que mantener un ojo en la pantalla) 11. Introduzca un "9" para hacer que la regi?n reproductor gratuito. 12. Apague y encienda de nuevo. 13. Juega un DVD externa para verificar el cambio.
  • Roberto CL
    PASO A PASO: 1. Asegurate de que no hay ning?n disco en la bandeja. 2. Apaga el reproductor y vuelve a encenderlo (Esto es necesario para limpiar-arrancar el firmware) 3. Espera hasta que la p?gina del men? principal aparece y el reproductor ya no haga nada. 4. Pulsa el bot?n de expulsi?n para abrir la bandeja. 5. Pulsa el bot?n de expulsi?n para cerrar la bandeja. 6. Espera a que el reproductor busque un disco y tan pronto como aparezca el mensaje "No hay disco" en la esquina superior izquierda pulsa el boton STOP e Introduce 76884 en el teclado num?rico.(NO APARECE NADA CUANDO APRIETAS 'STOP', SOLO PRESIONA LOS NUMEROS ENSEGUIDA) 7. El c?digo de regi?n "4" debe aparecer en la esquina superior de la pantalla y en ese instante pulsa "9" para hacer la regi?n free. 9. Apaga y enciende de nuevo el reproductor. 10. Disfruta de tu pel?cula ......NOTA: MI REPRODUCTOR CUANDO LO HICE REGION FREE DEJO DE LEER LOS BLU RAY REGION 'A', POR LO QUE PARA QUE LOS LEA LO QUE HAGO ES VOLVER EL REPRODUCTOR A REGION 4 SIGUIENDO LOS MISMOS PASOS SOLO QUE CUANDO EL APARECE EL NUMERO (AHORA 9) EN LA ESQUINA PRESIONO 4 Y LISTO, AS? QUE SOLO LO PONGO FREE (9) CUANDO VOY A VER LOS DVD'S QUE SON DE OTRA REGION. SUERTE.
Unlock region samsung
First, you need to let us know what region you are in before we give you a code. In the U.S. we are region 1. Foreign countries have different codes.
Jan 28, 2015 | Samsung BD-HM57C - BD-HM57C Wi-Fi Blu-ray...
Unlock region code for Samsung bd-f5500
The copyright protection seems to be embedded in the firmware and is tied into the whole system. I added a fan to my BD-E5900 and the extra draw of power on the board caused the copyright protection to not allow Blurays to play.
Feb 27, 2014 | Samsung Televison & Video
DOWNLOAD REGION FREE CODE FOR SAMSUNG DVD BD-E5300 PLAYER
You may get a region free code from these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Feb 15, 2013 | Samsung Blu-ray Player BD-E5300
Hello, recently purchased a Samsung BD-E5900, would it be possible to make it a region free player?
Hola soy de Mexico y tambien tuve el mismo problema mucho tiempo hasta que encontre la solucion y aqui te dejo paso a paso como hacerlo ;)
PASO A PASO: 1. Asegurate de que no hay ningun disco en la bandeja.
3. Espera hasta que la pagina del menu principal aparece y el reproductor ya no haga nada.
4. Pulsa el boton de expulsion para abrir la bandeja.
5. Pulsa el boton de expulsion para cerrar la bandeja.
6. Espera a que el reproductor busque un disco y tan pronto como aparezca el mensaje "No hay disco" en la esquina superior izquierda pulsa el boton STOP e Introduce 76884 en el teclado numerico.(NO APARECE NADA CUANDO APRIETAS 'STOP', SOLO PRESIONA LOS NUMEROS ENSEGUIDA)
7. El codigo de region "4" debe aparecer en la esquina superior de la pantalla y en ese instante pulsa "9" para hacer la region free.
8. Apaga y enciende de nuevo el reproductor.
9. Disfruta de tus peliculas :D :D :D
Sep 26, 2012 | Samsung BD-E5900 Smart-3D Blu-ray Player
Unlocking region code for samsung bd-e8500a
samsung bd-e8500a is
locking region how you
Unlocking region
Aug 08, 2012 | Samsung Bd-E8500 3D Smart Blu-Ray Disc...
How to unlock Samsung BD-E5900
Hola soy de Mexico y tambien tuve el mismo problema mucho tiempo hasta que encontre la solucien y aqui te dejo paso a paso como hacerlo ;)
Jun 04, 2012 | Samsung BD-E5900 Smart-3D Blu-ray Player
How unlock Samsung BD-E5900
If you wantto play DVDs from any region you maybe able to upgrade the firmware to make itregion free BUT if you make a mistake or installed the wrong firmware theplayer will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware (Passkey for DVD) that allows you to play DVDs from any region andPasskey for Blu-ray that allows you to play Blu-rays from any region. There areseveral available on the Internet but my favourite is DVD-Region Free From: -
www.dvdfab.com/products,free.htm
Jun 04, 2012 | Samsung BD-E5900 - 3D Blu-ray disc player...
Unlock region code for samsung bd-c6800
None of these suggestions work for the BD-C6800
Nov 13, 2011 | Samsung BD-C6800 Blu-Ray Player
Samsung BD-E5900 Smart-3D Blu-ray Player Logo
2,511 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
