Question about Bose Cinemate Digital Home Theater System Speaker
How do you open the interface of a bose cinemate to change the IR inside. Thankls
SOURCE: bose cinemate code for polaroid
I called the company and they said that I had an "original" remote and that they would send me a remote with extended codes. Hopefully that will work
Posted on Dec 26, 2007
SOURCE: bose CineMate home theater needs a remote!
call bose $45 including tax shipping
Posted on Feb 29, 2008
SOURCE: code for uverse cisco box to bose cinemate series
hi i do have here a couple of codes for bose 4000, 2130, 2215, 2276, 6060,
5007
hope this helps! goodluck!
Posted on Jun 03, 2010
charlestrep9
  • 15 Answers
SOURCE: I am having a Bose Cinamate Digital Home Theater. Original remote of this was lost and bought a new Bose Solo/cinemate system universal remote. It doesn't function with the interface. Will it real
If you can't get this to work, I suggest you try to return the remote and buy and harmony remote. For me it worked very well with everything including old audio amps and you can configure your own activities.
Posted on Oct 20, 2012
kjhbewtrg30705
SOURCE: replacement part for Bose Cinemate Interface
Replacement parts for Bose Cinemate Interface can be foudn at amazon, take a look here: Amazon com Bose Cinemate parts. I hope this helped. Cheers
Posted on Dec 17, 2014
Before I start to desolder and solder an new IR component I have a question. The green led doesn't turn on, but why does the interface module turn on when I disconnect the White and Red RCA plugs? So,...
It is probably not the IR component. It sounds more like some voltage problem between components. Can you narrow the problem down to which RCA cable and then down to the component itself? It almost sounds like the system is preventing a failure by disabling the IR component.
Mar 17, 2015 | Bose CineMate Speaker
Bose cinematic autoshut off
The device which sends Audio to Bose causing this issue. I have my Bose Cinemate connected to TV and it will remain until I switch off Bose Interface via remote (Even TV is switched off).
Overheating cause this issue, so keep the Cinemate to have some space to cool.
May 24, 2014 | Bose Cinemate Digital Home Theater System...
The light on the interface will not come on
Try powering the unit down for 30 seconds and then power it back up.If after pluging and unpluging you still have the fix red led then the IR Detector Module inside the CineMate Interface Module is not working. You have to replace it. The Part Number is 1B83 41A. You can but this part at Radio shack for under $5.00 , remove the old one and solder a new one in, 3 leads of the LED. This was the way I fixed mine
Mar 23, 2014 | Bose Cinemate Digital Home Theater System...
Bose cinemate troubleshooting
If the light on your control console just stays red and never changes, then the control module is probably bad. It's pretty common on the cinemate models.
Jun 06, 2013 | Audio Players & Recorders
Oct 20, 2012 | Bose Cinemate Digital Home Theater System...
Replacement part for Bose Cinemate Interface
Oct 29, 2011 | Bose Cinemate Digital Home Theater System...
Can't find remote for Bose Cinemate...is there any other way to turn it on without remote?
No, you need some sort of remote. Luckily this Bose uses IR for the remote and not RF. This means you might find a cheap universal remote that has a code for this. PC programmable remotes such as Logitech's Harmony, URC, and RTI remotes would definitely work.
If this was helpful, please rate!
Apr 07, 2011 | Bose Cinemate Digital Home Theater System...
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
Bose Cinemate green led won't come on.
Do the same thing by unplugging the power, but also unplug the interface module (box with red/green LED light) from the sub woofer / bass module, and wait 30+ seconds. Plug the interface module back in first, and screw it in as tight as possible. Then plug the power back in and try the remote. This should fix your problem. :)
If this doesn't fix it, you will have to purchase/replace this module through Bose. (anywhere from $40-$60 if not under 1-yr warranty.) If you're still under warranty, it's a free replacement.
Jun 08, 2009 | Bose Cinemate Digital Home Theater System...
Interface module and/or bass module power problem
Eric,
Take their offer Bose is not that forgiving.
Send it back let them deal with it.
If you try to DIY it you'll void warrenty and will be totally SOL
Good luck
May 12, 2008 | Bose Cinemate Digital Home Theater System...
Bose Cinemate Digital Home Theater System Speaker Logo
98 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
