Question about Zanussi 24 in. DA6153 Free-standing Dishwasher
Its actually a Zannussi DW24 bottom sprinkler not working
The bottom rotating spinkler is not moving (the steel oblong sprinkler paddle)
  • 944 Answers
Here is the link for the user manual if you need it; http://www.serviceforce.co.uk/pdfs/U01296.pdf Check page 14 about cleaning the large filter and removing the lower spray arm to do so, you will probably find a blockage there that is stopping the water flow (the rotation is driven by water pressure). If there is nothing visible and cleaning in there makes no difference, first check that the water can freely run through the spray arm by simply holding it upside down and filling it with water, checking that it comes out of ALL the holes (think of them as jets) and that there is no significant limescale build up. If you are unsure or the holes seem blocked, put the spray arm in a bowl of vinegar for a half day or so and the limescale should be dissolved. There can also possibly be particles of food blocking it (rice is a favourite) which can only really be removed by a bit of persistence with a tap or hose - a garden hose in the garden is the easiest and least traumatic way. (some spray arms can be opened up - if it can be it should be fairly obvious but it is unclear from the manual and unlikely for this model). Make sure when you reassemble it that everything is exactly in the right place and tightened down properly if still no luck, then check that the water inlet hose is not kinked, the tap (if present) on the inlet hose at the wall is not half off, and the filter in the hose where it joins the machine is not blocked (to check this you have to turn off the water supply and remove the hose). Inadequate water pressure due to a restriction in the pipe will stop the spray arm spinning. The last thing to try is a complete descale - there could be limescale blocking the water in a part you can't get to - a bottle of vinegar on a hot cycle with nothing in the machine works, or you can buy "dishwasher cleaners" which are usually strong citric acid or similar that you just put in as if it was detergent and run (again empty). If you haven't done this recently it is almost certainly worth doing anyway. In Summary if there is water at mains pressure getting to the spray arm and the holes in it are clear and it is fitted properly, then it will spin. Hope this helps - please ask again if you need any help carrying out these procedures :)
Posted on Jun 23, 2007
Instructions to maintain a TORO TR50XT Sprinkler
The sprinkler head unscrews just like a bulb. Dig a hole around the head to below the connection.
Unscrew the old one and screw in another one. You might need a nopple on the new head to match the connection. Set up the new head with the same setup an the one in the ground before you unscrew it as water will come out of the pipe and fill the hole. You want to get the new head set before debris gets into the pipe.
Jul 05, 2014 | Toro TR50XT-HP, Adjustable Arc, 12 Inch...
Took paddle off to clean but now can't get the paddle to rotate, help?
Add enough near boiling water to cover bottom. Wait 5 minutes. Drain off water. Add oil that you would use to make next loaf of bread. Rotate paddle back and forth to loosen up. I always add oil first to "lube" paddle shaft.
Apr 30, 2014 | Kitchen Appliances - Others
My traveling sprinkler won't move. The wheels rotate but it seems the gears don't engage. What should I try?
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Apr 29, 2011 | Nelson Sprinkler: Traveling Tractor
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
Ice and water dispenser stopped working
Welcome to the computer world. When depressed, the paddle actuates a switch attached to the bracket above. The switch sends a low voltage signal to a small circuit board mouted right behind the display. A computer chip on that small board communicates with another chip on the main control board mounted in the rear wall. Your situation could be a bad actuator switch, a broken paddle tab, possibly a bad door switch (the fresh food doors must be closed to dispense), or a bad electronic control.
Jun 05, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Bottom Oven Does not work - F64 Code on Panel
If you look under the bottom door you will see a 3/4" tall slot the entire length of the door. This is where the cooling air blows out. In the middle of this slot is the air switch enclosed in a 5" long metal housing. You can see a thin metal paddle sticking out of each side of the housing. These paddles are spring loaded to angle slightly back. When the fan is on, the airflow will push the paddles forward. If they do not move forward, then you will get the error code. The simplest solution is to vacuum out all of the normally collecting dust that keeps the paddles from moving. To better access and clean the area, the black trim piece that forms the slot can be removed by unscrewing the two retaining screws. That can be more easily accomplished by first removing the lower door. This is very simple. With the door fully open, rotate the small metal clip on each hinge so it hooks over the protrusion on the other part of the hinge. Then lift up on the door (close it part way) and slide (pull) the door and hinges out of the hinge slots. There is no need to remove the entire unit from the wall.
Sep 24, 2006 | Thermador C302U Electric Double Oven
Zanussi 24 in. DA6153 Free-standing Dishwasher Logo
193 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
