Question about Vehicle Parts & Accessories
Autopage xt62, light stays on - Vehicle Parts & Accessories
NEED TO PROGRAM AUTOPAGE XT33 REMOTE
When I hold the valet switch like am ask the led light lights up and stays on no chirping at all but if I hold the valet switch when the car is in the on position I get a chirp help someone please
Jul 01, 2012 | Vehicle Parts & Accessories
The lights no longer blink when unlocking and do not come on when starting
you will need to check the fuse, located on the 5 pin harness at the main brain. It is white in color.
Dec 26, 2010 | RS855LCD AutoPage MultiChannel 2 Way...
I have the normal alarm Autopage AutoPage C3RS603
Nothing is hard to hookup just time consuming andf it all depends on how good you R with wiring how good R you..?
Jul 16, 2010 | C3RS603 2Channel Remote Start Module with...
The headlights are not working. Could this be
Usually no. The autopage system is designed to operate the parking lights only.
Apr 15, 2010 | 2001 Ford Mustang
Need to program autopage 5b remote
Note: This mode will only retain the last 4 remote transmitters programmed. If the transmitter memory is exceeded,
the security system will start deleting transmitters from memory in chronological order.
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in ON position. Within 15 seconds.
2. Push the Valet switch 3 times and holding in on 3rd push until a long chirp is heard then release the valet switch.
You are now in the Transmitter programming mode.
3. Press and hold any button of the transmitter until the siren responds with a confirming chirp, indicating the signal
has been stored into memory.
4. If you have additional transmitters (up to 4) that need to be programmed, repeat step 3 for each transmitter.
Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. 3 long chirps & 3 parking
light flashes will confirm exit.
Feb 17, 2009 | Megatronix - TW71 - 5 Button 2 Way LCD...
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
