Question about Vacuums
2001 kirby G6 vacuum wheel fell off. where does the spring go when put back together?
Two little springs came out.
  • Vacuums Master
  • 18,411 Answers
SOURCE: Replacing spring in wheel height adjustment
I just solved the problem. Go to this website: http://www.completevac.com/kirby_schemo_5.html
It will show you where the spring goes (left side inside the ratchet - when you remove the ratchet you will see that it is hollow. That's where the spring goes!) and a good picture of that assembly
Posted on Sep 23, 2008
SOURCE: The right front wheel came
Thank heavens for a husband who can fix anything--and save me a lot of money for repairs and advice!
  • 112 Answers
SOURCE: dont know how to put the shampoo system together on my kirby g6..
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Copy and paste the above link to the address window of your browser for the Kirby Shampooer instructions.
Hope this helps :)
And thank you for using Fixya!!!
Posted on May 23, 2009
  • 175 Answers
SOURCE: replace wheel axle on my kirby g3 vacuum. have a
The spring goes inside that pedal that you step on to advance the height. Place that spring in that pedal and then place the pedal into its' groove, then put the axile and wheel assembly over the pedal and put your screws back into the mounting sections.
Posted on Jan 01, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: The spring and clear plastic
    I'm sorry to hear you're having difficulties with your DC28. It's probably best if you get in touch with us directly, so one of our experts can talk you through the process of reattaching the clip over the phone. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
    Kind regards,
    Jack
    Dyson Online Customer Support
    Posted on Sep 26, 2011
    I need to put the neutral pedal back together
    will need to get Kirby engineer to repair, should cost 39 callout+28 for new pedal
    Jan 11, 2013 | Kirby G6 Bagged Upright Vacuum
    G series kirby ultimate the wheel fell off and its on the side with the height adjustment....all fell on to floor when it came apart....how does that wheel stay on is there a part missing or do you just...
    I cleaned the end of rod and the hole in the wheel, and then forced the wheel back on the rod. A little bit of glue at the end of rod will help to keep wheel stay.
    Apr 21, 2011 | Kirby G5 Bagged Upright Vacuum
    The TechDrive Pedal on my Kirby G6 fell out of the back of my vacuum cleaner. I removed the screws from the metal plate one the bottom to try to see if something had come a loose. Can you send me a diagram...
    This requires removal of the transmission assembly and replacement of the pedal assembly - it cannot be repaired. The handle and upper motor shell must be remove to access the transmission assemby. There are two screws in front, and two under the plastic switch plate.
    Jan 18, 2011 | Kirby G6 Bagged Upright Vacuum
    Handle falls back on kirby vacuum
    You need to change handle holder (the one with spring at the bottom of handle), mostly spring disconnected and it can,t be fixed.
    May 28, 2010 | Kirby G6 Bagged Upright Vacuum
    Replace wheel axle on my kirby g3 vacuum. have a
    Dec 31, 2009 | Kirby Vacuums
    Right wheel slips off on Kirby Gsix . How do I fix it?
    The shaft is held onto the machine with two little metal pieces on the bottom of the Kirby. They are held on with screws. The rear wheels are held onto the shaft with a little tiny "c" clip.
    Marci
    Jun 13, 2009 | Kirby G6 Bagged Upright Vacuum
    Dont know how to put the shampoo system together on my kirby g6..
    Hope this helps :)
    May 02, 2009 | Kirby G6 Bagged Upright Vacuum
    The back wheel came off and i went to put it back on and the other wheel that connects to the mechinism/gear height ajustment that goes up/down with a spring in it came off as well. i have been looking for...
    You do not need schematics, it is fairly easy. Clean and lubricate the teeth on the inside of the front wheel shaft assembly. Insert the spring into small pedal and place the pedal designated opening on the Kirby front fan casing with teeth facing out. Then take the wheel shaft assembly and put it over those teeth and onto the fan casing. Use two clamps and 2 screws to attach the shaft to the fan case. Need any parts - go HERE.
    Good Luck,
    Rocky
    Apr 05, 2009 | Kirby G6 Bagged Upright Vacuum
    Jul 30, 2008 | Kirby G6 Bagged Upright Vacuum
    Vacuums Logo
    79 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
