Question about Mitsubishi CS-35503 TV
Mostrar diagrama del televisor mitsubishi cs-3515r serie 543089
Para repararla no funciona
4 Suggested Answers
SOURCE: Mitsubishi CS-3515R tv problem
is locked and forgot my 4 digital code number
Posted on Sep 29, 2008
gopakumarg43
  • 74198 Answers
SOURCE: model CS-3515R, has buzzing noise, screen darkens,
There is some short in the inside circuit of your TV. Horizontal output transistor may be leakey. Replace it with a new one of same type and number. If it doesn't rectify the problem, LOT should be replaced.
Posted on Oct 16, 2010
  • 6771 Answers
SOURCE: I have a Mitsubishi CS
There are two issues, the first is a vertical deflection problem, "needs a few parts+an ic" the second problem is intermittent color, "crystal and color processor ic" If the set is close to 10 years old then your money is better spent on a new tv.
Posted on Mar 20, 2011
Diagrama o plano
Hola Gabriel,
Va ser mas barato comprar una nueva unidad, que tratar de solucionar este problema. $ 102.70
Llamame si necesitas mas ayuda con esto -- 407.380.9200
Oct 16, 2013 | Opti -UPS PowerES 650 UPS System
NECESITO EL CODIGO DE UN TELEVISOR SANYO CON UN CONTROL REMOTO DE JVC
These are the codes for Sanyo TV: 0049 0097 0110 0004 0268 0012 0108 0180
Aug 19, 2012 | RCA Universal Remote Control
Compre una Santafe 2004, usada. No tenia el ETACS. No funciona la velocidad intermitente del limpiavidrios. Compre el ETACS, fue instalado pero al parecer incorrectamente porque no funciona la velocidad...
I have the same problem few days ago and found my solution on Fixya Expert Sources website. Here you will get all the top sources of your problem. All the sources of this site provided by top Fixya Gurus. Have a good look at the sources of the page. Go through the sources to find your solution. Hope it will help.
View Count:1
Aug 12, 2011 | 2004 Hyundai Santa Fe
Met de afst bediening kan ik niet komen aan de menu van mijn tv philips
Al pulsar el bot?n de men? o en el control remoto o en el panel frontal de la TV debe mostrar pantalla del men?. Si no es as?, visita el control remoto del televisor para la emisi?n de infrarrojos. Si no dispone de emisi?n infrarroja, o el sensor de infrarrojos en el interior de la Televisi?n ha damged, contro remoto no deber?a funcionar. Compruebe estos. Aceptar
May 23, 2011 | Philips Televison & Video
Como saber el codigo para un televisor de marca tcl. de un cotrol remoto universal motorola drc800
0023, 0024, 0043, 0044, 0045
Si ninguno funciona, puedes usar la función para buscar códigos del control, para esto hay que: 1.Con el televisor encencido, mantener presionado el botón de TV por al menos 6 segundos hasta que se enciendan las luces de cada dispositivo y la luz de TV permanezca encendida. 2.Presionar POWER, la luz de TV parpadeará 3 veces y se apagará. 3.Presionar la flecha hacia arriba hasta que el televisor se apague, una vez que se apague hay que presionar OK. Al presionar OK, el control guardará el código y ahora podrá controlar el televisor.
May 04, 2011 | Motorola Mobility DRC800 Universal Remote...
Hola,tengo un yamaha portasound PSS-290 que no funciona, necesitaría el diagrama del circuito para repararlo.Gracias
Just to help I can translate this: Hello, I have a Yamaha Portasound PSS 290 which does not work. I need a circuit diagram to repair it, thank you.
Apr 16, 2010 | Music
Tengo un problema mi televisor tlx-03210b no cambia de canal
Función de cambio de canal no funciona después de la búsqueda de canales
Aug 02, 2009 | Polaroid FLM-4201 42 in. LCD Television
No funciona
Ulises,
A ver si me entendes, el televisor se ha descalibrado con el control remoto.
o por la tecla que apretaste o por algo que paso.
Para que funcione nuevamente simplemente debes volverlo a programar.
Ya se que no anda, y ya se que probaste mil veces.
Ahora empeza de nuevo y programa el control remoto como si empezaras desde cero
Para ello necesitas el codigo de tu TV para ingresarlo en el control remoto.
Los codigos normales del Silvania son 0054, 0030, 0020, 0096
Si estos numeros no funcionan dame la informacion que te pido abajo
modelo de tu Sylvania
modelo de tu y marca Remote
Oct 19, 2008 | Vehicle Parts & Accessories
Ayuda para desbloquear
buenas tardes tengo un tv modelo HTV-2115 y tiene un candado rojo en la esquina inferior izquierda el canal no lo deja de mostrar y donde deberia tener la hora aparecen las rayitas no me deja usar el control sino para apagarlo y de los botones laterales solo lo puedo apagar como puedo desbloquearlo sino me da acceso al menu ni con el control ni con el menu lateral. darme respuesta al messnger viittoria1997@hotmail.com Gracias es de Venezuela
May 24, 2008 | Televison & Video
Nececito diagrama
tienes que dar mas informacion del tipo o marca del televisor pero si quieres intentar por ti mismo solo ve a la pagina de la compania que la fabrico y ve a soppporte manuales y diagramas ahi puedes encontrar lo que buscas es igual para todo tipo de aparato solo busca la pagina del fabricante
Nov 13, 2007 | Astar LTV2001 Television
Televison & Video Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
