Question about Sony Televison & Video
Sony wega 55in. turns on and off every minute and power light stays green
TV turns on and off about every minute for about an hour then stays on after that. The power light stays green and does not blink a code or change to red. The lamp replacement light stays off. Does anybody know what could be wrong. Thanks, Rod
    Top Expert:
  • Sony Master
  • 74,136 Answers
What is the exact model number to your Sony WEGA?
Posted on Dec 31, 2012
SOURCE: 42 INCH SONY WEGA
lose\
connection
Posted on Apr 03, 2008
jupits69
  • 4 Answers
SOURCE: KV HR36 Sony Wega, 10 blink and turn off...
try to replace the horizontal out transistor
Posted on Jul 18, 2008
  • 4234 Answers
SOURCE: SONY WEGA KV-36HS420 will not come on
The blinking is an indication that the set detected a problem. The code usually indicates a bad regulator circuit. If yu can solder, you can probably fix this your self. Please let me know if you wish to attempt the repair. If not, expect a parts cost in the $25-$40 range plus the local labor rate for the repair.
Posted on Oct 01, 2008
  • 61 Answers
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Posted on Oct 15, 2008
welcomejee
  • 10594 Answers
SOURCE: SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
Posted on May 18, 2009
Grand Wega turns off and comes back on
sounds like your lamp is getting weak, you need to replace it.
Jan 12, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony LCD Grand Wega 55in keeps turning off then on. It is on for about 1-2minutes before it turns off again - then automaticly turns on. The red light at the bottom of the TV never turns on - the green...
Have you ever tried to clean the air intake filter that sits behind your speaker grill. Have you ever replaced your lamp before either?
Blessings,
A/V Media Tech Guy
Dec 19, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony Grand Wega KDF_60XBR950 turns itself off
Symptom shows its time to replace Lamp.
How old is this TV?
Apr 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV powers off for no reason
Its your bulb on its way out.
the replacement bulb is a Sony XL-2400 But yours should definately be under warranty
Mar 20, 2009 | Sony KDF46E2000 46" Projection HDTV
Tv sound and pic goes out and green light flashes for 38 seconds
I have the same tv and it did the same thing. I replaced my lamp and it corrected the problem.
Jan 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Pictures goes black while power light blinks green
I have a 40 but i was having the same problem. It turned out to be my lamp. I got a brand new lamp from Projector Lamp Services (relampit.com) and my tv works fine now. Im pretty sure that the 40 and the 60 take the same lamp. You might want to give them a call.
Jan 05, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
