Question about Route 66 ROUTE EUROPE 2004 (601184407502) for PC
When i install Route 66 onto my samsung Omnia says no gps
Does it matter where i install route 66 eg: my storage, sd card etc
3 Suggested Answers
SOURCE: route 66 rac 210 sat nav update,s
sfaty cam updater from http://www.66.com/rac/index.php?cid=UK
Posted on Nov 12, 2008
SOURCE: Route 66 Mobile 8 Windows Mobile - software update creates error
To upgrade, use the website version of Route 66 Sync rather than the version on the disk or the upgrade file from the website, both of which do not work. The website version works in conjunction with Microsoft ActiveSync.
Posted on Dec 28, 2008
SOURCE: finean.exe error
Try downloading a new map program at www.finean.com .They tell you to install the map in the following directory :- \SD card\finean\map\.
Regards
G.Archer
Posted on Jul 06, 2009
Tip
I BOUGHT MYSELF A FORTIS GPS NAVIGATOR AND IT CAME WITH THE ROUTE 66 SOFTWARE...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Mar 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Lost Memory Card for Route66 Sat Nav
Get the SD card for any comuter store, and after you have to install the nav software on it, which for some information regarding the unit I will sell it to you for a rezonable price
Aug 19, 2009 | Route 66 Mobile 7 GPS Receiver
Route 66 on Samsung i900 omnia not synchronizing. Route 66 sync does detect the device but keeps asking 'please start the navigation software on your device'. Starting route 66 on the device does not solve...
the same problem for s8000 jet.
route 66 syn keeps saying "please start navigation software on your phone" but this doesnt solve. And I can not create a login.
Jul 18, 2009 | GPS
Upate GPS route 66
Route 66 map with navsoon 385 divices
Mar 02, 2009 | Computers & Internet
I have an A2265FF all in one navigation unit in my ford focus, the SD card had route 66 installed on the card which I updated and since then I have lost the files for loading the navigation, I have...
I can understand your problem, this problem arises with new SD card.
So, please copy Navione folder to memory card root directory, enter the directory, use Notepad to open Loader.ini to edit, enter your correct path, for example: \ Storage Card \ NaviOne \ NaviOne.exe save you, run to enter Loader.exe navigation procedures.
I'm sure it will work out for you. The error message shows similar indication. So, do it and load your route installed. It will work out surely.
With Regards,
Shyny
Apr 22, 2009 | GPS
Route 66 stuck on the welcome screen (Route 66)
Get the update for Mini/Maxi route 66 from 183 Mb. Install this with card reader on the the SD card.
Then ,having the same problem, Route 66 will start up as usual.
Jan 11, 2009 | Route 66 MINI Handheld GPS Receiver
Gps navigation screen is paralyzed--all other screens are working
hi did you install the software straight to your route 66 maxi using route 66 sync software ? if you did try downloading it to your computer then transfer it on to the memory card using a card reader
Jan 07, 2009 | Route 66 MAXI Car GPS Receiver
Gps model number FS070001795 route 66
hi have you tried installing the gps firmware update, if not here is the link
http://www.66.com/support/index.php?cid=UK&opt=updates_detail&prod=4
Jan 06, 2009 | Route 66 MAXI Car GPS Receiver
Activating Route 66 maps on my new Omnia
Gents,
It is quite simple
1. make sure you omnia is connected to the internedt
after insalling the route 66, go to
2. route 66 main menu
3. click on extras
4. scroll down and click on update
it will download and update
5 exit and go to extras again
6. now click on MAPs, you will find that Indi map would be seen as unlocked. select and enjoy
I have used many other gps maps in India but find that route 66 for India to be most accurate among them. but please note I was told that THIS IS AVAILABLE ONLY FOR 6 MONTHS ONLY. hope some one lets us know how to extend this.
Cheers
Raj
Nov 10, 2008 | Cell Phones
Route 66 ROUTE EUROPE 2004 (601184407502) for PC Logo
766 people viewed this question
Top Route 66 Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Route 66 Computer and Internet Expert? Answer questions, earn points and help others
