Question about Rockford Fosgate RFP3212 Car Subwoofer
Somethings Crazy
I have had two of these subs for quite some time and have not had any problems til today. Upon re-installing my system,i could only get my right subwoofer to go. I switched the speaker wires and had the same result, which proves that the speaker wires are in working condition. I then took the non-working subwoofer out of the enclosure and checked all the connections and all appeared to be secure. Im out of ideas of how my left sub could just stop working like so.
  • 156 Answers
It's surprising to see one fail after such a long time, but most likely either one of the tinsel leads (between the speaker terminals and the voice coil) has broken, or the voice coil itself has burned out. You should be able to see the tinsel leads; if one has broken away from the terminal you may be able to solder it back into place. If it's broken on the speaker cone side, it's unlikely that you'd be able to solder it without damaging the cone. A break in the voice coil won't be visible; to test for it, check for continuity between the two terminals. Unfortunately, it's probably going to be easier to replace the subs than repair them.
Posted on Jun 23, 2007
SOURCE:
2003 yukon big motor oil pressure gage drop to o message and alarm goes off Oil level ok.has done this in past and quits.
if the guage is unreliable and its the only one that is, may switch to an aftermarket separate oil pressure guage that mounts elsewhere and be done with the situation entirely..these run around 25 bucks and its time to install and it wont fail like electronic ones do...
Jan 15, 2013 | 2003 GMC Yukon Denali
I just recently bought a brand new MTX magnum amp and dual 10" enclosed subs deal off of amazon. They arrived today, and with the help of a friend who is good with car audio systems, we set the whole
the best thing to do is get in touch with amazon,and see what they can do about it,if you try to fix the problem yourself it will invalidate the garantee!
Dec 05, 2012 | MTX Car Audio & Video
I have a Sony Xplod 800w Amp running a 10' Sony Xplod Amp....i unhooked the amp to do some moving and i tried to put it back in today and it didnt have any sound coming from it! I did notice the power...
it sounds like it could be a blown channel in the amp. if the sub was blown it would still work just sound horrible. i have blown many subs and amps. you can bring it to an audio shop near you and they can fix it. i just got one of my channels fixed for 35$
May 11, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Upon entering any game the system
Call (800-345-7669)
Sony Network is experiencing sporadic outages in certain areas today.
It is reported to be "scheduled system upgrade" to the network servers - be assured you are not the only one facing this issue.
No UP time has been announced by Sony - they are working to get the system up and running as soon as possible.
The problem is not on your end.
Keep trying to connect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 01, 2010 | Sony PlayStation® 3 (80GB) Console
Subs cut out at low volume no matter the settings
I'm not a complete audio expert but it sounds like somethings over heating or you have a blown out put bridge.
Jun 20, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Jvc th-c30
sharazanct I had the same problem and posted here many months ago without any success. Just today, believe it or not, I decided i would replace the screws in the top cover and try it one last time. I don't know why, but it now works fine.???? My original problem was my receiver would light up and appeared to be working but I would get no sound out of the sub or speakers. I noticed at the time when I would first turn the receiver on the green indicator light on the front of the sub would light for a couple of seconds and then go out and would get no sound. Today the sub light lit and stayed on and I'm therefore able to hear sound as if everything was normal. I wish I knew exactly what I did, unfortunately I don't. If you have everything back together you might try unplugging the receiver and sub for some amount of time and come back and try it again. Good Luck!
May 04, 2009 | JVC TH-C30 System
Subs fading out briefly but speakers working fine
Holy mackerel you have a ton of power i bet that ****** is loudddddd-sounds like your charging system isnt quite keeping up with the amount of current draw that your amps can pull.Upgrade your alternator and look into a dual battery system using an isolator-that way your alt will charge both batteries but your amps will only pull off the one battery-you can look online into how to set that up its not that hard for someone that has managed to install the gear that you already have- Some folks if not most would encourage you to get some sort of capacitor to store power blahblahblah-BUT a dual battery system has waaaaayyyy more storage capacity than a capacitor does-check out the pro competitors online they arent using capacitors to run their stuff they use banks and banks of batteries to get their power-brother you need more juice
Apr 15, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Subwoofers won't work and they are brand new
I've got a pair of these MTX's subs powered from a Fusion 450 watt 2-channel amp. For the price, they are great. By the way, they are 4-ohm.
My first suspicion would be that something in the first incorrect wiring damaged either the amp or the subs. Can you explain specifically what the "installing the subs incorrectly" means? Was the amp output shorted out at any time or was it operated without a load? Either of these conditions will fry an amp and sometimes, the protection circuitry doesn't work either.
First make sure that your amp is still working. Check both the primary power fuse, usually located near the vehicle battery, and the fuses on both sides of the amp. Make sure that when you turn the system on, the power light comes on steady (blinking is protection mode). Test your subs one at a time on a speaker output.
Mar 29, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Dayton sub-100 connection
You have it upon one of several truly odd "standards" in the AV industry but the answer is simple if not quite logical. You will use an RCA type cable from the Sub out or LFE on the receiver to just one of the two inputs on the subwoofer. I usually use the one on the right but it really doesn't matter. The other connectors would be for a system with out a sub out where the speaker wire would be run first to the subwoofer and then out to the speakers. This will not be used at all in your case.
Enjy!
Feb 27, 2009 | Bose 151SE Main / Stereo Speaker
Rockford Fosgate RFP3212 Car Subwoofer Logo
249 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Professor_V
Professor_V
Mike Duncan
Mike Duncan
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
