Question about Keurig Elite B40 Coffee Maker
Coffee grounds in my Keurig B40
I have coffee grounds building up just outside the area where the pod goes in. I've poured water in to clean it out but it keeps recurring. How do I clean it without taking it all the way apart? Is there something I need to do so it doesn't happen again?
  • 1,511 Answers
Over flow from coffee Kcup due to clogged tubes. Clean as per manual.
Posted on Feb 01, 2014
  • 18 Answers
SOURCE: After cleaning/descaling my coffee maker still
If you put water in the basket, does it empty rather quickly? If it does, have you tried putting in a paper filter to help with the spillage?
Posted on Nov 24, 2009
cmccune04
  • 213 Answers
SOURCE: need parts list for ELITE B40 KEURIG coffee maker
Should be listed in your manual. If you need parts check this out.
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Posted on Apr 14, 2010
tgmusicgirl
  • 91 Answers
SOURCE: Coffee won't pass through pod
the K-cup is punctured at the top and at the bottom.
you can take a corkscrew, and puncture a number of holes in the bottom of the K-Cup... verify there is a hole at the top... just before you start to brew... press down on the black arm over the cup... but not too hard...Lets see what happens... if it all looks good... no problems... then we need to either adjust the arm... or shim the k-Cup up a little bit...
you may also check the rubber Seal around the top pin that punctures the K-cup...
sounds like you lost your rubber seal around the top of the K-cup...
you can re-phrase after looking and testing....
Posted on May 06, 2010
heatman101
  • 43501 Answers
SOURCE: My Keurig is doing the
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
heatman101
  • 43501 Answers
SOURCE: @Help.Keurig Elite B40 (I think).
heatman101
Hot water goes back into resivour.
Check that the needle under the top is clean, no coffee grounds blocking the flow of water into the K cup.
Aug 31, 2016 | Keurig Elite B40 Coffee Maker
Keurig is leaking out the back along bottom
Seal is damaged and needs replacement. Factory will di free under warranty.
Jan 31, 2013 | Keurig Elite B40 Coffee Maker
The descale light keeps blinking, what should I do?
The 'Descale' light that turns on indicates that it is time to de-scale the machine.
Scale - or mineral deposits- form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water.
You will need :
  • Keurig coffee maker
  • 48 oz. white distilled vinegar
  • Water
  • Large ceramic cup
  • Sink
Instructions :
  • 1 Unplug the coffee machine and remove the cup.
  • 2 Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
  • 3 Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
  • 4 Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
  • 5 Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
  • Good luck ;)
    Dec 14, 2011 | Keurig Elite B40 Coffee Maker
    Making only a half cup of coffee - the rest of the water seems to be pouring back into the resevoir from the vent thing.
    heatman101
    Sep 08, 2011 | Keurig Elite B40 Coffee Maker
    My keurig is brewing only alittle coffee and the rest of the water is being poured back into the water basin, at a very hot temp.
    When is the last time it was cleaned? That's usually the issue & the quickest fix. If the Keurig gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off or keep making partial cups. However, I've not heard of your particular problem with it running the heated water back into the basin. Try cleaning it & see if that reduces or eliminates your problem. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup, also remove the carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir. Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected). If this eliminates your problem, it should be done every 2-3 mths.
    If that does not work - call Keurig's Customer Service # at 1-866-901-BREW (2739) Good Luck.
    Sep 06, 2011 | Coffee Makers & Espresso Machines
    All of a sudden my mom's Keuring B40 won't make a full cup of coffee.
    Mine started to do that about a month ago. I would have to brew multiple "cups" just to fill one coffee cup. I ran several cycles of the largest cup, without any K-cups, to clean out the small metal spout. After about 3 hot-water cycles, it worked fine. I do this periodically, as I don't use the Keurig daily, so some of the residue builds up between uses.
    Aug 15, 2011 | Keurig Elite B40 Coffee Maker
    My b-40 Keurig doesn't make coffee it draws the water and despences it back into the water well. It doesn't come thru the coffee pod.
    heatman101
    Jun 05, 2011 | Keurig Elite B40 Coffee Maker
    Keurig Elite B40 Coffee Maker Logo
    Top Keurig Coffee Makers & Espresso Machines Experts
    Lisa
    Lisa
    Jason
    Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
