Seeking Parts Advice for Broken Samsung TV
Hello experts! Last night the only two HDMI ports on my Samsung Plasma TV Model # PN50B430P2DXZA (2009 model 720p HDTV) broke and now neither work. We believe the TV was angled in too severely to the wall without ample clearance and the ports broke free from what they were connected to inside the TV. They both worked before the TV was pushed into the wall and are now are super loose and do not work. Hubby would like to simply buy a new board that has the HDMI ports connected to it rather than try to solder the HDMI ports back on. I would appreciate some help from this community in locating the correct part for this TV, as the parts websites I've visited were not non-professional-friendly. I have repaired numerous things myself (solenoid on washing machine, dishwasher parts, electronic ignition on stove) with y'all's help so please don't fail me now! :D Many thanks! Sherri
    Sergeant:
  • 204 Answers
I would also just buy a new board .BUT keep the old board for parts! This way if anything goes out you can compare components on the board etc and figure out what's wrong and also use the parts for repairs when you need them. Some of those boards HDMI ports have the tiniest solder joints and you can easily bridge them make the board useless anyway. These things are way more fragile than the old CRT tv's. Just be a little more careful next time.
Posted on Dec 30, 2012
  • cakepro
    cakepro Dec 30, 2012
    Thanks. We'll keep the old board. I just need the correct part number, if someone could be so helpful to find that for me. Thanks in advance!
  • Brandon Murphy Dec 30, 2012
    I can help you look. Usually the part number is silk screened on the board or maybe a sticker with a barcade.
  • 128 Answers
SOURCE: Element Electronics 42" Plasma TV
damaged lcd screen are not repaireable but are replacable. mostly expensive depending on its size. handling, shipping or transporting units with lcd such as plasma tvs should be given extra care.
Posted on Oct 16, 2008
  • 178 Answers
SOURCE: I need a new power supply board for my Samsung HP-T4254
I would be Leary of cheap boards, $159 is a reasonable price for an oem replacement. i would not do it myself.
Posted on Sep 02, 2009
Testimonial: "Gave a quick, honest response, thanks!"
  • 10 Answers
SOURCE: Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
Posted on Oct 10, 2009
  • 119 Answers
SOURCE: Samsung PS42P2S plasma tv faulty sound.
look under tv
Posted on Feb 20, 2010
  • 10 Answers
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
Posted on May 11, 2010
Samsung PN43F4500AFXZA HDMI FIX
make sure you have it set to hdmi when cable is connected to source. try another working hdmi cable. try other hdmi ports.
May 08, 2017 | Samsung Televison & Video
Hdmi ports not working
Disconnect EVERYTHING for a few minutes - reconnect and restore all factory settings.
Jan 26, 2014 | Samsung 55 inch UA55ES8000 Smart 3D LED...
Hdmi port not working on plasma tv
Contact the authorized service center to rectify this fault. In most cases, the main board might need replacement.
Jul 23, 2013 | Insignia 42" LCD Flat-Panel HDTV
How do i connect my Samsung plasma tv to my Compaq Presario SR1601NX?
Hi Prissy,
You get USB to HDMI/DVI cables with which you can make the connection with your TV to PC
Hope this helps you.
Regards
Nat
Jun 29, 2012 | Samsung PN50C450 50 inch Series 4 720p...
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
Hi guys I have a Phillips Plasma TV 42PF5521D/10 model UK version bought in 2008 Guess what untill now i only used the HDMI ports to connect a Home Media Center PC to watch HD content. So last...
hi First, remember the old HDMI reset tech tip. Unplug all HDMI cables (one end will do.) Then remove power from all things in play. No, not just turned off but remove the AC. Wait 5 to 10 minutes, hookup re -test thanks
shaun .
Mar 09, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
Broken HDMI Port for HP-R5072
The HDMI input along with others is located on the a/v control panel of which would have to be replaced. I haven't seen an input jack yet with a part number attached for any model. I would suggest call a service center for a diagnosis.
Jan 24, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
