Question about Hotpoint WMA54 Front Load Washer
Wm54 door locking light wont come on - Hotpoint WMA54 Front Load Washer
  • Hotpoint Master
  • 17,129 Answers
IF the machine starts it is related only to a failure of the light, the connection or the wiring. If not there is fault in the main circuit unit of the controller.
Posted on Dec 31, 2012
2003 VW GOLF REAR door wont open
The rear door lock actuator has failed in the door locking unit this is a common problem you can manually unlock the door to replace the latch if you didn't have the deadlocking on if you cant try pressing the locking button twice so when the car is locked the flashing red light is not blinking ie off on the drivers. Doing this usually causes the faulty lock to release the dead locking so you can pull the inside handle to unlock the door.
Oct 13, 2016 | 2003 Volkswagen Golf
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Door lock light wont register with door when machine is turned on and cycle wont turn on.
if the door is locking but no light comes on it will be worn motor brushes
Jan 27, 2012 | Hotpoint Washing Machines
Door open indicator light stays on , automatic door locks go on & off while driving and dome light and outside mirror lights wont go off after the car is turned off
i would hazard a guess and say that wires in the rubber boot from the door pilar to the door are damaged or the connection block in the door pillar in this the terminals are corroded or something similar
Nov 22, 2011 | 2002 Mercury Sable
Door light in dash stays on, interior lights don't work and auto locks wont engage.
hi ya it seems one of the door switches is broken or disengaged on each door frame you will find a push in switch witch operates the interior light, door warning light on dash and remote locking if one of them is not working it will show on dash as a door not closed it will prevent the interior light from working and also stop the auto locking system from working properly the locking system is connected to the interior lights
Hope yhis helps
Dec 09, 2009 | 2003 Ford Windstar
Lights flickering
The Lights Flickering is most likely a defective Voltage regulator in the Alternator. Use a Volt meter to determine this.. I think its isolated from the door locks.. Im not good on door locks.. So not much help there.. But hope what lil bit I do know helped ya. thankx
Mar 11, 2009 | 1992 Chevrolet S-10 Blazer
Indesit washer wont run
the door lock light flashing indicates that the door has not locked or not shut correctly,is the appliance is under 5 yrs old open the door and check the door catch,there are two gaps either side of the catch,if you look into the gaps you should see a metal pin,if the one at the bottom is not there then thats why the door wont catch,there are some screws around the door frame if you take them out and just pry apart the door frame by the catch you will see the pin at the top,push it down till you see it at the bottom gap,refit and test.
Jan 24, 2009 | Indesit W 123 Front Load Washer
Please help , tell me why door is locked, on h 2 kenmore washer,
THANK YOU,
still nothing,
red doorlock light on, wont do anything,
I have to unplug so it will shut off,
when I plug in and hit start, red light stays on again,
Mar 28, 2008 | Kenmore 4292x Front Load Washer
My Hotpoint Aqaurius WD62 door is shuting but the door lock light wont come on!
you may need a switch but not a door see if you can adjust the door and try shutting it hard as front loaders close snug because of the rubber boot check your power too
Mar 02, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA54 Front Load Washer Logo
24 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
