HP Pavilion a6152n PC Desktop Logo
cmaloof Posted on Dec 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to upgrade the processor and add second hard drive to pavilion a6152n
I have upgraded the memory, now want to add second hard drive and upgrade processor. I s this possible and cost effective or should I get a new PC ?
Lee Hodgson
Level 3:
  • HP Master 4,810 Answers
  • Posted on Dec 31, 2012
Lee Hodgson
HP Master
Level 3:
Answers
4810
Questions
Helped
1782918
Points
15941
Hi.
This is possible and is more cost effective than buying a new PC. The processor is a Socket 775 so just look out for a better one than you already have.
Regards.
5 Related Answers
Anonymous
  • 62 Answers
  • Posted on Dec 15, 2007
SOURCE: HP Pavilion s3020n memory upgrade
They are usually in a plastic caady which has a latch on it find the latch and release the caddy hope this helps
Anonymous
  • 11 Answers
  • Posted on Jun 22, 2008
SOURCE: upgrade
Hi, my pc is hp compaq d530 sff, the processor is celeron, is it possible to upgrade it to a higher processor like core2due, if not what are the other possibilities
thanx.
Anonymous
  • 1179 Answers
  • Posted on Feb 04, 2009
SOURCE: boot pc problem
You can solve this by going into the bios setup & changing the boot order. Make the dvd/cd drive 1st in boot line then hdd. This should allow you to boot up from the windows xp disc. Hope this helps & please rate this solution fixya. Thanks.
Anonymous
  • 51 Answers
  • Posted on Feb 24, 2009
SOURCE: Upgrade HP a1010n Motherboard
Techguru2009: When you upgrade your motherboard, basically you have a new computer. You need to know how your hard/cd drives are connected. Either IDE or SATA. IDE is legacy hardware 80 pin and SATA is the new Thing small connecter. Next is your RAM. There is Dimm, DDR1, DDR2. Find out what your old system was using, or just buy new memory cards, DDR2 is not that expensive. Ask for the manual first read and check what is required, take a list of what your old computer has. I can also help you install everything via chat.
WebKill
  • 77 Answers
  • Posted on Mar 12, 2009
SOURCE: Processor upgrade
The 939 Socket is a bit of an older socket nowadays, most of the newer stuff is AM2/3; you might be able to get an Athelon 64 X2 chip for it though.
2answers
How to upgrade the memory
to upgrade the hard drive space capacity of your pc you need to buy another hard disk drive and add it to your computer....
1helpful
Dimension 5150 (DIM515MIN) PC Desktop: I want to know what kind of case a dell has. I'm p...
The Dimension 5150 has a BTX case, which is nearly impossible to upgrade. The motherboard is NOT interchangeable (with a few exceptions, but none of which are true upgrades).
If you have a PCI Express slot, you can upgrade the video card but do not get a card that requires an additional power cable directly from the power supply. This is because the stock power supply is very weak and doesn't have outputs for additional cards. If the card requires no additional power, you should be fine.
You can upgrade your processor with the P4 [Prescott] 5xx or 6xx Series Processors with HT. The 5150 does not support core 2 duo processors. Depending on what you currently have, this may or may not be worthwhile. Also note that higher power processors run at higher temps, which sometimes causes a noticeable increase in fan noise.
The hard drive is easily upgradeable. Just buy any standard sized SATA hard drive. Your computer case supports two drives, so you could keep your current drive and just add a second drive. Remember to buy a SATA cable with the new drive because new drives usually don't come with them.
Overall, if you're looking to get outstanding performance, get a new computer. BTX computers are not gaming computers. You'll end up dumping money into this thing just to get a lousy increase in performance.
What is the best processor for my hp pavilion ze4300? Do i need to upgrade the processor if i upgrade the memory to 1GB?
No you do not need to upgrade the cpu after upgrading the memory. The best processor is likely the one in it, however it may support other processors in the same family (ie, if it supports the i7 processor it may support any i7 processor, 1ghz or 2ghz, or if it's an amd turion 64 x2 tl-56 it should support the tl-58 and others. Be sure to purchase a new cpu from somewhere that does offer returns if it doesn't work.)
2answers
I want to upgrade my cpu, but dont know how to go about it.
it is not complicated for upgrade the desktop.as per my knowledge ur system configuration is-
Key Features
Form Factor Mini Tower
Processor Intel Pentium 4 1.6 GHz
Installed Memory 256 MB (SDRAM)
Operating System Microsoft Windows XP Home Edition
Recommended Use Business
ur system processor and memory both will be upgrade.
Memory-
RAM Technology SDRAM
Installed RAM -256 MB
Max Supported RAM 3 GB
Installed Video Memory 32 MB
Processor-
Processor Type Intel Pentium 4
Processor Speed 1.6 GHz
Processor Manufacturer Intel
Processor Upgradability Upgradable
Audio / Video-
Audio Output Type Sound Card
Max. Video Resolution 1920 x 1440
Hard Drive-
Hard Drive Capacity 40 GB
Hard Drive Interface DMA/ATA-100 (Ultra)
Thanks,
1helpful
Its processor is only 800 mhz, can i upgrade it into a more higher mhz?
insteading of changing the motherbard for making it fast try upgrading the memory cards it add extra memory stcks in the computer to make it faster...
Upgrading pc notebook
If you are a gaming person, then a new one, if not and the processor is around 1.6ghz or above the i would upgrade.
Regards Wayne
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
