My acoustic solution 19" lcd/dvd combo . ASTVD-31199-S2-ID-HD. When i put tv into auto-tune , before it ended completion, screen went blank, the led light continually flashing. no response with remote
I got two of these tv's which i tried to auto-tune,both just showing flashing led. i be very grateful for any advice/solution, thank you. john.
3 Suggested Answers
gopakumarg43
  • 74459 Answers
SOURCE: hi, I have a Acustic
Hello
When we do autotuning to any kind of TV, it automatically tunes to to the entire TV frequency spectrum, and stores each channel information in voltage forms in a memory Ic called Eraseable Programable Read Only Memory [EPROM]. In some sets, this part of the circuit mey built inside the command Ic, and in some otheres, there will be a seperate Ic used for it; called memory Ic. When we tuned in, all station iformations are converted into digital form, and stroed inside each memory positon of this Ic and will be regained when we chage each channels later.
In your TV combo, this memory section has damaged, and it doesnt store anything during tuning process.
You just open it and see whether a seperate Ic is used for this purpose or not. If it is, the things are easy, because it will be an Ic, which will have only 8 or 10pins to desoder it. it can be located very near to system control Ic. If there is no such Ic is, that means the system control Ic itself contains this portion inside, and the system control Ic itself dhould be replaced, and it will need skill and good sodering concepts. If it is an SMD [Surface Mount Type], will need special equipments to desolder it out from the circuit board, and to replace. Ok.
Posted on Nov 20, 2010
SOURCE: Acoustic Solutions astvd-31199-s2-id-hd circuit
cerco schema tv astvd 31119 s2id hd
bubefi@virgilio.it
Posted on Nov 22, 2010
Power indicator on, logo flashes briefly, but then no picture. What's wrong?
SEIKI Tv SC501TS has audio but no video, repair - YouTube
? 1:38
https://www.youtube.com/watch?v=cWpF4q_rBaw
Oct 19, 2014 - Uploaded by EurekaRecycler
SEIKI Tv SC501TS has audio but no video, repair ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
Learn why your screen is blank and you have audio - No image LED TV Repair Review Main Board Problems ...
LCD & LED TV Repair - No Image & Blank Black Screen ...
Dec 13, 2015 | SEIKI Digital Seiki SE32HY10 32 720p...
Dvd player won't read any disks and when i put the dvd cleaner in it the tv says no disk
Either its sled motor [the motor that spins the disc inside] or the laser pickup unit might be faulty. Check it.
Nov 02, 2013 | iSymphony " 19"" Class - LED - 720p - 60Hz...
Tv stop playing after thirty minutes and the picture get fussy and its make a loud popping noise. please help.
About the only simple thing you can try is disconnect set and a box if used from power for several minutes and then power all back up to see if when the units reboot the problem is there or not.
The usual repair cost on a 19 inch set will exceed the replacement cost of that set in most cases.
Dec 10, 2012 | Insignia Ns-19e450a11 19" 720p Hd Led Lcd...
19" LED TV INSIGNIA HD
I have one of the same tvs. Start by going under menu,setup,tuning band and set it up for antenna. When you get that far put in auto channel search. To see how to get best reception where you live go to http://www.antennaweb.org
Comment if you need any further help
Mar 17, 2010 | Insignia NS-LCD19 19 in. LCD TV
For i need a code to use with sony rm-vl600t tv remote control for use with an acoustic solutions astvd 3119ws 19'' hd lcd dvd combi(0.69 seconds)
I contacted sony support centre to ask for code for sony RM-VL600T remote control,
this is their reply below
I'm sorry, but there are no codes for the ASTVD LCD TV DVD COMBO. However, in some rare cases, you may not be able to operate your non-Sony equipment with the supplied Remote Commander. This is because your equipment may use a code that is not provided with this Remote Commander. In this case, please use the equipment's own remote control unit.
Thank you for understanding.
The Sony Email Response Team
C6EM
Brian
i have since learned the problem is that acoustic soultions tv are made for argos stores and are branded with their own name, therefore the modle is not registered as a tv brand to be used with universal remotes.
Oct 17, 2009 | Sony RM-TV294 Remote Control
No valid disc error
these built in tv/dvd players have this problem the laser inside tends to burn out. being unable to read discs. it may be dirty and you can try to clean it with a laser disc cleaner or by blowing the dust out with compressed air . but more than likley the laser is damged and you will have to go into a repair shop.
Apr 26, 2009 | Televison & Video
Failed power supply
Hi I have an acoustic solution 19 in tv with dvd player ASTVD - 3119 .
I can seem to get the menu off the screen it appears each time i change channel or press any button at all on the remote.can you help me please
Nov 21, 2008 | Televison & Video
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
