Question about Whirlpool LHW0050PQ Front Load Washer
Hotpoint bwm129 washing m/c door won,t open
Got the above m/c but can,t open door! i've drained m/c but still won't open. superwash and rinse hold led's are fleshing. can anyone help would be very much appreciated.
jb
  • 121 Answers
Probably door lock-switch.
Posted on Feb 16, 2009
I have a Hotpoint BWM129 washing machine and the Delay start and Superwash lights are flashing. Can anyone explain what fault code this is? The door locked light is also on.
Manual says to unplug maching from wall for at least 40 seconds to a minute. This will reset the unit. If that does not work you will need to call a service tech.
Jan 30, 2015 | Hotpoint Bwd12, Bwd129, Bwm129 Washing...
I have a hotpoint bwm129 1200 spin and I can't drain the water out of the washing machine. I have taken out the filter as it was clogged, cleaned up but the rest of the water has not come out of the d
You should be able to drain the water out by laying the drain hose down into a bowl. Does the pump function properly on final spin, that usually clears the water to allow the door to open. Parts are obtainable from Hotpoint Spares.co.uk.
Jan 29, 2015 | Hotpoint BWM12 Front Load Washer
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Superwash button constant flashing
I do not have a solution but also have the same issue. That is when putting on a cotton programme, the superwash light comes on at the end of the programme and I am unable to open the door as it remains locked. I then have to put it to a rinse or spin cycle as it does not seem to have spun the clothes at all.
Jul 15, 2010 | Hoover H140E Front Load Washer
Hotpoint bwm129 wont finish a cycle. super wash and rinse hold lights are flashing.have checked pump for obstructions and waste pipe. any suggestions?
Have you checked the filter? even if the pump is o/k, if the filter is blocked, it will not empty..
If filter clear, then you have a more serious problem.
Hope this helps.
Dec 02, 2009 | Hotpoint BWM12 Front Load Washer
Hi my washing machine model bwm129 bearing has
Hi, most engineers would charge £90 just for the bearings. It's quite a big job.
Hope this gives ou some idea.
Sep 28, 2009 | Washing Machines
Lights flashing & door wont open
Dear RedBikeGirl
I've got a BWM129 which is causing me problems too (the washing is smelly at th eend of the cycle!) - How did you get the filter unit out of its housing, I turns around but doesn't seem to want to come out!
Any help gratefully received
Jun 01, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint bwm129 making huming noise
Sounds like the rinse water can't come. Maybe the solenoid for cold water got stuck or a water filter needs cleaning? If the humming is louder, perhaps the drum motor (or drum) needs a little care or cleaning.
If all else fails, download the user manual and check the trouble checklist index. (Or; try learning your kenpo succession move sparring against laundry to clean it.)
Apr 14, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint Aquarius WT540
Sounds like the water pump is plugged with something. The pump could also just be locked up. The smell is probably the belt slipping on the pulley. To drain the unit you will need to lower the drain hose into a bucket and let it drain that way. Most pumps can be opened and cleaned. It will be inside and attached to the drain hose. It has a pulley on it where the belt rides. If it has a clamp holding the bottom on remove it and the clog. You may be able to do this without removing it from the unit. Let me know if you need further help.
Feb 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint bwm129 lights flashing
What mode are you starting this machine in ? I know this may sound silly and I'm trying to determe if this is a machine fault code or something else.
Dec 30, 2007 | Hotpoint BWM12 Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
423 people viewed this question
Dan Webster
Dan Webster
Sal De
