This washer machine is about 4years old it's a whirlpool model # LCE4332PQ1 and the problem that I'm having is that it's making this loud noise when it's rinsing in on the finally rinse it don't drain
    Sergeant:
  • 291 Answers
Almost sounds like a bearing going out, but that wouldn't address the no drain situation. My bet is a sock has lodged itself between your basket and tub. They usually end up covering the drain whole. Sometimes they work their way down into the hose between tub and pump. There they often work themselves against the propellers of the pump. Check that the hose is clear and pump functions correctly before attempting basket to tub disassembly. Also look really closely with flashlight at the drain holes at bottom of basket, you may be able to see it if it's between basket and tub. If you can see it try to move it towards drain hole with a straightened coat-hanger. If you can get it there i think it is just a matter of removing the hose from the tub end on your model and grabbing it with some needlenose pliers. Keep in mind i'm going from 20 sec. of video here, so i could be way off base. Hope this helps.
Posted on Dec 30, 2012
  • China Aiken Dec 30, 2012
    Thanks, I will try that soon as I get time again. Early this morning I had looked under the washer & I think I found the problem. I wasnt sure so I had contact Whirlpool online & asked for the manual. I think the problem is these 4 pipe like things on the corners I believe they are called suspension cups. When I was checking it earlier 2 of them was loose I'm thinking now that my be the problem too. I definitely appreciate all the advice I can get!!! So thanks again. I will keep ya posted when I figure it out.
Coldcut
  • 1554 Answers
SOURCE: My whirlpool duet washer indicates "5d"...
unplug.
open the bottom panel,3 screws on bottom
check the drain plug ,
remove the plug , mop up water ,
look inside for clogs ,
look above the ball,
look inside the propellers, spin the pumps propeller by hand.
reassemble.
close panel.
finally .
feel around the inside of the front rubber gasket for items.
Posted on Oct 31, 2008
  • 641 Answers
SOURCE: Washer makes loud thumping after finished spin cycle
Remove washer cabinet (easy to remove)and check that "base pads" (there are 3 pads, located under the main tub)are not worn. In case they are worn (even one of them), you should replce them all. Good luck !!
Posted on Jun 07, 2006
  • 213 Answers
SOURCE: whirlpool washing machine won't spin after rinse cycle
there is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
Posted on Nov 21, 2007
michiganfan9
  • 179 Answers
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
SOURCE: PORTABLE WASHER LCE4332PQ1
did you fix this? i have the same problem.
Posted on Jun 30, 2009
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
Aug 21, 2009 - 10 posts - ‎5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Jan 16, 2016 | Washing Machines
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Whirlpool Washer WTW4850Q1 makes loud noise during agitation cycle?
http://www.repairclinic.com/Shop-For-Parts/a11b5-x777477343835307131/Wtw4850q1-Whirlpool-Washing-Machine-Parts >Click on repair help written in blue. Its free. Hope this helped.
Jan 05, 2015 | Whirlpool Washing Machines
Front load duet whirlpool makes loud roar when it spins - no error code. Machine is only about 1 year old and just started making this noise recently
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Won't spin and loud noise
Kenmore washers could hold a few problems. First, without a model number you don't know who makes it. See, Kenmore does not make washers, they have someone else make them such as Whirlpool or Frigidaire. More that likely you have a Whirlpool (which is a good thing). What you are probably hearing is the coupler of the machine broken. A coupler is what replaced a belt in the newer machines. This piece is installed in between the motor and transmission. If it breaks it makes a loud rattle/grind sound. It is possible that the transmission is also the culprit. However, this noise is entirely different. A bad transmission generally makes a loud screech noise. If this does not help, please post a model number of the washer and I will gladly further assist you :)
May 28, 2010 | Kenmore Washing Machines
I have a whirlpool duet washer that is making very
It sounds like basket support failure. How old is the machine? They usually **** at around 5 to 6 years. Unless you are going to fix it yourself or it's under extended warranty, junk it.
The repair requires a complete teardown of the washer. two to six hours labor depending on tech skill level.
Jun 12, 2009 | Whirlpool GHW9200L Front Load Washer
Apr 06, 2009 | Whirlpool LCE4332P Top Load Washer
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
Whirlpool washer makes loud noise but aggitator doesn't even turn
a load of Jeans or pants is hardest on washing machines , you probably broke the belt for the aggitator
Dec 14, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
149 people viewed this question
Top Washing Machines Experts
