Question about Water Heaters
Low water pressure
The whloe house has low hot water pressure. Even the first spiket (standart old fashion)is low pressure. Should the white things in the inlet and exit holes that can be seen looking down in the holes in the top of the tank be removed?
  • Water Heaters Master
  • 5,245 Answers
1) Copy following link for troubleshoot walk-thru:
http://waterheatertimer.org/Low-hot-water-pressure.html
2) Yes. Remove the heat-trap inserts from water heater.
3) Add comment and say where you are so far.
Posted on Dec 30, 2012
  • 104 Answers
SOURCE: low hot water pressure
are you on city or well supply for water?
Posted on Nov 11, 2008
  • 70 Answers
SOURCE: Very Hot water coming out of overflow pipe
Is your boiler heating your domestic hot water if so i would turn water off to water maker and see if your boiler pressure stays down below 20 psi. If so water maker is bad. The other thing that could cause this problem would be the boiler pump is out.
Posted on Jan 23, 2009
gary1121
  • 332 Answers
SOURCE: Vaillant Mag 325 warm water only full pres. cold low pressure
you need a certain amount of water pressure for the water heater to turn on this is actaully one of the biggest problems that all manifactures forgot to tell anyone it is normal for the computer to shut down beings it is designed to heat water at a fast rate when you turn the water down, it's not enough pressure for for sensors to turn on to heat the water so turn on the spigot a little more and enjoy
Posted on Jun 09, 2009
  • 4 Answers
SOURCE: low pressure on hot water taps and showers
Many states building codes require a pressure regulator and expansion tank for hot water heater installation. Check the pressure regulator if you have one as this would only affect the hot water pressure. Adjust or replace. Rap the expansion tank like knocking hard on a door. Hollow sound is good. Dull thud means it needs to be replaced as it is filled with water.
Posted on Jun 24, 2009
  • 35 Answers
SOURCE: I have a thermostat mixer shower but hot water has
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Posted on Feb 19, 2010
How can I increase the hot water pressure in my home?
Cold water pressure is what give you your hot water pressure so they should be equal but if you have a restriction on the hot side such as a valve not opening on the hot side or not opening all the way then you will have less pressure or the pipe work on the hot side is not proper. Hard to say but check the valve on top of the hot water heater
Aug 13, 2014 | Water Heaters
Low water pressure in one area of house
Copy following link:
If one area of house is affected, then clog is usually at elbow or connection point.
Remove water shut-offs, and use compressed air to see if clog can be jostled loose.
Apr 28, 2013 | Water Heaters
Rheem powervent 42vp40f does not provide water to all faucets
Feb 2013
1) Copy following links for Intellivent gas control service manual, low hot water pressure, and crossover:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/Crossover.html
2) Unknown if tank has hot water > that is first thing to check.
3) Unknown if air intake screen located under burner is clogged with dust that cause combustion chamber to overheat, tripping FV lockout and breaker TRD glass vial.
Requires removal of combustion parts, replacement of TRD, blow out air intake screen, reset intellivent
4) Unknown if there is error code.
5) Rheem does not post service manuals.
However this unit can probably be repaired.
Feb 05, 2013 | Water Heaters
Reem hot water 180 dvn water pressure drop
1) Copy following link for detailed troubleshoot walk-thru:
2) Today's new water heaters come with heat traps or heat trap inserts, so manufacturer can claim higher energy savings. But these things restrict water flow and clog, and reduce pressure, and whistle, and generally cause problems for some installations.
http://waterheatertimer.org/images/Bradford-white-Heat-Traps-2.jpg
3) Add comment and say what you discover.
Dec 09, 2012 | Water Heaters
Water pressure decreases as the water runs
Probably a clog in galvanized pipe.
Expansion tank is not whole-house pressure regulating tank. It is localized protection for plumbing exposed to high pressure caused by very hot water.
If you house has pressure regulating valve, then that can be a cause.
For low water pressure in household, the following link might help:
Aug 07, 2011 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Water Heaters Logo
89 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
