Question about Samsung SGH-E350 Cellular Phone
Chargingf fault whenever i plug in the charger and try to charge the phone it comes up with a message saying usb charging not available!!!!!!CAn anyone help me?
  • 44 Answers
M8 try reseting the phone to factory settings if that doesent work try sending it to these guys http://www.mobilephoneservicecentre.co.uk/
Posted on Jun 26, 2007
SOURCE:
Iphone will not charge..... message says charging is not supported with this accessory.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 21, 2012 | Apple iPhone4 4G iPhone 4
Wont charge
First Option:
Second Option:
Sep 09, 2012 | ZTE Avail Bluetooth Music 3G GPS Android...
Wont charge
First Option:
Second Option:
Sep 09, 2012 | AT&T Avail
AT&T Impulse 4g says phone is charging when it is not plugged in. Will not charge when plugged in!
First Option:
Second Option:
Jul 26, 2012 | Huawei Impulse 4G
Whenever i try to charge my motorola krave, i get an error message saying "unauthorized charger" and my phone doesn't charge....how can i charge my phone?
There are two ways: since Motorola phones use mini-usb, you can connect it directly to your pc via a mini-usb cable- it should charge that way. The other way is to get a new motorola branded charger- they run about 10-15 dollars at your local big-box retailer. If it still does not charge with known-good cable or known-good charger, then the hardware in the phone has faulted and you will need to go to your carrier and ask for a safety-related replacement (electrical issues = safety issues in my book!)
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Nov 13, 2010 | Motorola Mobility Krave™ ZN4 Cell Phone
Whenever i plug my charher into my motorola razor it says unauhorized charger.
The "unauthorized charger" message is hence telling you that the power
output of your charger is significantly lower than a Motorola charger
would provide. It may or may not still charge the phone, you'll have
to try it to see. If it does charge the phone it will take longer to
do so than a higher power charger would.
Hope this helps. =)
Oct 20, 2009 | Motorola Cell Phones
Not able to charge the battery
As per Sony, if you are getting this message, it's a concern.
This message usually appears, if you are using a Battery other than Sony's.Make sure you are using Original Sony's charger. Try to use some other Charger and Battery.
If problem persists, you need to send the unit for repair. More likely, it's a firmware issue. I have hardly seen any Charge / Battery issue.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 13, 2009 | Sony Ericsson Walkman W705 Cell Phone
Nokia N95 8gb. will not charge or power up.
That phone does charge using the USB port like other phones do. You have to use the 5v Nokia Charger that comes with the phone; it should plug-in right next to the USB port.
Mar 08, 2009 | Nokia N95 Cellular Phone
Charging P168 with USB cord
i have heard someone say that the charger goes in both ways on your model, and that one way it charges and the other way it detects headphones. try flipping your charger upside down vice-versa.
Jan 29, 2009 | Dual Electronics CECT P168 Cellular Phone
Charger fault
m8 sounds like your software needs loadin on again or fone needs to be formated best advice i can give you is try to reset it using reset factory settings an if that doesent work send it to these guys http://www.mobilephoneservicecentre.co.uk/
Jun 23, 2007 | Samsung SGH-E350 Cellular Phone
Samsung SGH-E350 Cellular Phone Logo
47 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
