Question about Teac PD-D2610 5-Disc CD Changer / Player
Teac D2610 5 disk CD player - Plays 1 CD and stops. After that it does not think any more cd's are there and keeps sequencing around and around.
Problem is not consistent. Sometimes will not play even one and just goes into its sequencing mode. When it does this it does not indicate any CD's by the front panel.
VOTIT
  • 2071 Answers
SOURCE: CD player won't play disk and says "no disk"
The problem of "'no discs'"displayed is in the mechanism in the roller thats moving back and port bringing the lense set .The old grease thier is already hardened that cause the problem.Clean that by using a lighter fluid or like that fluid to take the old grease,and put it with a new one first class grease type-A grease put only a little grease and wipe the lense with a cotton buds without any chemicals on it .Try this solution so performance will be better.
Posted on Jun 18, 2008
  • 92 Answers
SOURCE: teac pdh-300
Generally something that is time related with a CD player indicates that there is something stuck in one of the gear teeth that drive the laser back and forth to play different areas of the disc. A very small piece of dirt/sand can get inside and stuck in a gear tooth preventing the laser from moving past that point on the CD, in your case it's about the 40 minute mark........you can try skipping to say the last song on the CD which will advance the laser unit a bit more quickly than if you were to let the disc play through, that might dislodge the piece.
Another scenario could be a cracked gear in the same drive area. This is not as likely as you say it plays for 40 minutes or so. There is a piece that is attached to the laser which has gear teeth in it that mesh with the gears that move it, I'd suspect it's in there.
Make sure you do not have the player plugged in when you open it, the laser is capable of damaging your eyes.
Posted on Oct 07, 2008
SOURCE: TEAC CD player jammed
I had the same problem in 2007: I removed the cover and manually encouraged the cd drawer to open. It has been working ever since.
Posted on Sep 14, 2009
  • 3 Answers
SOURCE: Display doesn't work on TEAC PD H300mkIII
I had the same issue today. I found that opening the unit you can see that there is a white ribbon cable connecting the head unit to the main board. removing this cable and re-inserting it the connector fixed the problem. The display now works again...hope this helps
Posted on Nov 21, 2009
  • 65 Answers
SOURCE: Teac CR H100 CD player just clicks when I press
it sounds like it is the motor that spins the disk most likely not worth replacing unless the unit has high sentimental value to you
Posted on Sep 23, 2010
Cd skips
my best conclusion would be your player might be copyright protected to the point were you'd be able to hear the music but wouldnt be able to enjoy it.... different player or better quality CD-R's would be your best best. . .
Dec 29, 2012 | Teac AD-800 CD Player
Whats the difference between the teac rw-cd22 and rw-d250
I have a Teac RW-CD22 and it keeps telling me there is no TOC> I am unable to record a disc.
Dec 04, 2010 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
Teac CR H100 CD player just clicks when I press play and if it plays, it stops very soon. Is this teminal
Sep 23, 2010 | Teac Audio Players & Recorders
Put a cd in playey, plays for around 20 seconds stops playing then restarts playing and keeps doing the same
sounds like the laser tracks might need regreased to me, does it also skip when playing ?
Feb 07, 2010 | Teac PD-H300 CD Player
How to copy CD from Laptop to empty cd
Sounds like you made a data disk with MP3s and not an audio cd.
To play on a "regular" CD player, you should burn an audio cd.
Different burning programs have different options for this.
Jan 21, 2010 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
The unit rarely plays CD's anymore. It spins the
most likely a bad laser lens or out of adjustment.
Sep 21, 2009 | Teac PD-D2380 5-Disc CD Changer
My teac dvd/cd player wont play some cds
Probably a codec problem on the notebook. rather than a drive problem. Try a 3rd party media player such as Real Player or Quicktime
Feb 15, 2009 | Teac CD-Rewritable W28E CD-RW Burner
Teac PD-D2610 5-Disc CD Changer / Player Logo
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
