Question about Kohler Fort© Single Lever Handle Kitchen Faucet with Side Spray Polish
Rubber cover has come off the spray control button
My unit has the tall curved faucet, which pulls out and entends . On the bottom of the faucet end there is a button which switches the water from stream to spray. That rocking button has a small black rubber cover over it. Somehow just the rubber cover has popped off. The faucet still works properly, but I cannot get the rubber cover to snap back on.
5 Suggested Answers
erickg
  • 116 Answers
SOURCE: Srayer leaking down the hose from pivot joint near spray head
there is an oring in that connection that is most likey bad. turn water off and disconnect coupling to spayer. remove the black oring and match it up at your local hardware store. when installin it lubricate it with vaseline for ease of insatlltion and to help protect it during installation.
Posted on Apr 21, 2009
  • 54 Answers
SOURCE: brand new faucet, on central aerator setting (not
Aerator ,sounds like it is not on right ,maybe cross threaded,or just not tight
Posted on Apr 13, 2010
  • 4345 Answers
SOURCE: Just lost pressure. Only a very small stream of
First try the tip ariator. it can plug up. then you have to check the inlet system, which includes shut off valves, hoses to the faucet and the cartridge. It is the cartridge that has the small openings, but shut off valve seat material falls back into the feed channel. I usually remove cartridge, cover with a towel and turn on feed water briefly. Often I get little pieces.
Posted on Oct 27, 2010
jazmann5
  • 4 Answers
SOURCE: Faucet makes noise when turned on but produces only a tiny stream of water
sounds like u got some kind of blockage in it take apart and clean
Posted on Aug 13, 2012
Need to tighten my ladylux
Grohe has a special tool that is used for installation that comes with the faucet. You have to remove the pullout spray and remove the curved neck of the faucet by pulling out. Insert the tool in the main body and tighten from above. Most plumbers will keep this tool when installing. I don't know if Grohe still uses the same system still today, but they did in the past.
Sep 03, 2013 | Grohe Ladylux Cafe Faucet with PullOut...
The faucet is loose on the sink how do i tighten it?
if you look under the sink at the bottom of the tap there should be a long threaded screw with a nut fastening it to the sink by a curved metal bracket and a rubber washer,( try tightening this.)sometimes the bracket and washer corode if they have then you will have to replace them
Aug 17, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
How to pull the lever off the top
There is a set screw under the handle lever maybe covered with a small cap or bottom type cover. remove that cover if it's still there and loosen the set screw and pull the handle off.
Feb 12, 2011 | Danze D403412 Melrose Single Handle...
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
Replace button on pull-out sprayer
With your faucet in the off position pull the sprayer out. Unscrew the hose that connects to the sprayer. This lets you take the sprayer to someplace where you can sit down. The front of the sprayer where the water comes out unscrews as well. You may need to use a nonslip mat or a piece of rubber but you can undo this by hand. Once you have this off a small piece (airator) can come out that helps control water flow into a steady stream instead of the way water comes out of a garden hose with no nozzle. form here you'll be able to see how the old button fits into the sprayer, pop it out and replace with the new one. Assemble in reverse.
Feb 16, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
May 30, 2009 | Blanco Classic Single Handle Faucet with...
My paper is jammed in the back roller of the printer...I can see it but can't get to it...does the back come off?
Yes.
Pull back cover ALL the way down.
remove 2 silver screws
pull off back cover...difficult but doable
remove tall gray cover on left
remove black wiring cover on right, unplug 2 connectors and keeper
remove curved feed guide in front of fuser bottom.
pull out fuser
reassemble
Dec 03, 2008 | HP LaserJet 2430dtn Printer
Kohler Fort© Single Lever Handle Kitchen Faucet with Side Spray  Polish Logo
102 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
