Question about John Deere Garden
Having a hydraulic problem? Checked hoses,fittings,and fluids all ok. Plow still not going up
Is that valve a 2 -part valve
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 30 Answers
Check your hydraulic pump to make sure it is operating correctly. If it is then take it in to the repair shop and have the diagnose the problem.
Posted on Dec 31, 2012
Western plow will not go left
There is a hydraulic block/valve. Replace it.
Jan 03, 2017 | Cars & Trucks
Curtis plow stops angling right
Is it hydraulic or electric. I believe hydraulic. If so ck fluid level, ck hoses for kinks, ck hydraulic pump & belt operation & lube linkage. While you ck for any damage, heavy damaging rust or bent framework on the plow hinges & linkage.. Good Luck .
Nov 26, 2015 | Cars & Trucks
Plow will only turn to the right
It is electric over hydraulic most are, make sure the solenoid is clicking when you try to turn the plow. One side is working see what one is clicking the other one would be the culprit. If the solenoid are working then the problem is internal to the valve body. Make sure you haven't bent the rams that will cause this as well. If you have you will hear the hydraulics trying to over come this. Make sure the power is getting to the solenoid as well to make them click. Sometimes the switch inside the cab will break inside and not send the electric signal to the solenoid. inside when they do this they are moving a spool valve to redirect hydraulic flow of fluid to one ram or the other. Hope this helps :-)
Jan 24, 2015 | Cars & Trucks
Plow will go up and down but not angle
Electrical problems possibly....or is it hydraulic and electric? Enough hydraulic fluid in system?
Jan 10, 2015 | Cars & Trucks
The snow plow in my truck is not moving after the cool weather we hade last night in NJ. The motor still runing but my plow is not going up,left or rigth, but is going down
Dis you check the hydraulic fluid in the pump? If the fluid is low, you probably have a broken hose or a blown seal on one of your rams. If the fluid is full, you probably have a bad pump.
Jan 25, 2011 | 1997 Ford F350 Crew Cab
Plow cylinders seem loose, causing plow to move back and forth. 7.5 HT plow. could this be from low hydraulic fluid? If so what fluid is recommended
Have someone operate the plow as you look for loose parts while it changes direction. Low fluid would likely result in incomplete movement and high pump wear if it continues. You may need to bleed air from the system. You will need to check with the original manufacturer of the plow to find the correct hydraulic fluid and the fluid level required. Good luck!
Jan 22, 2011 | Garden
Garden Logo
177 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
