Question about Toshiba 200GB USB 2.0 Portable External 200 GB Hard Drive
My toshiba usb external harddisk doesnt work with any computer. i have tried wivista, xp, 2003 server. when i plug it in the red light appears but the pc does not show an icon for accessing it. do i need a driver? what is the problem
    Problem Solver:
  • 10 Answers
Well, a solution of sorts.
I had the same problem with a Maxtor 500g.
Eventually what I did was crack open the case to discover the HD is a SATA with a small circuit board that converts it to USB. I got rid of the circuit board and just plugged it into my system. Have not had a problem since.
I know this is not solving your problem but if the unit is dead and you cannot exchange it for a new one, you could at least get some use out of it.
Obviously I can't guarantee that what is inside your toshiba is the same as what was inside my maxtor.
Posted on Jan 18, 2009
Extenal hard disc when plug in the USB the PC can't read
You may need to plug in an additional cable for power for the hard drive. If you have, make sure the hard drive itself is not broken
Mar 01, 2011 | Seagate Computers & Internet
Dear Sirs, I need the Windows 98 Driver for Western Digital USB External HardDisk 320 GB ? I use COMPAQ Presario with Windows XP to hook up the External Harddisk right know. The External...
Sory to report - from Western Digital support site
Uses SES Drivers
7, Vista, XP
Not Supported
Server 2008, Server 2003, 2000 Server, 2000, ME, 98SE, 98, 95
Win 98 is not a supported OS, for that drive.
Jan 27, 2011 | Western Digital My Passport Essential...
I have a 320gb toshiba external hard drive, i've been using it around 3 years without any trouble. A few days ago i lost the cable connecting it to the PC. I bought a few cables but no use. Doesn't...
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Jan 13, 2011 | Toshiba 120GB USB 2.0 Portable External...
My external Harddrive just up and stopped showing up on the computer. I mean the lights (red and blue) are on, it just doesnt show up. i even plugged both cables into my comp, and still nothing. I noticed...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then power adapter of harddisk or your harddrive has internal issue.
Let me know if you need further assistance. Thanks for using FixYa
Oct 15, 2010 | SimpleTech SimpleDrive 160 GB External USB...
External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
May 08, 2010 | Toshiba 120GB USB 2.0 Portable External...
External Harddrive doesnt show up in harddrive management.
it sounds like a hardrive issue. You can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 24, 2009 | IBM TravelStar 48GH 48 GB Hard Drive
Trying to install FreeAgent GO 500G as backup for Server 2003
Installation isn't possible directly from the Harddisk.
Try download from http://www.seagate.com/staticfiles/support/software/FreeAgentCN.zip
Good Luck.
Uwe
May 23, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Toshiba 200GB USB 2.0 Portable External 200 GB Hard Drive Logo
337 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
