Question about KitchenAid Architect II KEBS208SSS Stainless Steel Electric Double Oven
Kitchenaid kebc208kss03 makes loud noise
Make loud noise while using.
Candy fl 134 x uk , single oven ..... oven works fine ... clock/ timer is dead and keeps making clicking noise , when not in use i power it off ... do i just need to replace the clock ???? Thanks roy
[n 75 years I have never heard of anyone powering off an oven when not in use . those little clocks do not use enough electric to worry about waste
Feb 25, 2017 | Candy Ovens
How do you set the clock?
Since you didn't state your oven name and type,what you can do is google it.just do this as a example,k.How do you set a clock on a Kenmore oven?Then select from the options and their should be one to show you how to set your clock.
Jul 18, 2015 | Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Beko double oven the fan has started to make a loud noise and sometimes cuts out had oven 18 months
by loud noise do you mean squeeling squaking .
then its the fan bearing just order another fan motor.
Jul 25, 2014 | Ovens
Kitchenaid superba oven
What is the model number?
Jun 19, 2013 | Ovens
FAN NOISE in convection mode, as in a loud whirring sound, suggesting a problem with the fan. Any one else experiencing this?
FAN NOISE IS NORMAL BUT IF ITS SQUEELING THERE IS A PROBLEM WITH THE COOLING FAN. YOU DO HAVVE TO REMOVE THE OVEN FROM THE WALL TO REPLACE.
Jan 24, 2010 | KitchenAid KEBC107 Electric Single Oven
KitchenAid Architect Series KEBC278KSS Electric Double Oven displ
Our fan on our oven is super loud. Always has been. We have to keep the door open so that it will cool off asap because it is so loud. What's wrong?
Mar 11, 2009 | KitchenAid Architect Series KEBC278KSS...
DOUBLE OVENS FROM KITCHENAID
Redhead Do nothing and call the manufacturer. Your oven has one year warranty. Gendos...post back
Mar 22, 2007 | KitchenAid Architect Series KEBC278KSS...
KitchenAid Architect II KEBS208SSS Stainless Steel Electric Double Oven Logo
74 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
