Question about Samsung WF350ANP Front Load Tumble
Samsung washing machine nf Error code
Get an "nf" error code that says it's trying to fill up with water an it can't. Verified water supply, clear hoses and clean inlet filter, but can't get through a cycle without getting the error. Have to shut it off and turn it back on for it to work.
My samsung washing mechine can't spin 13.5 kg load. why/
Posted on Jun 08, 2013
    Sergeant:
  • 291 Answers
Here is the best troubleshooting manual i've ever seen. It's PDF:
http://downloadcenter.samsung.com/content/UM/201106/20110628141933509/WF350AN-Tech-02834A-02.pdf
I found it here:
https://www.samsung.com/us/support/owners/product/WF350ANP/XAA
NOTE: If water is not entering tub, you almost certainly need to replace the water valve. If water is entering tub but won't fill your drain pump is suspect. Hope this helps.
Posted on Dec 30, 2012
  • 3 Answers
SOURCE: Samsung washing machine J1453. Error
Had a same fault code and also sometimes had the reverse kept filling - soultion was that the small flexible pipe up to the pressure sensor had a crack (fatigue mahine was only 1.5 years old) in it next to the sensor - found it by sucking and blowing down the pipe while it was not connected to the sensor (with the electric off ) - Replacment pipe can be found at any good local washing machine parts shop/store
Posted on Jul 11, 2008
  • 13 Answers
SOURCE: Washer keeps displaying '4E' Lack of water error
If you have pulled out and cleaned the filter at the back of the machine where the hose connects then I would check that your pump is not running during the cycle and also make sure your drain line is at least half way above your drum at its highest point, If its too low then it will drain off even if the pump is not running.
Posted on Apr 11, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
  • 380 Answers
SOURCE: Samsung washing machine gives Low Water pressure
You get these messages turned off by fixing the problem.
Low water pressure is basically one of the valves is not letting water pass through.
1. Do as you already did and clean the inlet filters. Any kinked hoses?
2. Adjust the water pressure in the house. Is it too high or too low?
3. Replace the valves in the unit.
4. Main board.
Posted on Dec 30, 2009
SOURCE: i have a samsung J1043 7kg washing machine, apon
3E means the motor is running below or above the programming RPM's, this is a real problem. hold down the two left buttons while pressing the power button. this will present you with the testing system. Press the temp button and T1 will appear. press the start button on the machine will move through the phases in 3 second bursts. if your drum doesn;t move your motos shot. Good luck
Posted on Jan 31, 2010
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Nf code and donnot continue to next cycle
    Samsung Washer Error Code NF (Fixed ...
    www.appliancerepairlesson.com/.../samsung-washer-error-code-nf-fixed/
    Jan 11, 2014 - What does the error code NF mean on a Samsung washer? ... You can set the washer to any cycle and test each solenoid for proper voltage. ... Next would be to check the screens on the back where the water hoses connect. ..... Hi, you don'thave any power to the water valve wires when it should be filling?
    Dec 15, 2015 | Frigidaire Affinity ATF7000E Front Load...
    What is Nf code
    Dits a no fill error so you probably need to replace the water inlet valve. The link below goes into it in more detail. Samsung Washer Error Code NF Fixed
    Oct 24, 2015 | Samsung SW62ASP Top Load Washer
    Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
    Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
    Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
    Error nf code
    That code is the no fill, or no water code. Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water which in return will give you the nf code as well. What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness.If both those are good somewhere inside the body of the machine is a tech guide which will tell you how to go into diagnoistic mode and run test on every part of the machine to narrow down the actuall problem.
    Apr 29, 2012 | Amana 3.5 Cu. Ft. Front Load Washer...
    HOW TO FIX NF CODE IN MAYTAG WASHING MACHINE
    Hello & Welcome to FixYa
    NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
    Kevin
    Oct 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
    I have an error code that says nf
    NF error in your washer is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
    Kevin
    Mar 06, 2011 | Samsung WF337AA Front Load Washer
    I get an NF error code and the washer sounds like it's filling, but never does, and then there is water in the detergent dispenser.
    Hi
    Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water. Try running the diagnostic test by:
    • Press the delicates and heavy soil keys together for 3 seconds.
    • You are in the service mode.
    • Now, press wrinkle free key, cold water should start entering.
    • Then, press the cotton sturdy and hot water should flow.
    • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
    Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Sep 22, 2010 | Samsung WF328AA Front Load Washer
    Nf error code sporadically
    Tell me, do you notice the water filling and going against the "glass" door and going straight to the overfill trap bellow the door?
    Let me know.
    Dec 30, 2008 | Samsung WF203ANW Front Load Washer
    Samsung WF350ANP Front Load Tumble Logo
    1,970 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
