Question about Kitchen Ranges
Crosley CE38300BAQ replace oven element
The bottom element flashed, burned and sparked. What do I need to know to replace it?
  • 8,220 Answers
The main thing you need to know is L-2 is always hot to the element. Which means you MUST unplug the power to the range to do the replacement. Yank out the bottom drawer and with any luck you will be able to unplug the stove without moving it. Once the power is disconnected use a screwdriver to remove the mounting screws as seen in this video:
Posted on Dec 30, 2012
Testimonial: "The information was very clear and concise, giving me confidence to tackle the job."
  • sedeger4664 Dec 30, 2012
    Thank-you, Dan. That was very helpful. My oven element connects on either side instead of the middle. Is the procedure the same?
  • Dan Webster
    Dan Webster Dec 31, 2012
    yep. just remember all stoves are hot to the element first through the 2nd hot wire. You will ruin the new element if it touches the stove while you are installing it if it touch AND it might fry yore asz as well. Cheers
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: RCA oven bottom heating element burned up
youd be better to leave the old elemnt in tillits replaced, the wire leading to the elemnt is ALWAYS live, even when not on there is ALWAYS power to the elemnt wire
Posted on Dec 02, 2008
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
SOURCE: Oven element started to spark
See this for description of same issue:
http://forum.doityourself.com/appliances-large-electric/255234-ge-electric-range-oven-element.html
Posted on Jan 24, 2009
  • 15 Answers
SOURCE: need part number for lower heating element in a JBP26 oven
That doesn't appear to be a complete serial number. You can go to repairclinic.com and click on repair help, or go straight to this page: http://www.repairclinic.com/0089.asp?apptype=13
to find the correct serial number.
Posted on Jul 20, 2009
Will just replacing the oven element fix my Kenmore model 911.955879range oven? It sparked, broke in two and a white flame continued going around the element, wouldn't stop I had to shut breaker off.
Hello Jennifer;
My name is peter. I am a retired field service appliance technician.
Good for you - turning off the breaker.
You have a older oven. Usually there is a spark or crack in the oven element. In your case the element was so embrittled it broke into 2 pieces.
Before you use the top range burners to be on the safe side you need to disconnect the oven element. You may have damaged the oven control board to where it is locked into power for the oven.
25713262-01ium3bsyoj5ql4fhv4kpwvp-4-0.jpg 1.) Remove the bottom drawer to reduce weight.
2.) Put a rug on the floor in front of the oven, so when you pull the oven out it does not scratch the floor.
3.) Pull the oven out so you can get behind it.
4.) Unplug the unit.
5.) Remove the back bottom cover.
6.) Disconnect the heating element and remove from oven.
7.) Rap the two loose element connections in the back with electrical tape.
8.) Follow the element loose connection to the control board at the top. Disconnect at the oven control board.
9.) Inspect the loose wiring from the control board to the heating element for burns or melting.
10.) Plug the oven back in and turn on the range burners.
The part number for the oven element is WB44T10014. Sears wants about $95.00 for this part. Search the internet for this part number and get it for about $28.00.
Your oven control board may have become damaged. Recently I replace one for a friend. Sears wanted $256.00. I got a remanufactured board over the internet for $30.00.
Get back to me and let me know what is going on.
May 25, 2015 | Kitchen Ranges
My Crosley oven has a new element and timer and still will not heat up
It sounds like you need to replace the burner receptacle, in either the broiler or the bottom oven burner( heating element) or both. When it exploded it burned the contacts in the heating element.
Apr 11, 2014 | Ovens
Dryer not getting hot
This usually indicates that the heating element is burned out. To test, unplug dryer, access back, remove at least one of the two connections to the element (looks like the element in the oven of an electric stove), and measure the electric resistance of the element - if infinite or very high, the element needs replacing.
Nov 10, 2013 | Crosley CDE6000 Electric Dryer
Electrolux E@30GS65GSD bottom oven won't heat
most likely it is a bad element easy and cheep to replace check element for burn spots on it with a flash light don't touch unless you have the power turned off , get back to me if you need a part but i will need all info on this oven
Dec 06, 2011 | Electrolux Ovens
Heating element burned out (literally!)
No you are fine...just replace the element, they will fry like that sometimes...
Check out this tip that I wrote about this problem...
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 29, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Hi i have a very old 1970? whirlpool electric single oven
It sounds like you burned out the oven heating element control board.
Jul 18, 2017 | Whirlpool Ovens
Bottom oven element sparked then quit working
The element sometimes will continue to arc inside after it burns out. It's 220 volts jumping across the break.
Mar 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Kitchen Ranges Logo
96 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
