Question about Irulu 10.1"tft Wifi 3g Android 2.2 Tablet Pc Touchscreen 0.3mp Camera 2gb 512mb Ddr2
IRULU tablet has broken charger port or hole
Son plugged charger in may have messed in side charger up
  • tim lawhead Dec 30, 2012
    can this be charged from usb port
4 Suggested Answers
lee_catrina
SOURCE: irulu 7 instruction manual?
i cant get my wi-fi work on my irulu tablet help please
Posted on Dec 25, 2012
SOURCE: How do u charge an irulu tablet, didnt get a charger with it
I got my tablet with a charger but after some time it got damaged.. NOW I USE THE MINI-USB cable to charge it.. you can use an adaptor like the one that comes with the Samsung galaxy cellphone and use the mini usb cable with it.. Hope you understand my mess.. good look..
Posted on May 03, 2013
  • 451 Answers
SOURCE: How do you reset a Irulu laptop?
A: Performing a factory reset can be useful for a number of reasons and situations, particularly when your device has become too
clogged up with apps, files and different accounts which may be compromising the performance. Please follow the outlined steps
below:
1: Navigate to the settings of your tablet.
2: Scroll down to click on Backup&Reset section of the Settings menu.
3: Enter reset facotry settings.
4: Hit the Reset Device Button.
Hope this helps.
Posted on Jan 03, 2014
Testimonial: "I cannot get into my tablet. It wont leave the first loading screen. I need to be able to reset it with out needing to be inside the tablet."
Charger fot my acer tablet only goes half way in and wont charge
The pin inside the charger port might be broken.
Look in the hole where you put the USB (on the device) there should be a tiny flat tongue sitting in the middle, if it's bent and touching the inside of the hole, it will need repairing. It's a very common fault.
You might be able to temporarily fix it yourself by trying to straighten it with a tooth pick. It's supposed to slot inside the micro USB plug.
Oct 20, 2016 | Acer Tablets & eReaders
How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port.
If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port.
Also, some Cable adapters are On the Go wired, and may not work properly.
It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
Apr 20, 2016 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Is my irulu x7 tab mhl enabled
Irulu Tablet - Android Forums at AndroidCentral.com
forums.androidcentral.com/other-tablets/236406-irulu-tablet.html
Dec 18, 2012 - 25 posts - ‎22 authors
The specs are below. ... I just got my irulu 4.2 Jellybean tablet and this is my first time dealing with anything other than desktop and non smart phone. ..... There is a hidden phone on the irulu X7 called dragonphone and I have ...
MHL Supported Products - Accell
www.accellcables.com/pages/mhl-supported-products
Now mirror your smartphone or tablet featuring MHL technology on a display or projector. Please ensure your device is MHL enabled by visiting the link below. •
Feature News Stories: How Do I Connect My Tablet to My ...
hometheaterreview.com/how-do-i-connect-my-tablet-to-my-tv-let-me-co...
Oct 14, 2013 - That means you must connect your MHL smartphone or tablet ... flash drive and plugs directly into an MHL-compatible HDMI port on your TV or ...
Amazon.com : IRULU X1a 7" Tablet - A33 Cortex-A7 1.5 ...
www.amazon.com/IRULU...Tablet.../B00M3OTG3S
Amazon.com, Inc.
Rating: 3.2 - ‎97 reviews
Jan 21, 2016 | Tablets & eReaders
My irulu tablet wont charge
Check charger, cable and connectors. When you can borrow another charger try that one. If a new or good charger does not change the situation, and nothing is in the connector, the defect must be in the tablet, like a bent or broken pin in the connector, or a broken cable inside. An oxidised connection inside or just a defective main board, to mention some possible causes. As soon as the tablet needs to be opened, consult a tech, or start saving for a new tablet.
Apr 24, 2015 | Tablets & eReaders
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
The charging port is broken off, will the pad still charge wireless?
No. The wireless charger has to connect to the charging port via an add on cover on the device. Powermat Wireless Charging Pads from Duracell
Get a new tablet.
Mar 11, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Jan 08, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
How do I reset my irulu 7" tablet pc ?
Let's see,
Point is: 99.9 % you loose your stuff by hard-resetting! So Backup first (if you can)
a) get yourself a paper-clip or equivalent (no needle !)
b) plug your tab into the el. net with your charger, (make sure charging led lights on); turn device on by pressing "on" on the device;
c) look @ your irulu, mine's got a dedicated "RESET" hole between the USB port and the earphone outlet; It's a small 2mm hole.
d) poke the paperclip softly into the reset hole until you feel da "click"; keep it pressed for a little over one minute, release the clip and wait for the device to reset and reboot;
e) Setup your device> date, time, usr name, password If that does not work, contact your seller, try to ask nicely for help; kindness makes the world go round and does wonders; they are happy to help;
greetz
Ganimidis
Dec 29, 2014 | Tablets & eReaders
Dec 13, 2012 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Irulu 10.1"tft Wifi 3g Android 2.2 Tablet Pc Touchscreen 0.3mp Camera 2gb 512mb Ddr2 Logo
312 people viewed this question
Top Irulu Tablets & eReaders Experts
David Clark
David Clark
john smith
David Harrelson
David Harrelson
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
