Question about HEWLETT-PACKARD Pavilion DV6-1243CL Notebook
Where is the rtc battery located in an HP Pavilion dv6-1243 cl
  • HEWLETT-PACKARD Master
  • 7,627 Answers
Open the bays on the bottom of the laptop, it may be under the Memory Mods. Take a look at this for a general idea: http://www.youtube.com/watch?v=ZoYVztAcCiQ
Posted on Dec 31, 2012
RESETTING BIOS FOR HP DV2100
This is normally hitting the Delete key at starting up during BIOS posting. There should be an exit menu where you can load BIOS DEFAULTS. If you can't find it the other way to clear CMOS is to remove the battery. Read the Maintenance and service guide.
Prepare the computer for disassembly (refer to Section 5.3, "Preparing the Computer for Disassembly," for more information).2. Remove the real-time clock (RTC) battery (refer toSection 5.5, "RTC Battery," for more information).3. Wait approximately 5 minutes.4. Replace the RTC battery and reassemble the computer.5. Connect AC power to the computer. Do not reinsert any batteries at this time.6. Turn on the computer
Clearing CMOS will set the BIOS to its DEFAULT setting.
The only "resetting" of a BIOS is setting DEFAULTS.
Mar 26, 2013 | HP 417035-001 - HP Pavilion dv2000 Series...
How to get bios password for HPDV 1000 Laptop
to reset the bios password you need to remove the RTC battery for about 2 or 3 minutes, unfortunately the RTC battery on your comp is in a hard to get at spot, here is the service manual link https://docs.google.com/viewer?a=v&q=cache:Qnll0FDGyLMJ:h10032.www1.hp.com/ctg/Manual/c00312379.pdf+HP+DV1000+manual&hl=en&gl=au&pid=bl&srcid=ADGEESjzOpN2_LzzpCtFcLAfb1GrMzBa4i-cpUBBFBw4OX8ZGupLrTjOGEt6WsFxtfHp1R29eL6L5PRZw8qlrkfJ0_A5Gu1DvHRbeDza3CZP1gj3EumC2ZGWlHkZ2IrBi31LPC6Oc23k&sig=AHIEtbRkO_TzCI2L6EuzJDQZcdvA8qh4Mw&pli=1
good luck
Mar 05, 2012 | HP Pavilion dv1000 Notebook
My hp dv9000 cant update or correct time and date
If the laptop doesn't keep the correct time, and date, it's because the CMOS Battery is shot.
In the HP Pavilion dv9000 series of Notebook PC's, the CMOS Battery is named RTC Battery. (Real Time Clock )
Replace the RTC Battery.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=1842189&
On the above page, scroll down, and left-click on the file name in blue -
HP Pavilion dv9000 Notebook PC - Maintenance and Service Guide
Ignore the following if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds, before the first page comes up.
At the top of the PDF file is the page number box. It is to the Right of the Down Arrow.
You can use the Down Arrow to go page by page, until you arrive at the page you want, or you can do this;
1) Put your mouse cursor in the page number box.
2) Left-click once
3) Type the page number
4) Press the Enter key
Or you can use the Bookmarks menu to the left.
Go to Page 131.
5.7 RTC Battery
A) Remove ALL power. Remove the AC adapter (Charger) if plugged in, and remove the Battery. (Main battery)
B) I would advise buying an ESD wrist strap, and wearing it.
Connect it's alligator clip to a good ground source.
(Electro Static Discharge)
Average cost is around $3 to $6.
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
Use an ESD wrist strap, and breathe easier.
Don't know if you have ever replaced a CMOS Battery in a desktop computer before, but the Battery is the same.
It is just soldered to two wires, and put into a small plastic bag that has a cable coming from it, with a connector on the end.
(NO, I do not recommend trying to solder wires to a CR2032 battery! May go BOOM)
http://www.vendio.com/stores/CMOSBATTERIES/item/hp-cmos-battery/replacement-cmos-rtc-battery-f/lid=3032230
The above is from a quick search. Scroll down for laptop compatibility
As you can see in the Service Manual, you need to remove;
1) The Memory Compartment Cover. Page 28
Table 1-8, Bottom Components
Number 6 points to the Memory Compartment Cover.
The RTC Battery is fixed to the laptop with double-sided tape.
New tape should come with the new RTC Battery.
If you have any additional questions please post in a Comment.
Regards,
joecoolvette
Jan 29, 2012 | HP Computers & Internet
Can you please tell me where the Cmos battery is located and if there are any special techniques that need to be employed to successfully remove and replace it? It is (was) a DV6000 series laptop with a...
Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
1. Remove the memory module compartment cover
2. Disconnect the RTC battery cable 1 from the system board.
3. Remove the RTC battery
The RTC battery is secured to the computer by double-sided tape.
Reverse the above procedure to install the RTC battery.
Sep 12, 2010 | HP Pavilion dv6000z Notebook
Need to replace RTC battery in dv7-1240 hp
Battery is usually located on bottom of laptop usually takes 1-4 screws to get it out.
There are usually 2 compartments on the bottom, one for RAM memory upgrades and the other compartment is the battery.
May 25, 2009 | HP Pavilion ze2000 Notebook
Bios lock
Try this link
Easiest Method would be to follow these steps
1: Unplug Power Cord from Power Supply in Back
2: Open Case
3: Locate Round Battery on Motherboard
4: remove Round Battery
5: wait 5 Minutes
6: replace the battery
7: Close case and plug power back in.
This should solve your problem.
If not try the solution below
Clear cmos
Typically to clear the cmos there are 3 pins with a 2 pin jumper, near the battery.
Pin 1&2 clears the cmos and pin 2&3 is default, do not do this when the system is running or it will kill your motherboard.
Nov 11, 2008 | HP Pavilion dv4000 Notebook
Power on password
Its not possible , the only thing you need to remove the RTC battery inside the laptop and reinsert so that the power on password will get reset.   THE RTC BATTERY LOOKS LIKE A BATTERY WHICH WE PUT ON OUR DIGITAL WRIST WATCHES.
Oct 20, 2008 | HP Pavilion tx1000z Notebook
Location of RTC battery
The CMOS battery is on the back-side of the motherboard on the nx9030. You'll have to lift the motherboard up to gain access to it.
Aug 25, 2008 | HP Compaq nx9030 Notebook
Don't know the Power on Password
Is the bios protected by the same password, usually it isnt. If you can get on the bios you can disable that HDD password. Other than that I dont know much about HP's and their set ups, sorry.
Jan 26, 2008 | HP Compaq nc6320 Notebook
HEWLETT-PACKARD Pavilion DV6-1243CL Notebook Logo
63 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
