Question about Kenmore 20.6 cu. ft. Upright Freezer 24092
I've been offered an Imperial upright freezer. But it is not working properly. Apparently the problem is that it won't go below 35 degrees, they think is has to do with the compressor... Is it worth taking - if the repair is not exuberating. What could be wrong? I saw a used model on ebay ar. $350 working. Thank you.
    Guru:
  • 1,524 Answers
Buy the one on e-bay.
Posted on May 07, 2009
Can I lay down an Imperial Heavy Duty Upright Freezer for transport in a van or must it be upright in a pick up?
It should be upright, but if you must, after standing it up again - don't plug it in for couple of days. When it's down, oil in the pump moves quickly, but when it's upright again it takes it's time. If you plug it in too early, pump will overheats and you will need a new pump. Hope it helps.
Apr 30, 2014 | Freezers
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
May 13, 2012 | Kenmore Freezer 20.6 cu. ft. Frost Free...
Have defrosted my 210 cu.ft. upright freezer v2003rw3, do not have my manual to hand . At what setting on the dial should I put it at to start it up?
Every Refrigerator has its own "personality" There is no common
setting for any one refrigerator. I would start with 3
The real solution is what I have always told my customers
Get a refrigerator thermometer and a freezer thermometer
Refrigerator temp should be about 33-37 degrees.
Freezer should be about 0-10 degrees. below 0 is overkill
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Woods 201 cu. ft. Upright Freezer V2003RW3
My frigidaire side by side isn't cooling properly,
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 21, 2010 | Frigidaire Freezer Refrigeration White...
Running High @ -10 C and should run at -20 C on coldest setting
1. Make sure the sealing gasket is making good contact all the way around. It's pretty easy to lose 10 degrees. If it is a magnetic seal on the door gasket, it may not be sealing all the way around.
2. If it is staying that cold, everything is working well enough. Maybe you need a little gas in the compressor. Time for the service guy.
By the way, is your unit speced to be that cold full of supplies? Is the door opened frequently? minus 35 is pretty cold.
Mar 11, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Slow icecube maker
the harvest mode is started when the ice cube reaches around 14 degrees so lower the temp in the freezer or decrease the size of the cubes also make sure the fan vents in the freezer is unblocked. check the temp in the freezer should be around 0 degrees.
Dec 12, 2008 | Frigidaire Freezer Refrigeration White...
Proper temp. range in freezer
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
UP RIGHT FRIGIDAIRE FREEZER AUTO DEFROST 11CF I THINK
This could be normal for the summer. This is the right temp to keep it at. Some units are meant to run 80 - 90 % of the time. Turn it all the way up and check the temp. Most units when working properly can get below 0. Check the condensor underneath for dirt and to see if the fan is running under there. (smaller units don't have anything underneath) Some have coils in the rear and the smallest units just use the sides of the cabinet to disperse the heat. Check the gasket see if its sealing properly or maybe the door is warped and not closing at the bottom.
Jun 28, 2008 | Frigidaire 11.6 cu. ft. / 328 liter...
Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
Feb 03, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Kenmore 20.6 cu. ft. Upright Freezer 24092 Logo
272 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
