Question about Bosch Dishwashers
I have a Bosch SHU4322uc/u12 dishwasher remove wires from control module, should have taken picture, but did not,need to know where to plug wire into control module thx
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 31 Answers
Look at the notches in the control and on the wire connections. They are all different and only fit in their own spot.
Posted on Dec 30, 2012
SOURCE: Replacing Control Module
Sergio,
Did you get your problem resolved. By now I think you have found the two screws on the sides of the inter part of the door. Did replacing the module fix your problem. I have the same problem.
Mike
Posted on Jul 06, 2008
textonor
  • 130 Answers
SOURCE: burnt wiring on Bosch SHX46A06 Dishwasher
Bill that is exactly what happened, the connection wasn't correct from the start. The Bosch dishwasher pulls 11 amps during the cycle while heating the water to temp. The cooler the water the longer the heat time. Your dishwasher came with a set of wire nuts that where suppose to be used. Be sure when you correct this to use 20 amp wire nuts with the unit. This will stop this from happening again.
Posted on Aug 12, 2008
daddy1264
  • 76 Answers
SOURCE: How do I replace the heating element for a Bosch SHU53 dishwasher
are you sure its the element, the control boards on them get bad soldering joints and the you get the impression that the element is bad, but its the solder joint that controls the element that goes bad....you can resolder that
Posted on Dec 30, 2008
mark_37388
  • 100 Answers
SOURCE: My Bosch Dishwasher cycle runs for 2 plus hours!
If this unit is running for a long time it is because it is still try to heat the water temp up it is eather the control board or the heater.
Posted on Mar 28, 2009
SOURCE: Bosch SHV 6800 dishwasher, 2HR error
Bosch dishwasher all cycles start at 2H and get hungup on 1 min.
Posted on Apr 30, 2010
Bosch model SHX68T55UC/02 Completely dead after 2 inch flood in kitchen.
You will need to remove the unit from its installation in the cabinetry. Check the wiring connector located on the rear of the base, near one side. The wire connection must be clean, dry and securely snapped into place. If this connection is burned, distorted or won't allow the plug (special shape) to click securely into place then it should be replaced. Since the unit is totally dead it would appear there is no power reaching the control module, But, you can also confirm that water did not overflow the top of the dishwasher base pan and allow water to enter the pump motors (there are two.) If so these must be thoroughly dried. They may be damaged if power was supplied to a motor with water in the winding and contacts.
Oct 03, 2016 | Bosch Dishwashers
How do I fix the heater in my Bosch shu5306uc / u12?
SHU5306UC-12 BOSCH DISHWASHER Manual - Sears ...
www.searspartsdirect.com > Kitchen Appliance Parts > Bosch Parts
Download Manual for Model SHU5306UC-12 BOSCH DISHWASHER.Sears PartsDirect has parts, manuals & part diagrams for all types of repair projects.
Aug 01, 2015 | Bosch Dishwashers
How do I run a diagnostic test on the Bosch shu5315uc/u12? The cycle time of my dishwasher is at least 4-5 hours.
Long running time on a Bosch dishwasher is almost always a blown solder joint at the heater relay on the control board. You can resolder the joint, replace the relay or replace the control. Control board part number is 00266746.
Jan 13, 2015 | Bosch Dishwashers
My bosch dishwasher model shu5306 uc/u12 counts down to one minute left then just keeps running
Your d/w has a faulty control board... only solution is to replace it.
Mar 21, 2010 | Bosch Dishwashers
What is error code 2H
My Bosch dishwasher did the same thing. When the wash cycle starts, the dishwasher fills with water and then the heater is supposed to turn on to heat the water. If the water does not heat, then it will display 2H continuously. The heating element may be bad, but a more likely cause is with the control module. Bosch has a problem with the control module printed circuit (pc) board that powers the heater on many models. The solution requires some technical expertise and soldering skills. The details are explained in the document "Bosch dishwasher troubleshooting tips" on page 11. Download here
Bosch recommends re-soldering the connection, which is a temporary fix. The problem is that the copper conductor (called a trace) on the circuit board is not wide enough to handle the current required for the heating element, and as a result the copper trace overheats, causing the solder to melt on the relay connection. The best solution is to remove the control module PC board and solder a short length of copper wire between the pins to prevent the overheating problem, as shown in the attached photo (magnified portion of PC board). I did this on my dishwasher and it has been trouble-free for over 3 years.
Jul 07, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Tried to replace bosch soap dispenser model shu3036uc/u12
Wire positioning doesn’t matter to soap dispenser. If water is leaking from the door then the dispenser is not pressed in properly against its seal. As far as the door not opening if wires are connected perhaps the problem is in the control module. Voltage meter on wiring to dispenser should indicate this while machine is running at start of quick wash cycle. (First 5 minutes of cycle on heating)
Dec 28, 2017 | Bosch 24 in. SHY66C02 / SHY66C06 Built-in...
Nov 24, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch model SHU43C05UC/17
the module (timer) have a groove that each set of wires slide in and a tab that snapps in place. usually you can't mess up the plugs. all wires should be plug in..
Jun 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Sergio,
Mike
Jun 28, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
117 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
