Question about Sungale STB266 cloud tv box
I need to know what the cable #'s are in order to purchase the cables needed to adapt this to my non-HD television. Television has only standard av input/output "cable" type connectors.
The HDMI connector cable is not an option on my television. I need to know what the cable #'s are in order to purchase the cables needed to adapt this to my non-HD television. Television has only standard av input/output "cable" type connectors, while box itself only has "jack" like connector ports. As there are literally thousands of cables available for a myriad of different connections, I see no feasible way to do a search myself.
  • Sungale Master
  • 4,164 Answers
There is no magic cable fix .
What you most likely need is a hdmi to rca converter
google search mini hdmi2rca
this device seems like the most sold device but there are several posts on its quality
https://www.youtube.com/watch?v=aPYPXrmRfow
https://www.youtube.com/watch?v=Did9JwlDocc
https://www.youtube.com/watch?v=i5u1n4VTF0Y
this is another device
but picture quality is questionable
https://www.youtube.com/watch?v=6ir4ZRvdvCg
here is another device
https://www.youtube.com/watch?v=_YCfHZF77EA
so you need a hdmi cable and a rca cable.
this youtube video rates several of the converters available
Posted on Jun 12, 2017
I need help setting hooking up my DVD player to my hisense tv
There are 3 options for connecting a DVD player to a television. HDMI, Component or VGA. The most common, and best, these days is HDMI which requires 1 cable, called a HDMI cable, between the player and television. These input / output sockets are clearly marked & there is usually about 3 of them on most televisions. HDMI 1, HDMI 2, HDMI 3. The next is component. These consist of 4 separate connections. RED, GREEN, BLUE & YELLOW. Again simply connect like to like. The third (VGA) are RED, WHITE & YELLOW. Same deal, simply connect like to like on player and set. Once one of the connections are made select SOURCE on the television remote and select the connection that you have made. Cheers
Dec 14, 2016 | Televison & Video
Hdmi cable for 40" led TV WHAT ARE THEY FOR
The hdmi cable is used to connect the tv to devices so it can be displayed on the tv. Devices such as, but are not limited to, computers, bluray/DVD players, gaming consoles, etc...
For channels, you have two options.
1. You would need to purchase a cable package from one of the options in your area. They will run a line I to your house and provide you with a cable box in which you connect the cable box to the tv via hdmi cable.
2. You can purchase an antenna and plug it into the tv. Run the channel search and you'll have those channels. Some TVs may have built in antennas but if yours doesn't, I'd go for a simple antenna from target or best buy. Or you can purchase it online.
Thanks!
Sep 22, 2014 | SEIKI Digital SE40FY19 40" LED TV...
Hyundai hlt 3270 can't connect to my direct tv hd box
I know this is an old post but the solutions helped me just recently. My hyundai does not have a hdmi port and I was very frustrated. Luckily I had an old rca connector. The green blue and red cord with the white and red audio connector. If your hdmi box does not have this option you are sol. Call your cable company and request one. This is the only solution. Hyundai tvs are garbage. Good luck.
Aug 28, 2012 | Hyundai ImageQuest HLT-3270 Television
How do you enable the pioneer plasma pdp ro6fe HDMI settings? My HDMI input options do not currently allow selection & adustment
just plug in the HDMI cable from what ever equipment your using,then switch it on, put the other end into the back of the tv, take out any scart cables you have plugged in, just for now.
then find your AV source button on your remote, press it until it says HDMI.
the chances are,if it flickers or wont show, then you'll need to hook up the external equipment by scart cable & go into the picture settings & change it to a lower rez. (The tv wont be the problem)
i can't help you any more because you haven't said what it is your trying to do or hook up.....SKY BOX, DVD PLAYER, GAMES CONSOLE...e.t.c.
Or what make of TV it is.....
Sep 10, 2011 | Televison & Video
How do i hook pc up to tv
Your TV will accept Component, Composite, HDMI and DVI-I inputs. Your computer will need to have a video output that matches one of those on in the list above. The DVI-I or HDMI will provide the best looking picture and is by far the most popular on modern computers. Both the DVI & HDMI jacks are for digital signals.
The standard, run-of-the-mill VGA jack on your computer can be adapted to connect by purchasing a quality cable with a DVI-I connector on one end and a VGA connector on the other. You can also purchase an adapter that will do the same thing instead for less money. If you need a long cable, purchase a quality cable instead of the cheapest one available. You will see a difference with cheapo cables. This will send video to the TV, but audio will be from the computer, unless you send the stereo signal from the computer to a seperate amplifier and speakers.
The HDMI jack will send both video and Dolby Digital audio to you TV all in one cable / connection. Of course, you need a HDMI jack on your computer and an HDMI cable to interconnect. Upgrading a desktop computer with a new video card that has HDMI jacks might be the way to go - but if you're using a notebook, this may be impossible to do.
Good luck! If my answer was helpful, please rate it "4 thumbs up." Thanks!
Jul 27, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I just wanted to know how to hook up my lg 3d blue ray player. i'm not home so i can look at anything. I need to know how many HDMI cords I may need to plug in my tv, digital cable box, the a/v...
You can do this two ways.
Way #1 connect your cable box to your a/v receiver with one hdmi cable. Connect your blu ray player to your a/v receiver with a second hdmi cable. Lastly, connect a third hdmi cable from the a/v receiver to the television. (3 hdmi cables needed this way)
Way #2 connect your cable box to your television with one hdmi cable. Connect your blu ray player to your television with a second hdmi cable. Connect your a/v receiver to your television with a RCA/composite a/v cable or with a fiber optic cable. Connect your cable box to your a/v receiver with a fiber optic cable or RCA/composite a/v cable. Lastly connect your blu ray player to your a/v receiver with a fiber optic or RCA/composite a/v cable. This method takes 2 hdmi cables and three sets of fiber optic and or RCA/composite a/v cables.
Can't get more specific than that without having the a/v receiver's model number, type of cable box, and television model number. Hope this helps.
Jul 22, 2011 | Audio Players & Recorders
Satellite/Cable Coax "DTV/TV" in-port broke
Replacing connectors on televisions can be a pricy endeavor. If you can't afford to bring it into a service shop, you may have luck by switching to a different type of connector. If your Satellite or Cable receiver has an HDMI output, your best bet would be to buy an HDMI cable and hook that up instead - the quality would actually be better than coax. Failing that, depending on what kinds of outputs your sat/cable receiver has, you could also go with (in order of preference) component video (a cable with five ends, red/green/blue, plus two for audio), s-video (a round metal connector with four pins in the middle), or composite video (similar to a component video cable, but only three ends - red, white, and yellow).
Any of the above cables (including the HDMI) can usually be found at your local big box electronics retailer for under $30.
May 02, 2011 | Televison & Video
I have a cable box connectin and cannot choose HDMI as a source. I had HDMI as the source for about two years and then something must have changed. I have verified the HDMI cable is not the problem. Page...
The manual is telling you that your "source", whatever you are connecting to a particular HDMI port, needs to be turned-on in order for the TV to detect it. Make sure that the HDMI cable plugged into the correct HDMI port for each device (TV & cable box) and that the cable box is on. Does the cable box HDMI port need to be selected in order for it to be functional or is it on all of the time? Check your cable box instruction manual for details on the proper way to enable (turn-on) or disable the various outputs if needed.
Let me know if you need additional info.
Feb 26, 2010 | Samsung HL-S5086W 50" HDTV
I need to know how to run my ps3 thru the optical wire to my hdtv
Before you start ensure that you read the TV instruction manual to know which resolution supports it. Do not switch on the TV and your console
You can connect your Playstation 3 to your TV in three different methods:
  1. Connecting with an AV cable
  2. Connecting with an HDMI cable
  3. Connecting with an Optical Cable
Connecting with an AV Cable:
  1. You are supplied with a Composite AV cable which would typically look like the below image
  2. Connect the AV Multi Out Connector to the socket on the back of your PS3 Console.
  3. Match the colors of the Jacks with the connectors on the TV which says "Video in".
Connecting with an HDMI Cable:
HDMI cable is not supplied with the PS3. You need to purchase it seperately. This cable would enhance the audio-video quality of your TV.
  1. Just connect one end of the connector to the HDMI OUT connector socket on the back of the console
  2. Connect the other end to the socket on the back of your TV which says HDMI IN.
Connecting with an Optical cable:
You need to purchase an Optical cable if you wish to connect your PS3 console through a digital audio device (Home theater, AV receiver etc.,). You need to connect Video ouput seperately with a help of Video output cable (HDMI, AV Cable etc.,)
  1. Connect one end of the optical cable to "Audio Out" socket on the console
  2. Connect the other end to the audio receiver.
Note: You can also connect your console to the Internet to use the Playstation 3 internet capabilities. Here's how you do it:
The Playstation 3 only supports 10BASE-T, 100BASE-TX and 1000BASE-T type networks. It needs a High speed internet connection. Do not connect it to a standard telephone connection or cables that are not supported. It might cause a malfunction or damage to the system.
Dec 11, 2008 | Computers & Internet
Sungale STB266 cloud tv box Logo
Top Sungale Computers & Internet Experts
David Payne
David Payne
Are you a Sungale Computer and Internet Expert? Answer questions, earn points and help others
