Windows Error Reporting Error
When Windows itself crashes, it sends an error report to itself. Or, at least it tries to. I get this error: Windows cannot find 'http://wer.microsoft.com/responses/resredir .aspx?sid=685&Bucket=0x8E_win32k!GreGetGlyphIndicesW%2baf&State=1&ID=cbf7bd62-f66e-42d6-a3d5-d3200a1ab288&LCID=1033&OS=5.1.2600.2.00010300.3.0'. Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search. And it can't actually send the error report. Help?
  • Computers & ... Master
  • 27,725 Answers
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. Hope this helps.
Posted on Dec 31, 2012
  • 32 Answers
SOURCE: Help and Support cannot be found
Boot using the XP cd and choose the "Recovery" option..
Posted on Feb 12, 2009
  • 32 Answers
  • 23 Answers
SOURCE: Windows Startup Error csrss.exe
Okay, we are going to try two things. If the first don't work go to the second.
1) First perform a search on your computer for the 'csrss.exe' file. If found, copy it and then paste it into your C:\windows\system32 folder.
That should do it.
2) If that don't do it or your search can't find it, then perform the following;
To scan and verify the versions of all the system files that Windows File Protection protects, use the System File Checker (Sfc.exe) tool together with the /scannow parameter. If the SFC.exe tool detects that such a file was overwritten, the SFC.exe tool retrieves the correct version of the file from the Dllcache folder or from the Windows installation source files, and then replaces the incorrect file.
To run SFC, please follow these steps:
1. Click on Start > Run command prompt
2. Type SFC /scannow, and then press ENTER
Note: You may be asked for inset OS CD.
3. After finishing SFC, you may run CHKDSK C: /R in the Run command prompt as well.
Posted on Feb 14, 2009
  • 90 Answers
SOURCE: Every time I start my computer running Windows XP,
just click start and select run and typr msconfig. u will get a menu and in that click startup ..u will get a list of files loading in startup. untick the one appearing in ur error. and restart
Posted on Apr 10, 2009
  • 64 Answers
SOURCE: I keep getting an error
What you're seeing is a message from Microsoft ONLINE CRASH ANALYSIS (oca.microsoft.com). You are using WinXP and I suspect that you're located somewhere within the US. You seem to be having a problem with Internet Explorer or possibly with an Office 2007 or Office 2010 product.
Please read the following page from Windows Error Reporting:
http://wer.microsoft.com/responses/Response.aspx/1485/en-us/5.1.2600.2.00010300.3.0?SGD=790f1d8f-b3c5-46de-ad3a-82f5dac47ab7
The error message you're seeing could actually be related to countless numbers of stupid Windows problems, so please follow these instructions:
1. MAKE SURE that you have the MOST RECENT updates for Windows XP and Internet Explorer. If you haven't installed Win XP SP3 yet, download it and install it right away. SP3 will reboot your system; do NOT interfere with this process.
2. Next, run Windows Update and let it install whatever patches and patched patches you are missing. This process could take HOURS, so start it and check back every 15 minutes in case you have to click on an "OK" button.
3. Make SURE that you have ALL of the patches and updates for EACH application in Office. Update Word FIRST, then REBOOT THE COMPUTER. After that, update EACH of the remaining apps (XL, Outlook, and PP) but REMEMBER TO REBOOT THE COMPUTER after EACH update.
This could be a SIMPLE fix, or a VERY complicated problem. Please understand that there is no EASY or SIMPLE way to determine EXACTLY where the problem is located, because Microsoft uses some of the basic IE files throughout other MS products, which is stupid in the extreme, but that is "The "Microsoft Way" of doing things.
Good luck with this; you could have a LOT of work to do to eliminate this. Please do NOT simply wipe the HDD and reinstall Windows; you can learn a LOT from this.
Posted on Apr 30, 2011
Installed hallmark card studio 2011 upon launch keep recieving send error message to microsoft.
The installation must have gone wrong somewhere, Uninstall and install again.
If the program works anyway. Just disable the "Send Error Report" message:
To access the settings for the reporting feature:
  • Click Start.
  • Right-click My Computer, then click Properties.
  • Click the Advanced tab.
  • Click Error Reporting.
To configure the error reporting feature:
  • By default, error reporting is enabled. To disable it, click Disable error reporting. To continue to be notified when errors occur without being prompted to report the errors, click to select the But notify me when critical errors occur check box.
  • Specify whether you want to use error reporting for the Windows operating system, for programs, or for both Windows and programs.
  • To report errors only for selected programs, click Choose Programs, click All programs in this list, and then click the programs that you do not want to include.
  • To add a program that is not listed, click Add, type the name of the program, or click Browse to find the program on your computer.
Mar 01, 2011 | Computers & Internet
Tip
Disable The Send Error Report, to Microsoft
Open Control Panel
Click on Preformance and Maintenance.
Click on System.
Then click on the Advanced tab
Click on the error reporting button on the bottom of the windows.
Select Disable error reporting.
Click OK
Click OK
on Apr 12, 2009 | Microsoft Windows XP Professional
Tip
Disable Error Reporting Windows XP
everyone hates those error reports whats the use of sending them they never inprove so here is how you Disable Error Reporting
1. Open Control Panel
2. Click on Performance and Maintenance.
3. Click on System.
4. Then click on the Advanced tab
5. Click on the error-reporting button on the bottom of the windows.
6. Select Disable error reporting.
7. Click OK
8. Click OK
Regards: Dark-Viper
on Jan 27, 2009 | QuickStart PC Cleaner XP (798936829016)...
I disabled the error reporting in my computer properties, Advanced. But still I am facing the same "don't send" error. Please help in solving this problem.
In system properties go to advance option and select error reporting in that window give select the option that "disable error reporting" and unchecked "But notify me when critical error occur".
Aug 05, 2010 | Microsoft Windows XP Professional
How do I delete the error reporting to microsoft
if it is Showing ” Internet Explorer has encountered a problem and needs to close. We are sorry for the inconvenience ” Click “Don’t Send ” and everything get closed ,This Window error Report generated by microsoft is sometimes create problems for you , it is suggested you to dont ever click Send Error Reports or ” Please tell Microsoft about this problem ” because it will send all yours computer details to Microsoft , and creating problems for you.so its better to disable that error repor,so that such problem not arise in future,There are three methods to disable Microsoft error reporting.
  • To get rid of this MS Error Reporting, Right-click the My Computer icon on your desktop and choose Properties.
  • In the System Properties , go to the Advanced tab and click Error Reporting.
  • Select disable error reporting This will make any crashing program’s window simply close itself.
  • You could also click But Notify Me When Critical Errors Occur, but it might be even safer if you select Enable Error Reporting.
Inspite of this technique you can also disable error reporting via control panel as well as via editing registry . icon_smile.gif
Tags: Dont Send, Error Reports, Microsoft, Window Error
May 19, 2010 | Computers & Internet
I've installed the latest version of msn yesterday. 5 seconds after i sign in i get the ''Windows Live Communications Platform has encountered a problem and needs to close. We are sorry for the...
Although the solution is being posted months after the question is raised, let this help others having the same Dr.Watson issue.
For this, you can ignore the Error Reporting window, or turn off error reporting so it wont dump your windows drive with GBs of unwanted error dump data. If you are good with Registry Editor, follow the steps below:
Open your Registry Editor and browse to
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionAeDebug . Create a new string value (REG_SZ) with name 'Auto' and enter its value as 0, so error reporting gets disabled.
May be this article should help you.
Oct 06, 2009 | Microsoft Windows Live Messanger
Dont send error
Hii
You can follow the steps inorder to hide this error from popping up every time :-
RIght click on MY COMPUTER icon > PROPERTIES > ADVANCED tab > ERROR REPORTING (on lower right of the properties window) > Select DISABLE ERROR REPORTING.
Regards and hope it helps u.
CHEERS
Sep 07, 2009 | Microsoft Windows XP Professional
Error of send and dont send.
Does this happen every time that you do that? If so, try to uninstall the program, then re-install it. It's not unusual to get an error report popup every once in a while, just ignore them, as long as they don't happen all the time. Sometimes they result when trying to do something too fast.
If you want to turn off error reporting go to:
start>settings(classic view)>control panel>system>then click on the "advanced" tab>then click on "error reporting" in the lower right handside of the "system properties" box. Select "disable error reporting", then click ok, apply, then ok again.
If this is a recurring problem, then post back with more details.
Feb 10, 2009 | Microsoft Windows XP Professional
Error Report (send-Dont send issue)
You turn error reporting off.
You need Administer privileges to do this.
1) Right click My Computer
2) Click on the Advanced Tab
3) At the bottom right of the resulting property sheet click on Error Reporting
4) Select Disable Error Reporting and deselect 'but notify me, etc.'
This is a persistent setting unless you "Reinstall your OS" in that case you will need to do steps 1-4 again.
Restart your system.
You should be able to run the game at any configuration you want. Take a look at the settings in the game to see if it sends you error messages but I bet you've done this already.
As always make sure you are using the latest set of drivers, not Beta, for your Display Adapter.
Regards,
Worldvet
Jun 17, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
