Question about Belkin Share N300 Wireless Router (722868807392)
I kept getting a window that says another computer is on and has the same ip address and I couldn't get on the internet, I am on now after several reboots, what did that window mean, is someone el
  • 7,627 Answers
Is your wireless Secured? Pull the AC plug from the Belkin., plug back in, reboot computer. Setup Security on your wireless . Use this Manual: http://www.belkin.com/networking/manual/MAN_F7D7302_v1_8820-00698_Share_N300_N_Router.pdf
Posted on Dec 31, 2012
4 Suggested Answers
roadhawk
  • 25 Answers
SOURCE: IP address
Hi tammyhope,
I would guess that your ISP is providing a dynamic IP address for connectivity to the internet. If your router is changing the IP address back to default, I would think that your configuration is not setup properly, to receive a dynamic address, but is set with a static address instead. So what happens is that when you attempt to connect to your ISP your router is resetting. If this is the case then you need to go into the router configuration and set it to recieve a dynamic address from your ISP.
--RoadHawk
Posted on Nov 25, 2007
SOURCE: wireless computer won't connect to internet
Somewhere in the network connections settings I recall seeing a checkbox to tell the laptop to automatically determine the IP address when connecting (as opposed to using the same one every time). Sorry I don't recall more specific directions ....
Posted on Jan 01, 2008
dante777
  • 623 Answers
SOURCE: Can't access my computer onthe internet
  1. Make sure that your ISP is not blocking port 80. You can check that here. (Otherwise switch to another port like 8080 or 805)
  2. Have you setup your DDNS service on your router or ensured by other means that no-ip has your up-to-date external IP? (Make sure that your external IP matches the entry at no-ip.com!)
  3. Set your LAN server to a static IP address
  4. Make sure that port forwarding is enabled and pointing to your server.
    - That means: if you run a webserver on port 80, you have to set the external port to 80 and leave the internal blank, unless your internal server listens on a different port.
If this does not help, what exactly do your mean by "Fail to connect"? Is it a 404 error? Please provide details.
I think this might be interesting for some other people too. So please come back and leave a comment!
Posted on Dec 29, 2008
I cannot connect to the WFC because it needs the ip adress and the connection fails
Click start type cmd press enter you will be in DOS mode
type in ipconfigpress enter you will see all of your internet connection details type in your default gateway ip adress into your internet search should read something like 10.0.0.138
Your IP Address should be thought more as your computer's phone number than it's address, if you have multiple connections, you have multiple IPs if you dont have a connection, you dont have an IP.
Without further delay If you need your computers IP address:
This will work in almost every case, it simply requests the website's server to tell you what your IP is. http://whatismyipaddress.com/
I have included a link to make things easier.
If you are in a network and need your computers local address.
Hold the windows button (looks like the windows banner, usually between left ctrl and left alt) and press 'R'.
A box will display, and type in "cmd.exe" and hit enter.
The 'command prompt' will display, a black screen with white lettering.
Simply type in ipconfig. This gives information on all your internet connections.
Look for the line "IPv4 Address".
If you need to find the IP of a current connection you can type (from the command prompt) "netstat".
This will give you all your current connections.
To identify a specific one, the easiest way is to run it before you establish the connection then again afterwards.
Change IP Addresses
Your IP address is a series of numbers that identify your specific computer on the Internet.
If, for some reason, you want to change your IP address, you can do so without going into the command prompt.Click "Start," "Control Panel," "Network and Internet" and "Network and Sharing Center."
Click "Change adapter settings."
Right-click the network you want to change and click "Properties."
Click the "Networking" tab.
Put a check either next to Internet Protocol Version 6 (TCP/IPv6) or Internet Protocol Version 4 (TCP/IPv4) and click "Properties."
Click the radio button next to Obtain an IP Address Automatically if you want Windows to assign one, or click "Use the following IP address" to manually change it.
Enter the requested information and click "OK."
Mar 01, 2014 | 2wire Wireless-G 802.11g ADSL Gateway
How to change my router's MAC address Netopia 3397G
Using a router is a great way to create a home or office network without having to spend a lot of money.
As long as you have a broadband Internet connection through an Internet service provider, you can use a router to get all of the computers in your home or office connected.
If you have chosen Netopia as your router brand of choice, you will have to configure it to make your network operable.
Power on your Netopia router, broadband modem and computer.
Open your Internet browser.
Type the router IP address, 192.168.1.254, into the address bar. Hit "Enter" on your keyboard. Log into your Netopia router with the username and password assigned to you by your Internet service provider.
Select "Expert Mode."
After entering expert mode, you will see a menu bar at the top of the configuration window.
Click on the "Home" tab. Many Internet service providers will ship your Netopia router to you preconfigured.
If it is preconfigured all of the fields, such as IP address, subnet mask and default gateway will already be populated. If the fields are not populated, proceed to the next step.
Click on the "Configure" tab. Select "WAN." Select "ATM." Enter the "VPI" and "VCI" numbers provided by your Internet service provider.
Choose your encapsulation option.
For example, "Routed IP," "PPPOE," etc... Click "Submit."
Select "WAN" on the left side of your configuration window.
Choose the "VCC1" option. Select the option to "Enable Interface."
If you do not have your own IP address, choose the option to "Obtain an IP Address Automatically."
If you do have your own IP address, uncheck the automatic IP address box.
Type in your IP address if you have your own.
Enter your subnet mask.
This information can be obtained from your Internet service provider.
Select the "NAT" option if you are using your own private IP address for your network connection. Click on "Submit."
Ensure that there is a check in the "Gateway Option" box and "IP Address" is selected as the "Interface Type."
Type in your "Default Gateway" address.
This can be obtained from your Internet service provider.
Click "Submit."
Select the "Configure" tab at the top of your window. Select "LAN."
Select "Enable Interface."
Type in the IP address for your router and subnet mask. Click "Submit."
Click on the yellow caution symbol on the top right hand side of your window to save all configuration changes.
Click on "Save."
Restart your computer for the changes to become effective.
http://www.netopia.com/support/hardware/technotes/CQG_121.html
May 10, 2013 | Netopia Computers & Internet
How to find a IP address for my emachines laptop
go to start -- run and type in CMD
hit enter to open a black command prompt window
type in "ipconfig" without the quotes and hit enter. This will give you your IP address.
If you need the IP address from your provider that you are using out on the public internet, just go to http://whatismyipaddress.com/ and it will tell you what your external public IP address is.
Mar 06, 2013 | E-Machines eMachines Desktop PC
Trust DS-1700R keyboard working intermittently with windows 7
go to control panel , keyboards, right click on keyboard , click on properties , click on compatibility tab click check box and select operating system used in the computer
click apply and ok
Mar 25, 2017 | Trust Computers & Internet
I cannot get online with my neighbor's internet service. They have an open access signal with Time Warner cable and my message is that I need to renew my ip address to make a connection. I have
To renew the IP address under Windows XP, you issue the following two commands in sequence under command line (aka cmd):
ipconfig /release
ipconfig /renew
Feb 19, 2012 | Dell Computers & Internet
Someone is using my ip address
There are a couple of very valid ways that the same IP addresses might appear to be in use by several different computers. If the voting software using only your IP address to check for voting abuse, then it's not doing as good a job as it should be.
Two scenarios come to mind immediately: routers and bad IP detection.
As I've discussed before, a router allows several computers to share a single internet connection. One side effect of doing so is that all the computers that are sharing that connection appear on the internet as having the same IP address. The internet IP address actually belongs to the router, and it manages the routing the appropriate data to and from the appropriate computer behind it.
If you're in a home or small business that uses a router to share an internet connection, then any of the other computers could have voted and appeared as having come from the same IP address your computer would.
If you're connecting from a larger facility, say a school or corporation, the same issue can arise. Many facilities connect their internal network to the internet through a set of routers. A company of several thousand might appear as only a handful of IP addresses on the internet. If someone else within the company voted, it's quite possible that you might appear as the same IP address when you attempt to vote later.
"Using just the IP address to counter voter fraud and other types of abuse is common because it's easy." And then there's AOL.
When last I checked, I believe AOL puts all of its subscribers behind the equivalent of a collection of routers. Therefore when you as an AOL user connect to a web site you may be using the same IP address as some other AOL subscriber who came before you.
There's another problem that could be at play here as well.
If you're behind a router, your IP address is an IP address on your local network, not the internet. Most consumer routers use the 192.168.1.x range. In fact, most will start assigning IP addresses at 192.168.1.1, then 192.168.1.2, then 3 and so on.
As a result there are thousands of machines out there at IP address 192.168.1.1 on their local network.
If the voting abuse software attempts to use the IP address of the machine rather than the IP address of the machine's connection to the web site, then it'll just be wrong. The first person with an IP of 192.168.1.1 might be able to vote, but all that follow would be seen as coming from the same address.
It's very unlikely, but it is one additional way that the voting abuse detection scheme might fail.
Using just the IP address to counter voter fraud and other types of abuse is common because it's easy. As you can see, that often has the unintended side-effect of blocking more than just a single abuser. Unfortunately blocking an individual computer for these types of accesses is difficult - at least doing so in a way that isn't trivial to circumvent is difficult. The most common alternate approach is to require registration and login to vote, which naturally reduces the number of voters as people are reluctant to jump through the additional hoops.
Sep 26, 2011 | Toshiba Satellite P105-S6197 Laptop
Whte is my ip addres
Open a command line (e.g. run CMD to get a 'dos' prompt) and execute:
IPCONFIG
The line with IPv4 will have your IP address
Sep 20, 2011 | Linksys Wireless-G Broadband Router
I'm using two Macintosh Computers. I followed the quick setup wizard, all the right lights are lit. I've reset my broadband modem, I've reset the Dynex Router. Yet I can't make contact...
Richard have you tried setting up static ip addresses on the MACs
If you have other p.c's on network with auto ip assignment then alter the DHCP server lease to 192.168.1.10 to 192.168.1.240
then make ip address static 192.168.1.241 subnet mask 255.255.255.0 default gateway 192.168.1.1 and on the other mac
make ip address static 192.168.1.242 subnet mask 255.255.255.0 default gateway 192.168.1.1
http://www.macinstruct.com/node/550
Jul 07, 2017 | Dynex DX-E402 Router
I have two user on my computer but on one i can get on the internet and on the other i cant it says change the proxy setting
every user created on the OS will have to have different settings.....
before making changes...get the foll info from your internet service provider
IP Address, Subnet mask, Default Gateway, DNS server address both primary and secondary
once that's available.....
you can use different settings in in WinXP as below....
Control panel / Network Connection /Local Area Conn /Right click / properties/ Internet Protocol TCP IP / Check Box / Propertis / in IP address use the IP address that's been assigned by your internet service provider
log in to first user accunt and make the settings....for....
use the info obtained from the service provider.....
....then
in the IP address filed use some thing similar like this..(check your internet service provider for that info).....the foll is only an example from my PC
say....192.168.1.2 for user ONE
log out....
shut down and restart PC
log in to second user accunt and make the settings....for all the above fileds....then
in the IP address filed use 192.168.1.4 for user TWO....(note the difference of the last filed of the IP address....2 vs 4)...every new user a/c the last field of IP address keeps changing
1st user ....say 192.168.1.2
2nd user .........192.168.1.4
3rd user ..........192.168.1.6
etc...
http://windows.microsoft.com/en-IN/windows-vista/Change-proxy-settings-in-Internet-Explorer
hope this helps
reg
Suresh
Apr 28, 2011 | Google Chrome
I have a trendnet wireless router tew 432brp, a new hp windows 7 laptop, and old xp laptop and i want to share the connection with my verizon um175 aircard. this has worked for several years with the old...
The router connects computers together . You are using a windows 7 p.c and connecting it to an internet connection via a usb verizon um175 aircard.
I think you need to share the internet connection with the rest of the network and may need to feed the ethernet cable into the feed port of the router. I have not done this before but logically the windows 7 computer would have to act as a gateway to the internet.
http://www.dummies.com/computers/operating-systems/windows-7/how-to-share-an-internet-connection-in-windows-7/
https://www.ibvpn.com/billing/knowledgebase/53/Internet-Connection-Sharing-on-Windows-7.html
Note the default gateway is going to have to be the windows 7 ip address on the other computers
You may need to set the ip address on windows 7 to a static address and then change the dhcp server settings default gateway and also increase the first address to not include the windows 7 ip address or the routers ip address in the lease range for shcp.
Mar 17, 2017 | Trendware TEW-432BRP 54Mbps Wireless...
Belkin Share N300 Wireless Router (722868807392) Logo
47 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
