Question about Cobra electronics pr5000dx 15-mile range two-way radios- 2pk
I have the Cobra PR5000. Haven't used in awhile so put in new batteries in both units , put in charger where red lights came on but went off. When I turn on the radios there is nothing and a blank
  • 105 Answers
SOURCE: Cobra CB Radio 148 NW ST
The first thing to do is to check if your power wire actually has power to it. Do this with a test light or a multimeter. Given that the wire is powered, check to make sure your ground is good. Modern cars have so much plastic in them that grounds may be hard to find. The next step is to check the rig's fuse. Make sure the microphone is plugged in, too. If none of this helps, your radio needs repair or replacement.
Posted on Feb 17, 2008
vrc_tech
  • 109 Answers
SOURCE: Batteries won't charge on new cobra 2VP 270 radios
If radios are brand new then I would take them back to the store for warranty exchange. The other opton is to vist a local radio service center and ask the tech to jump the battery. if the battery falls below a certain voltage it might need a quick jump sart from a power supply with a higher voltage normally 12 volts works well...
Posted on Aug 20, 2008
BillB-SA
  • 2761 Answers
SOURCE: I just put new batteries
The radios will work fine while being charged, but they will charge faster if turned off. Normal charging time is 8-10 hours, but I would recommend an overnight charge - they won't overcharge or be damaged by the longer charge time.
Bill B.
Posted on Nov 05, 2010
  • 33 Answers
SOURCE: I have a pair of
Your batteries may be bad. Sometimes over charging batteries will cause them to wear out.
Posted on May 05, 2011
Ironfist109
  • 3018 Answers
SOURCE: Just received my new cobra
  • Check that power cord up by the tip. It is possible it is a little loos in the tip (that hooks into the radio) Being new it almost has to be related to the power feed.
  • Make sure the fuse you are using is good. Use a 4 amp fuse in there.
  • Make sure you installed all the shoulder washers in your antenna properly or this will cause a short too.
  • Your power supply could be at fault too. Take a multimeter and turn it to DC volts and make sure 13.8 is coming out of it. The power supply could be failing under a load. Have you tried a quick setup in the car? See if sticking the power cord pos to pos and neg to neg on the car battery keeps the radio running better. You don't need to have the antenna hooked up for this just DO NOT key the mike. Just long enough to see if the radio stays on for more than 2 seconds.
  • If you do all this testing and the radio still cuts out then you have a defective unit and it needs to be replaced with a properly running unit.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jun 19, 2011
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
No Power
If your Charger is OK, then the problem is your units' battery was drained. Change your units' battery.
Apr 23, 2013 | JVC GZ-EX210 Full HD Everio Camcorder with...
I have a Samsung PL100 digital camera. I dropped it while at beach, it was switched off. When I went to switch it on the lens came out but then it made a buzzing sound and switched itself off. The lens is...
I had the same exact issue.... try putting it on the charger, even if you think it's fully charged... If the light is red, leave it on the charger until it turns green, and then remove the battery for a second and then put it back in the camera before turning it back on..... try turning it on. If it still won't close, put it back on the charger. If the charger is automatically indicating a red light, that means you have exhausted your battery and will nee a new one... they cost about 5-11 dollars on amazon...... hope that helps...
Jul 20, 2012 | Cameras
My Cobra micro talk two-way radios have lithium batteries. They will not charge in the charger, the light won't come on. If I take the batteries out and put them in the charger alone the light lights...
Check your battery contacts to see if they have a film of dirt or debris. If so, clean them with a pencil eraser. Check to see they are making good alignment with the contacts in the charger. If these suggestions do not solve your issue, you may have a bad solder on a battery contact in the radio. (Be certain the radio is shut off when charging.)
Best regards.
Sep 24, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
My cobra microtalk cxt450 will not charge. and the charger lights are not on when i place them in the charger
pull the batteries out, slam them ******* a solid surface. put 'em in, let 'em charge. if that doesn't bring 'em back buy new bats.also, use a voltmeter to make sure the charger was getting voltage.
Sep 04, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
Cobra pr 3850wx bought new NiMh 800mAh 1.2v rechargable batteries now the base charger lights won't come on when i put the radios in it
  • A Cobra 3850wx Radio requires 4x600mAh NiMH 1.2V AAA Part # GA-3ANH rechargeable batteries.
  • Not just any AAA rechargeable battery will charge in the unit.
  • All will work in the radio but not all will charge inside the radio. It has to be a specific battery.
  • This is an example of what you need. GA-3ANH batteries which will charge inside your radio. http://www.tomsawyer2wayradios.com/catalog/item/3823249/5076887.htm
Regards, Tony
May 22, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Charging
put batterys in a normal charger. if still nothing,. problem lies with radios.
May 09, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Cobra electronics pr5000dx 15-mile range two-way radios- 2pk Logo
47 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
