Question about Garmin Nulink 2340 Nulink 2390 Battery
Unlink 2340 loading maps but does nothing
USB does not work either
Turn on, loading the map then shows computer usb connection then do nothing
You have to use the Navdesk software on your computer to load maps into Navman gps unit.
Google Navman support and go the link.
Mar 15, 2015 | Navman S30 Car GPS Receiver
My cousin have no CDROM and we want to install her wireless usb adapter by searching its guide ang manuals in internet.
Hi Ceejay,
I got your issue and you need the manual for your WUA -2340 wireless adapter and here is the link
ftp://ftp10.dlink.com/pdfs/products/WUA-2340/WUA-2340_ds.pdf
Please do give me thumps if its useful
Thanks & Regards,
Prema
Oct 09, 2010 | D-Link WUA-2340 (ASKU55774) Wireless...
My Garmin gets stuck on the garmin screen saying loading maps. I have tried to the reboot option of holding down the right corner, power on, and then click yes to erase maps, however when i click yes,...
Borrow a USB cable to plug it into a computer. I just had this issue with the nuvi 1300, and that was the only way to fix it.
Holding the power button for 10-15 seconds would attempt to restart it, but it would just get stuck on the "Loading Maps." section.
I was able to fix it by simply plugging it into a PC's USB port, where the unit started up for purposes of data transfer. Then I unplugged it, and it restarted properly.
Mar 28, 2010 | Garmin nuvi 1300 Car GPS Receiver
My d-link WUA-2340 is only running on 54mbps
What router are you using?
Most routers sold until recently have been 802.11b/g (54mbps) routers, it must be 802.11b/g/n to run at 108mbps.
The adapter will self adjust to the older standard if it cannot detect if the faster standard is available.
Jul 29, 2009 | D-Link WUA-2340 (ASKU55774) Wireless...
The adapter doesnt blink, and wireless adapter is not found.
If it doesn't blink:
- try to uninstall it completely
- remove the adapter from the USB port
- install the software again
- leave the WUA-2340 out of the computer's USB port until you have installed the software
- when the installation routine tells you then insert the adapter into the USB port
- you follow the instructions from there.
It should work if you do it that way.
Jun 20, 2009 | D-Link WUA-2340 (ASKU55774) Wireless...
D-Link WUA-2340 RangeBooster G USB Adapter Installation Issue
http://support.dlink.com/products/view.asp?productid=WUA-2340
Mar 07, 2009 | D-Link Rangebooster G USB Adapter...
Can't load wua 2340 driver
Here is the correct driver install package, download the zip file to your desktop, then double click the zip file to get to the setup.exe file for the dlink adapter, first it may ask you if you want to remove the driver and all its components, say yes, go ahead remove all previous dlink drivers. Then, after the driver is gone(look in your program list to make sure its gone), doubleclick the exe file again to install the driver correctly, insert your usb adapter when prompted to. You are better off using this dlink adapter with an external base with a usb extension cable so you can mount in by your window(to catch the networks)
I am using it right now (wua-2340), it comes in low, but with a fast download speed even fast enough to stream video or audio.
click on link below(if you can't, copy and paste the link into your IE or furefox, hit enter
the driver date for vista and win xp is from 2008-
http://www.dlink.com/products/support.asp?pid=473#drivers
Feb 09, 2009 | D-Link WUA-2340 (ASKU55774) Wireless...
Garmin Nulink 2340 Nulink 2390 Battery Logo
69 people viewed this question
Top Garmin Electronics - Others Experts
Are you a Garmin Electronics - Other Expert? Answer questions, earn points and help others
