Question about Bosch Dishwashers
Bosch SHU33A06UC/17 wont drain - Bosch Dishwashers
2 Suggested Answers
  • 833 Answers
SOURCE: Dishwasher draining - Bosch SGV4313GB/17
This is generally because of a stuck diverter solenoid. The water goes to the pump and then is either sent to the wash arms or the drain. Also, check the drain.
Posted on Feb 11, 2008
My bosh shu33a06uc dishwasher is stuck in water discharge cycle. It will run untill door is open.
This error means your dishwasher has water in the pan below your tub. You need to remove toe plate below the door and soak up the water in the pan to reset the motor.
Good Luck
http://www.appliancerepairlesson.com
Mar 06, 2011 | Bosch SHU3306UC Built-in Dishwasher
Bosch dishwasher will not drain
drAIN AND CANCEL BUTTON WILL RESET UNIT;)
Feb 25, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Bosch dishwasher won't drain model SHU3302uc/17
probably something stuckin drain pump. remove plastic part in bottom of unit with a torc screw driver spin the propeller and your problemis solved. let me know if it works.:]
Dec 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Dec 09, 2009 | Bosch Washing Machines
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Bosch dishwasher wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Feb 22, 2009 | Bosch 24 in. SGI43E05GB Built-in...
Non return valve
Has it always done this? If so it was an install issue. The tech should have put the drain above the drain with a loop to prevent backfill.
Jan 26, 2009 | Dishwashers
Feb 11, 2008 | Bosch 24 in. SGE09A25 Built-in Dishwasher
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Jan 06, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwashers Logo
87 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
