Question about Dryers
I have a 60 inch Miramar II Ceiling Fan model #AL60-O88. We had a dimmer switch installed by an electrician. Due to low brightness of the lights, we removed the swtich and replaced with a three way (on/off). The lights were brighter. We have tried several brands of energy saving, incandescant light bulbs (most recent 9W, 120 VAC, 60 HZ, 140 mA). This should be well within the limiters capacity, but It won't work - hums and shuts off after 30 secs. Standard 40 watt bulbs just are not bright enough. Should we replace the limiter?
  • 37 Answers
SOURCE: 40 watt just not bright enough?
60 watts could be fine and you may never have a problem, but it says 40 watts for a reason. So you don't burn your house down. See "To reduce the risk of fire....". The better option here would be to buy 23watt compact fluorescent light bulbs. They give off less heat than a 40 watt incandescent and the same light output of a 100watt incandescent. I'm guessing that you don't currently have the light on a dimmer, but if you wanted to, make sure you get cfl's that are made to be used on a dimmer.
Posted on Jan 24, 2009
  • 969 Answers
SOURCE: question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Posted on Aug 23, 2009
SOURCE: Changing light bulbs in Hampton Bay 60 in. Miramar Fan
You have to unscrew the small openings on top of the housing where the motor is to access the small nightlight bulbs.
Posted on Oct 01, 2009
rtpflh
  • 546 Answers
SOURCE: Installed a Hunter ceiling fan yesterday for a
60 watt bulbs are the maximum recommended,and can be used.if using a remote control, a slight delay is normal,compare it to the delay when turning on a TV.
Posted on Oct 12, 2009
Testimonial: "No remote was used, just a wall switch."
  • 91 Answers
SOURCE: Ceiling fan will not spin fast
in england the usual house current is 220 volts and here the current is 120volts. this explains the problem. unless there is a switch to change your fan to a 110 current built in it might make sense to buy a new fan and move on. rewiring it would be expensive and unless it has alot of sentimental value probably not worth it.
Posted on May 31, 2010
Testimonial: "Arsehole"
Hunterfan com
If you have a remote then you can't use the dimmer switch on the wall. Put in an on/off switch.
Sep 20, 2013 | Hunter 52" Ceiling Fan With Light And...
I have a Hampton Bay Miramar 60 in ceiling fan, when you try to turn it on the upper light just blinks and nothing else happens. You can't even turn the blinking light off. HELP!!!
Turn off the breaker that controls power to the fan. Remove the batteries from the remote and press the buttons in case one is stuck. Reinstall batteries or new ones. Turn on the fan breaker and try using the remote again
Dec 16, 2012 | Universal Remote Control Hampton Bay...
My remote shows 100 percent light but cannot figure out how to adjust brightness downward. Is this possible to do?
Do you have a dimmer switch in line? If not you need one and if you do check your wiring at the switch.
Oct 07, 2012 | Hampton Bay 46056 Callaway II Ceiling Fan
I have a dimmer switch installed and it wont work with the celing fan
Your question has two switches and 1 dimmer.
The fan switch works.
The light switch works.
The dimmer does not. What is the dimmer connected to?
Dimmers typically will not control fan speed unless they are rated to do that.
Do you have a 3-way switching where two switches control same light, and you installed the dimmer in place of 3-way switch?
Sep 06, 2012 | Westinghouse Contempra Trio 42" Ceiling...
Wiring ceiling fan to a light/fan dimmer swich
I think you should get a licensed electrician , if you dont wire it up correctly you could burn your house down and i dont think insurance companys take klndly to diy electrical work around the home .
Jun 05, 2009 | Leviton Decora Light Dimmer Switch
Lights aren't working normally
Most likely, there is a dimmer selection switch on the remote controller to dim the lights. The wall switch has no effect on the brightness.
Apr 30, 2009 | Heating & Cooling
Light flickers when dimmer switch isn't ''just right''
Compact fluorescent bulbs do not work on dimmers.  You have to use standard incandescent bulbs or not dim the lights.
Mar 20, 2009 | Hampton Bay 52 In. Brushed Nickel Romano...
Jan 08, 2009 | Hampton Bay 24002 Ceiling Fan
Not sure if this is the exact ceiling fan/ light kit we have... but looks similar.
Turned out that it was the dimmer switch that had shorted out.
My hubby figured it out, and replaced it.
Jul 19, 2008 | Hampton Bay 24750 Huntington III Ceiling...
2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Jan 15, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
Dryers Logo
56 people viewed this question
Top Dryers Experts
