Question about Dell Dimension E510 PC Desktop
Dell E510 Freezes during Bios Load
I have a Dell E510 computer which was new in October of 06. It occasionally used to freeze when the bios would load, but now almost always does. If you turn the computer off and restart it, it will start alright. It doesnt seem to have any other erratic issues other than that.
I'm debating on replacing the CMOS battery but someone said that if it doesnt say "restored to factory defaults" on load that it couldnt be that. Although I think the splash screen might cover it.
Any help is appreciated.
  • 1,913 Answers
U haveto reset your bios wit juper settings it is near cmos set in it 2-3 position then again in 1-2 position .
ten clear all dust from circuit then reaatch all calwe and connectors.
Posted on Jan 18, 2009
My computer stays on bios and wont start
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Jun 17, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
Hi my Dell OptiPlex GX270 turns on but when it comes on it freezes but i cant be sure its frozen because my mouse and keyboard wont connect I orginally bought a wireless mouse and keyboard and it wouldnt...
First off, try going to BIOS. Usually you have to tap either F2 or Delete on dell computers while booting up to enter BIOS. If you're successful, and you're in BIOS, observe for a few minutes if it will freeze while in BIOS. If it doesn't then you might need to reinstall windows. If it freezes in BIOS as well, then there's a hardware malfunction/problem. That will be the time to have a technician check the hardware on your desktop.
Sep 11, 2011 | Dell OptiPlex GX270 PC Desktop
I have a Dell Dimension E510 and it makes different tone beeps during and after startup. The computer works ok, but the beeps are disruptive. Seems like there are many more beeps during processing steps,...
When you first switch on your computer it checks certain things to make sure everything is OK and sends out multiple Beeps if there is a problem this is call POST. If you are getting multiple beeps then there is a problem, depending what BIOS CHIP you have and how many beeps you are getting should indicate what is at fault. If windiws is starting ok then it will be a minor problem, the first thing I would check if i was you is the memory. If you have more the one stick of memory installed and one is faulty windows will still start but with the beeping error. Start the computer and goto the control panel and click on System and check what memory that is showing and compare with what should be installed. If its the same then the fault is somewhere else and you will have to give more infomation like what is the system bios and how many beeps.
Good luck.
May 29, 2011 | Dell Dimension E510 PC Desktop
My laptop freezes when I use USB ports
dell insprion 1525 revision A13 bios password crack
Feb 03, 2010 | Computers & Internet
Bios problem on dell dimension e510
At first u need to remove the bios. wait for 5 minutes. then add the battery. start it
Jan 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Computer freez
well u could try going into ur bios befor it freezes and make it boot from the win98 cd instead of ur HDD or use a boot disk or just take ur cmos battery out and it will reset ur bios so it should work
Jan 13, 2009 | Computers & Internet
I update my bios in my dell e510 now all it does is restart over and over.
try to download the bios and flash it once again. still if u see the issue probably it could be a improper bios flashing. replace the motherboard
Jan 12, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
DELL Poweredge 2600 Bios FREEZES After Cpu check and before SCSI Drives check HELP!!!!
The BIOS check can freeze for many reasons.
Can you tell me if this is an existing system that was working fine and then had this problem, or is this a new (or new to you) system?
Can you give more information on what is actually showing on the screen?
Nov 05, 2008 | Dell PowerEdge 2600 Server
Optiplex Gx110 Freezing on Bios Post
The only thing I can think of is there should be a jumper pin that on the mother board that resets the cmos. Unplugging the battery does not clear the cmos rom. My guess would be the cmos rom is currupted and unfortunatly you need the rom loaded before you can flash and replace it. My advice is ditch it.
Aug 02, 2007 | Dell OptiPlex GX110 PC Desktop
Dell Dimension E510 PC Desktop Logo
344 people viewed this question
Alun Cox
