Question about Olevia LT42HVi 42 in. LCD Television
I can't get a full screen on some channels.
    Sergeant:
  • 204 Answers
It's because of the digital transition. Most everything is in 16:9 ratio nowadays and the TV you have is 4:3 ratio.
Posted on Dec 30, 2012
Can't get a full screen on some channels
I AM NOT AN EXPERT ON TV'S BUT ARE YOU AWARE SOME STATIONS PLAY MOVIES WITH THE SCREEN SHORTENED? ITS DUMB IF YOU ASK ME.
Dec 30, 2012 | Olevia Televison & Video
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
My old Toshiba tv is stuck on widescreen, help..
this a problem with microprocessor signal, this will be difficult for to fix it yourself.
Every signal coming from tv goes to the CPU, you must have high skill for to repair and diagram. I can recommend you to get assistance from some repair shop TV for fix it. see the diagram and you will see the problem difficult.
God bless you
Jul 14, 2012 | Toshiba CF32F50 TV
Is there any way to get my tv channel back on 4 with no remote?
Try after amke a factory reset to your tV. Normally, aits remote control is needed to make it channel-4.
Apr 29, 2012 | Televison & Video
Left channels weak and statiky
Maybe your amp is bad? Swich your right and left wires around and see. If the problem moves your player is bad. If it doesn't your amp is bad. Doubt it is the amp though if it is all of your left channels.
Apr 19, 2012 | Dual XD7500 AM/FM/CD Receiver, Motorized...
The aspect ratio on the HD channels are full screen - which is correct. However all other channels have the incorrect aspect ratio. (reduced size) A solution please???
Many times HD channels will come in more clear, but with a smaller picture or widescreen view. There should be a button on your remote called 'wide' or 'zoom' and it will let you adjust the size on the fly. If you adjust the view while watching an HD channel, and you switch to a standard channel, you will have to change the ratio back. For other information and help with LG TVS visit http://www.lg.com/us/support. Thanks
Mar 31, 2011 | LG 42SL9000 42 in. HD-Ready LED TV
I cannot play full screen video in samsung corby plus
Samsung b3410 cann't strech video that y u can see full screen video.
Jul 03, 2010 | Samsung B3410 Cell Phone
Wiring Speaker to amp
remove all speaker connections to your amp. MAke sure the inputs are driving all 4 channels, and that the built in crossovers on the amp are all set to full range. Conect your full range speaker to each output channel one at a time and verify there is oputput on all 4 channels. If all is ok, then connect your rear speakers to the front(a) outputs of your 4 channel amp, and then use the second 2 channels (rear or B) bridged to drive the sub. Re-configure the crossovers for highpass for front (to drive your rear speakers) and lowpass for sub. This is the proper way to connect a 4 channel amp with a sup whle driving 2 full range speakers.
Jun 10, 2009 | Car Audio & Video
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Full screen view
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
May 21, 2008 | Vizio L32 32 in. LCD HDTV
Olevia LT42HVi 42 in. LCD Television Logo
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
