Question about Pioneer Audio Players & Recorders
Need to hook up pioneer a-88x to ex-9000 to sr-60 to f-443-can you help
They have diagrams but none for hooking all together
marsrover
  • 682 Answers
SOURCE: pioneer spec 1 and spec 2 hook up with RG 2 processor and audiosource eq 1
preamp out---------to equalizer in-------------equalizer out----to amplifier in-----------amplifier out----------to loudspeakers.
Posted on Jul 23, 2008
dunnbiker
  • 8546 Answers
SOURCE: how to hook up bose series 2 eq to onkyo tx sr 875 receiver.?
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! I see on the SR875 there are Pre Audio OUTS. This is easy.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Posted on Apr 25, 2009
SOURCE: NEED WIRING DIAGRAM
hope this helps,......http://www.nodevice.com/user_manual/pioneer/car_multimedia/avh-p5700dvd.html
Posted on Aug 01, 2009
  • 5 Answers
SOURCE: wndr 3300 net gear router wont work with hn 9000 hughes net modem
just buy a switch for hn9000.hughesnet and connected to ps3 .
Posted on Feb 15, 2010
  • 47 Answers
SOURCE: need wire diagram koiiler xm 7676
U CAN GET ALL UR WIRE DIAGRAMS FROM PIONEER WEBSITE JUST OUT IN UR MODEL NUMBER THEN TYPE IN WIRE DIAGRAM
Posted on Feb 28, 2010
I have a pioneer djm mixer 400,I hooked it up to 2cdj mk1002. I want to run them through my pioneer reciever.which is a vsx 1020.im having a problem.IT works okay,if i run the cd player directly to cd...
If your CD player works hooked up to the DJ board, then try hooking the line out of the board into a auxiliary in or line in in or record in on your receiver using the appropriate cables.Try the CD in first and if there is too much signal then use the CD/Tape in. You need to match the output signal of your board to the input signal of your amp. Hope this helps.
Oct 22, 2010 | Pioneer DJm 400 Professional DJ Mixer
Need wire diagram koiiler xm 7676
Feb 13, 2010 | Koiiler XM-7676W Car Audio Amplifier
I AM TRYING TO HOOK UP A CAR PIONEER CAR STEREO AND NEED THE COLOR DIAGRAM
Hello vickie_morto,
You can download a PDF copy of the manual here. The wiring diagram with color code is on page 51.
Hope this helps.
Jun 28, 2009 | Pioneer DEH-P3800MP CD Player
I need a wiring diagram for deh-p400, the old one...
No diagram available for 10yr old head...sorry:o(
Other than that, it should be easy to hook it up, I'm sure there's no sub-outs etc. Should have 4 sets of speaker wires bundled together coming out of the back of the radio chassis. Yellow, is switched power...all the speaker wires have a stripe on one of each of the two wires, thats the "common" wire. White is ground for the chassis.
Good Luck
Jun 14, 2009 | Pioneer DEH-P4000UB CD Player
Pioneer AVIC-N3. What wires power it on??
the pioneer avic n3 has a seperate brain system and there is a cable that hooks the two together its called like the 13 pin wire or something and once you hook the brain and the head unit together it will have the display and everything else
May 25, 2009 | Pioneer AVIC-N2 Car DVD Player
NEED WIRING DIAGRAM
Mar 07, 2009 | Pioneer AVH-5700DVD Car DVD Player
What equipment do i need
hi you will need the AV master, AVM-P700/800 or 9000
nothing else will work with it.
Mark
www.blueice-electronics.co.uk
Jul 23, 2008 | Pioneer AVX-P7300
Pioneer prsx720 wiring question
If the subs are dual 4 ohm voice coils, you could hook the DVC's of each sub in parallel ("+"'s together, "-"'s together) making each sub essentially 2 ohms. Then connect one sub to each channel of the amps. This will put about 200W on each sub.
Mar 14, 2008 | Pioneer PRS-X720 Car Audio Amplifier
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
