Question about Coleman Powermate 27 Gallon Air Compressor
I would like to find info on the capacitors for my 27gal powermate air compressor
    Top Expert:
  • Coleman Master
  • 48,461 Answers
Suggest contacting the manufacturer first they know best Powermate Powermate generators air compressors pressure washers and air...
Posted on Apr 08, 2015
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
To be sure you don't get 'bit' by the capacitor, remove the power from the circuit and expose the capacitor (s) connections then short across them with an insulated screwdriver to ensure that they are discharged. Some electrical 'purists' that know all there is to know about electricity say you should NEVER short a capacitor....but that's a bunch of baloney. Who cares if you shorten its life expectancy a little bit. Its better than shocking the fire outta yourself. Some capacitors leak down quite quickly but you never know for sure without shorting across the terminals.
The accepted norm on capacitor start motors is to use a capacitor with NO MORE than 10% variance above or below the original capacitors rating. Try wwwgraingers.com for replacement capacitors or ereplacements.com as another choice. Or possibly McMaster-Carr.
    Problem Solver:
  • 5 Answers
? should be printed on them careful as they bite when discharging if you need replacement try mastertoolrepair.com they have them
not sure on best way to discharge them hope this helps
Posted on Jan 26, 2009
  • Danielle Julien Apr 05, 2015
    I'm also trying 2 replace my capacitor for a 27 gallon coleman powermater air compressor but the number is erased can't clearly make it out which makes it difficult to get the correct one for the said compressor
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
Need starting and running capacitors for 8-182852-nu century motor on coleman 6hp compressor. Thanks!
get the micro farad and volts of your capacitors, then bring it to the electrical supplies
Aug 23, 2010 | Coleman Powermate 60 Gallon Air Compressor
I have a Cleman 4 Gallon, 1.75 HP, Powermate air
When mine hums and trips, it is one of two things, Not warm enough, only does this when it is cold out, and 2 would be not enough juice, I have to have a 20 amp breaker or it doesn't run. And if I use a cord, it has to big. The slightest drop in amperage and it will not run, yours might have the same problem, mine is only 1 1/2 HP. It draws some 16 amps at start up and then idles down to 13 to run. A 15 amp breaker, forget it. Cold out, forget it. It wasn't just mine though, we did a house last winter and made one bathroom heated with a gas heater with 3 compressors in there just to keep them warm, there was no room for us. Hope this helps.
Jul 20, 2010 | Coleman Powermate 11 Gallon Air Compressor
I got me a compressor but do not have any info on it
All of the manuals (user and parts) for all of their products are at:
Assuming that you have the ILA3606056 - Owners manual direct link is:
http://www.powermate.com/pdfs/2007/11/29/manual_operators_manual_single_stage_cast_iron.pdf
Hope this helps, if so please leave feedback .. if not pls let me know and I'll try and help some more!
Feb 02, 2010 | Coleman Powermate 60 Gallon Air Compressor
Coleman black max air compressor
go to the coleman website, or to another site which shows how to identify the compressor by looks.
Aug 05, 2009 | Coleman Powermate 60 Gallon Air Compressor
Coleman powermate 27gal 5hp air supply line and regulater gets very hot and blowes off hose
Is a shroud of any sort been took of ? is there oil in pump assembly ? Is there a fan on this model? At what pressure does the compressor stop pumping (should be less than 135psi aroud120psi) are you using it over it's duty capacity ei:sandblasting....?
Jun 04, 2009 | Coleman Powermate 27 Gallon Air Compressor
Coleman Powermate 27 Gallon Air Compressor Logo
219 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
