Need copy of manual for kenmore Model #11042822220 Kenmore Elite Washer
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Washing Mach... Master
  • 102,366 Answers
You may download a copy of the manual at http://c.searspartsdirect.com/mmh/lis_pdf/OWNM/L0533141.pdf
Posted on Oct 09, 2014
jgwhomeequip
  • 1902 Answers
SOURCE: Iget a f-11 trouble code on my kenmore elite he4t washer.
REplace your MCU. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem. Go onto kenmore.com and find your right washing machine and replace the part yourself. First try and take the wiring harness off and then reconnect it and see if the error code goes away if it doesnt then replace the part. Please Rate. Thank you
Posted on Feb 12, 2009
SOURCE: i lost the manual of my kenmore elite he4t washer
pumping out water but not spinning, no aggitation
Posted on Oct 10, 2009
  • 311 Answers
SOURCE: My Kenmore Elite washer spins to slow cauisng the
If this is occurring mostly on heavier loads your clutch may be slipping. If you take a flathead screwdriver and push down the lid switch so the washer will spin with the lid up, grab the inside of the drum. If you can easily stop the drum its most likely a bad clutch. If you tip the washer back and see oil underneath then its probably your transmission leaking oil onto the the clutch causing it to slip (in which case you need transmission and clutch assy). If you see oil I would probably not bother calling a tech it would be a pretty expensive repair.
IF the problem is with the clutch only it may be worth repairing but to replace the clutch you will have to remove the pump, motor, transmission, and the clutch mounts on top. The other less common possibility could be a bad drive block under the inner tub. hope this helps. _MJ_
Posted on Jan 28, 2010
SOURCE: need a manual for my kenmore elite he3t front load washer
My Kenmore Elite HE3 has been great for many years, and now I have a little problem for the first time.
I can usually press cancel to change the program. This morning, after I selected one program and press cancel, it won't cancel. Lights just blinked. So, I press Start to wash with selected program, but it won't start. It won't start nor cancel no matter what I do.
Should I unplug the unit?
Thank you so much!
Posted on Mar 11, 2010
  • 1937 Answers
SOURCE: Kenmore He3 washer manual required
See the following Sears site for on line (PDF) manuals
http://www.managemylife.com/mmh/owner_manuals/search?query=110.45872400
Posted on Mar 29, 2010
I have a kenmore elite he3 smart heat quiet pak4 how much is a motor for this dryer
  1. Kenmore Elite He3 Parts - searspartsdirect.com‎
    Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
    Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller.
    Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Search Results
    MOTOR diagram for model # 41794130000 Kenmore-elite ...
    www.searspartsdirect.com/model-part/41794130000/0583/.../00004.html
    MOTOR Diagram and Parts List for KENMORE ELITE Dryer-Parts model # ... MOTORdiagram for model # 41794130000 Kenmore-elite-Parts Dryer-Parts (18).
    PUMP AND MOTOR PARTS Diagram & Parts List for Model ...
    www.searspartsdirect.com/model-part/11047789702/0583/.../00006.html
    PUMP AND MOTOR PARTS Diagram and Parts List for KENMORE ELITE ... ANDMOTOR PARTS diagram for model # 11047789702 Kenmore-elite-Parts ...
Nov 01, 2015 | Kenmore Dryers
Need owners manual for a kenmore elite washer that is free
What is your model number..also to let ya know Sears does charge for manuals. HOWEVER Sears doesnt make that washer that have it labeled for them..so with the model number i can determine exactly who made it..very likely Whirlpool and send ya a manual for that exact equivelent machine which will be identical except on the front where yours says Kenmore that one will say WHIRLPOOL
Whirlpool does not charge for manuals
or even if is made by General Electric their maunals are free as well..only Sears charge to send ya hard copy in the mail and wont allow a pdf electronic versoin of it to be downloaded free
Aug 24, 2011 | Kenmore Washing Machines
Manual for elite Kenmore front loader
You will need to type into your search engine/web brouser 'kenmore washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 14, 2011 | Kenmore Elite 45986 Front Load Washer
Head over to the manufacture's website. WWW.SEARSPARTSDIRECT.COM
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 15, 2010 | Kenmore Elite 45986 Front Load Washer
How can I get a copy of the User Manual for the Kenmore Elite HE 3? I would like to get a downloadable one if possible?
See the following two sites.
Enter your complete model number AND:
The first site should show diagrams of all the major components in the washer.
The second site is Sears site for downloading PDF versions of their User Manuals.
SEARS PARTS SITE MAY HAVE MANUALS
http://www.searspartsdirect.com/partsdirect/index.action
SEARS ANSWER SITE
http://www.managemyhome.com/
May 03, 2010 | Kenmore Elite HE5t Washer
Manual for kenmore elite 45986 front load washer
See the following site and select your actual model number:
The 45986 number is the stock number, not the model.
http://www.managemylife.com/mmh/owner_manuals/search?query=elite+45986
Apr 07, 2010 | Kenmore Elite 45986 Front Load Washer
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
I am house sitting and i dont know how to use the washer and i cant find the manual with the instructions
If this is a Kenmore Elite front loader as you have this question listed under, you can find a FREE copy of the owner's manual at managemyhome.com. Just locate the model number (listed on a nameplate around the door opening) and enter it under the "Manuals" link. You can view online or download a copy. I hope this helps you.
Sep 05, 2009 | Kenmore Elite 45986 Front Load Washer
I need a manual for a Kenmore washer, model # 1102708604.
I have now got the manual for the Kenmore Elite washer and dryer coming in by mail. I had gone to the local Sears store and then to the service center close to home. The service center was able to find the manuals and order them for me.
Thanks for your help.
Cecil
Apr 10, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
