Question about Sony Playstation 3 (PS3) Console
Turns on then off with blinking red light
I hooked my playstation up to hdmi i dont have hdmi no more so i tryed swithing back to av cords but now it just turns on then turns right back off with blinking red light is it stuck between hdmi and regular tv
    Problem Solver:
  • 5 Answers
Turn on your ps3 but keep your finger on the touch sensitive on button for 5-7 seconds, the sytem will beep again and all pictures are back to standard def. worked for me, so should work for you. good luck.
Posted on Jul 31, 2009
Playstation 3 works fine useing the av hook up but won;t work with hdmi cable hook up.
First, make sure your TV is on the appropriate input for the plugged in HDMI cable. Once this is completed, turn your ps3 on. If the screen comes on and is black, turn the ps3 to standby (red light is on) and hold the front power button until the console beeps a second time. This will usually force the ps3 to recognize the hdmi input and will bring up the menu to configure the AV settings.
Aug 13, 2014 | Sony Playstation 3 (PS3) Console
Playstation 3 shuts down and cant reset
Does it blink red or yellow lights? That's a sign of hardware failure and the system needs to be serviced.
May 14, 2014 | Sony Playstation 3 - System - 500gb -...
Im trying to hook up a HD A/V combo cable to my led jvc and the tvs missing one connect part. Im only gettinf black and white but the guy insisted that it was the right cord. What cord do I need?
You don't need a ikonvert box if you tv has a AV out (monitor out on picture) then all you need is an AV cord sorry if this is not helpful
May 25, 2012 | JVC Televison & Video
I properly connect my ps3 and switch it on but it does not show anything on the screen what may be the problem
Hook up a/v cord and have it on standy (red light)...push and hold power button for about 7-10 seconds or until you hear it beep......Let off...wait another 5-10 it on now????? if not your audio/video card in it might have went out....
Apr 01, 2012 | Sony Playstation 3 (PS3) Console
Hi, have had bedroom decorated and playstation had to be disconnected for few days,, now plugged back in and not playing a dvd or a game,,,any ideas?? the lights come on ok but no picture on screen,, tv...
double check all your cords and that they are hooked up tightly and correctly.
if that fails try hooking it up using the AUX (yellow,white,red) cord. It could have been reset which means if you were using a HDMI output it was set back to default AUX.
and finally try using a different HDMI cord, everything goes bad eventually
Aug 20, 2011 | Sony Playstation 3 (PS3) Console
Hi our PS3 has no sound or picture. It does have the green power light on.
What is probably happening, is your PS3 is set for the wrong type of output. If you are using an HDMI cord, try switching to the AV cables that came with your PS3, and set your TV at the appropriate input to correspond with the AV hookups, and see if the picture works then.
If you are using the AV cables, it may have been set to HDMI accidentally. You need to use an HDMI cord, and hook the PS3 up to an HDMI compatible TV or monitor, and select the HDMI input. Once you get the picture working, go to Settings>Display Settings and set the display you wish to use.
May 16, 2011 | Sony Playstation 3 (PS3) Console
Ps2 turns on and tv is on correct channel. We hear it but it does not show up on tv screen.
This is could be two problems 1 the cords 2 the connections
try putting a new set of cords if that dont work you have a bad connector on the tv or on the ps2 also try hooking up with av cables and hdmi cables/
Jan 23, 2011 | Sony PlayStation 2 (PS2) Console
The picture on my t.v when i turn on my ps3 goes black and white with a section of it at the top gone a fuzzy green colour. how do i get rid of this and put colour back on the screen
First of all hold down the power button for 5-10 seconds. YOu should hear a couple of beeps. That is resetting the video to the ps3. Power it back up. If you have it hooked up through hdmi try the other av cordes it came with. ALso try unpluging and plugging back in the av cords. If that does not work then I dont know.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
Playstation3 cant turn on><
try turning the main swith on and off a few times, then power the front.
let me know
Aug 02, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
  1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
456 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
